13 #ifndef vtkSMStateLoader_h 14 #define vtkSMStateLoader_h 26 struct vtkSMStateLoaderInternals;
38 int LoadState(
vtkPVXMLElement* rootElement,
bool keepOriginalId =
false);
54 vtkSetMacro(KeepIdMapping,
int);
55 vtkGetMacro(KeepIdMapping,
int);
56 vtkBooleanMacro(KeepIdMapping,
int);
66 vtkTypeUInt32* GetMappingArray(
int& size);
99 const char* xmlgroup,
const char* xmlname,
const char* subProxyName =
nullptr)
override;
114 virtual void RegisterProxy(vtkTypeUInt32
id,
vtkSMProxy* proxy);
115 virtual void RegisterProxyInternal(
const char* group,
const char* name,
vtkSMProxy* proxy);
127 virtual bool UpdateRegistrationInfo(std::string& group, std::string& name,
vtkSMProxy* proxy);
151 vtkSMProxy* LocateExistingProxyUsingRegistrationName(vtkTypeUInt32
id);
161 vtkSMStateLoaderInternals* Internal;
vtkSMProxy * CreateProxy(const char *xmlgroup, const char *xmlname, const char *subProxyName=nullptr) override
Create a new proxy of the given group and name.
vtkPVXMLElement * ServerManagerStateElement
vtkSMProxyLocator * ProxyLocator
virtual void CreatedNewProxy(vtkTypeUInt32 id, vtkSMProxy *proxy)
Called after a new proxy has been created.
static vtkSMDeserializerXML * New()
deserializes proxies from their XML states.
Utility class to load state from XML.
virtual vtkPVXMLElement * LocateProxyElement(vtkTypeUInt32 id)
Locate the XML for the proxy with the given id.
