13 #ifndef vtkSISourceProxy_h 14 #define vtkSISourceProxy_h 44 virtual void UpdatePipeline(
int port,
double time,
bool doTime);
49 virtual void SetupSelectionProxy(
int port,
vtkSIProxy* extractSelection);
89 virtual bool CreateOutputPorts();
95 void MarkStartEvent();
100 vtkSetStringMacro(ExecutiveName);
110 vtkInternals* Internals;
112 int StartEventCounter;
virtual void UpdatePipelineInformation()
Triggers UpdateInformation() on vtkObject if possible.
virtual bool ReadXMLAttributes(vtkPVXMLElement *element)
Parses the XML to create property/subproxy helpers.
vtkSISourceProxy is the server-side helper for a vtkSMSourceProxy.
virtual bool CreateVTKObjects()
Creates the VTK objects.
virtual void OnCreateVTKObjects()
Called after CreateVTKObjects().
vtkSIProxy is the server-implementation for a vtkSMProxy that helps the vtkSMProxy with managing/upda...
bool DisablePipelineExecution
static vtkSIProxy * New()
virtual void RecreateVTKObjects()
Called by vtkSMProxy::RecreateVTKObjects() to re-create the VTK objects.
virtual void SetDisablePipelineExecution(bool value)
Allow to shut down pipeline execution.
vtkSICompoundSourceProxy is the server-side helper for a vtkSMCompoundSourceProxy.
