vtkSMProxyProperty.h
48 #ifndef vtkSMProxyProperty_h
49 #define vtkSMProxyProperty_h
50
51 #include "vtkRemotingServerManagerModule.h" //needed for exports
52 #include "vtkSMProperty.h"
53
54 class vtkSMProxy;
55 class vtkSMStateLocator;
56
58 {
59 public:
61
67  static void EnableProxyCreation();
68  static void DisableProxyCreation();
69  static bool CanCreateProxy();
71
72  static vtkSMProxyProperty* New();
74  void PrintSelf(ostream& os, vtkIndent indent) override;
75
77
81  virtual void AddProxy(vtkSMProxy* proxy);
82  virtual void SetProxy(unsigned int idx, vtkSMProxy* proxy);
83  virtual void RemoveProxy(vtkSMProxy* proxy);
84  virtual void RemoveAllProxies();
86
90  virtual void SetProxies(unsigned int numElements, vtkSMProxy* proxies[]);
91
95  bool IsProxyAdded(vtkSMProxy* proxy);
96
98
109  virtual void AddUncheckedProxy(vtkSMProxy* proxy);
110  virtual void SetUncheckedProxy(unsigned int idx, vtkSMProxy* proxy);
112
116  virtual void RemoveAllUncheckedProxies();
117  void ClearUncheckedElements() override { this->RemoveAllUncheckedProxies(); }
118
122  unsigned int GetNumberOfProxies();
123
127  unsigned int GetNumberOfUncheckedProxies();
128
130
133  void SetNumberOfProxies(unsigned int count);
134  void SetNumberOfUncheckedProxies(unsigned int count);
136
140  vtkSMProxy* GetProxy(unsigned int idx);
141
145  vtkSMProxy* GetUncheckedProxy(unsigned int idx);
146
155  void Copy(vtkSMProperty* src) override;
156
160  void UpdateAllInputs() override;
161
165  void ResetDefaultsToCurrent();
166
176  bool IsValueDefault() override;
177
183  bool IsValueDefaultNonRecursive();
184
191  void ResetToXMLDefaults() override;
192
193 protected:
195  ~vtkSMProxyProperty() override;
196
200  void WriteTo(vtkSMMessage* msg) override;
201
205  void ReadFrom(const vtkSMMessage* msg, int msg_offset, vtkSMProxyLocator*) override;
206
207  friend class vtkSMProxy;
208
213  int ReadXMLAttributes(vtkSMProxy* parent, vtkPVXMLElement* element) override;
214
218  void SaveStateValues(vtkPVXMLElement* propertyElement) override;
219
226  virtual vtkPVXMLElement* AddProxyElementState(vtkPVXMLElement* prop, unsigned int idx);
230  int LoadState(vtkPVXMLElement* element, vtkSMProxyLocator* loader) override;
231
236  void OnUpdateDataEvent() { this->UpdateDomains(); }
237
238  // Static flag used to know if the locator should be used to create proxy
239  // or if the session should be used to find only the existing ones
240  static bool CreateProxyAllowed;
241
243  friend class vtkPPInternals;
245
246 private:
247  vtkSMProxyProperty(const vtkSMProxyProperty&) = delete;
248  void operator=(const vtkSMProxyProperty&) = delete;
249 };
250
251 #endif
virtual int ReadXMLAttributes(vtkSMProxy *parent, vtkPVXMLElement *element)
virtual void SaveStateValues(vtkPVXMLElement *propertyElement)
This method must be overridden by concrete class in order to save the real property data...
Use this method to clear unchecked values set of this property.
virtual void WriteTo(vtkSMMessage *msg)
Let the property write its content into the stream.
vtkPPInternals * PPInternals
property representing pointer(s) to vtkObject(s)
virtual void Copy(vtkSMProperty *src)
Copy all property values.
static vtkSMProperty * New()
void UpdateDomains()
Calls Update() on all domains contained by the property as well as all dependent domains.
Called when a producer fires the vtkCommand::UpdateDataEvent.
This class is used by vtkSMProxyProperty to keep track of the proxies.
virtual void ReadFrom(const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
Definition: vtkSMProxy.h:140
virtual void ResetToXMLDefaults()
For properties that support specifying defaults in XML configuration, this method will reset the prop...
virtual int LoadState(vtkPVXMLElement *element, vtkSMProxyLocator *loader)
Updates state from an XML element.
virtual bool IsValueDefault()
Class used to retrieve a given message state based on its GlobalID.
virtual void UpdateAllInputs()
Update all proxies referred by this property (if any).
