vtkSMIdTypeVectorProperty.h
13 #ifndef vtkSMIdTypeVectorProperty_h
14 #define vtkSMIdTypeVectorProperty_h
15
16 #include "vtkRemotingServerManagerModule.h" //needed for exports
17 #include "vtkSMVectorProperty.h"
18
19 #include <vector> // for std::vector
20
21 class vtkSMStateLocator;
22
24 {
25 public:
28  void PrintSelf(ostream& os, vtkIndent indent) override;
33  unsigned int GetNumberOfElements() override;
39  void SetNumberOfElements(unsigned int num) override;
40
46  int SetElement(unsigned int idx, vtkIdType value);
47
49
56  int SetElements(const vtkIdType* values);
57  int SetElements(const vtkIdType* values, unsigned int numValues);
59
61
64  int SetUncheckedElements(const vtkIdType* values);
65  int SetUncheckedElements(const vtkIdType* values, unsigned int numValues);
67
74  int SetElements1(vtkIdType value0);
75
82  int SetElements2(vtkIdType value0, vtkIdType value1);
83
90  int SetElements3(vtkIdType value0, vtkIdType value1, vtkIdType value2);
91
95  int AppendElements(const vtkIdType* values, unsigned int numValues);
96
100  int AppendUncheckedElements(const vtkIdType* values, unsigned int numValues);
101
105  vtkIdType GetElement(unsigned int idx);
106
113  vtkIdType GetUncheckedElement(unsigned int idx);
114
120  void SetUncheckedElement(unsigned int idx, vtkIdType value);
121
127  unsigned int GetNumberOfUncheckedElements() override;
128
130
133  const std::vector<vtkIdType>& GetElements() const;
134  const std::vector<vtkIdType>& GetUncheckedElements() const;
136
138
150  vtkGetMacro(ArgumentIsArray, int);
151  vtkSetMacro(ArgumentIsArray, int);
152  vtkBooleanMacro(ArgumentIsArray, int);
154
158  void Copy(vtkSMProperty* src) override;
159
160  void ClearUncheckedElements() override;
161
167  void ResetToXMLDefaults() override;
168
169 protected:
171  ~vtkSMIdTypeVectorProperty() override;
172
176  void WriteTo(vtkSMMessage*) override;
177
181  void ReadFrom(const vtkSMMessage*, int msg_offset, vtkSMProxyLocator*) override;
182
183  int ReadXMLAttributes(vtkSMProxy* parent, vtkPVXMLElement* element) override;
184
186
192  void SetNumberOfUncheckedElements(unsigned int num) override;
193
197  int LoadState(vtkPVXMLElement* element, vtkSMProxyLocator* loader) override;
198
199  // Save concrete property values into the XML state property declaration
200  void SaveStateValues(vtkPVXMLElement* propElement) override;
201
202 private:
204  void operator=(const vtkSMIdTypeVectorProperty&) = delete;
205
206  class vtkInternals;
207  vtkInternals* Internals;
208 };
209
210 #endif
virtual void SaveStateValues(vtkPVXMLElement *propertyElement)
This method must be overridden by concrete class in order to save the real property data...
virtual void WriteTo(vtkSMMessage *msg)
Let the property write its content into the stream.
virtual void SetNumberOfUncheckedElements(unsigned int num)=0
API for setting unchecked element values.
int vtkIdType
void Copy(vtkSMProperty *src) override
Copy all property values.
virtual void SetNumberOfElements(unsigned int num)=0
Sets the size of the vector.
abstract superclass for all vector properties
property representing a vector of integers
static vtkSMProperty * New()
virtual unsigned int GetNumberOfUncheckedElements()=0
virtual void ReadFrom(const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
Definition: vtkSMProxy.h:140
void ClearUncheckedElements() override=0
virtual void ResetToXMLDefaults()
For properties that support specifying defaults in XML configuration, this method will reset the prop...
virtual int LoadState(vtkPVXMLElement *element, vtkSMProxyLocator *loader)
Updates state from an XML element.
int ReadXMLAttributes(vtkSMProxy *parent, vtkPVXMLElement *element) override
virtual unsigned int GetNumberOfElements()=0
Returns the size of the vector.
Class used to retrieve a given message state based on its GlobalID.
