0009984 | ParaView | Bug | public | 2009-12-01 11:22 | 2009-12-02 20:18 | ||||
Target Version | 3.8 | Fixed in Version | 3.8 | ||||||
Summary | 0009984: Issue with Implicit Plane Widget | ||||||||
Description | * Create Wavelet * Change Extent to (0, 1, 0, 1, 0, 1) * Apply * Create Slice filter * The implicit plane widget's bounds are not correct. | ||||||||
Relationships | ||||||
(0018632) Utkarsh Ayachit (administrator) 2009-12-01 17:06 |
When bounds of the data were same as the default value for the PlaceWidget property, it wasn't getting pushed. Fixed that by changing default to initialized. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- Servers/ServerManager/Resources/rendering.xml new revision: 1.379; previous revision: 1.378 |
(0018675) Alan Scott (manager) 2009-12-02 20:18 |
Tested local server. Also tested with clip. |
2009-12-01 11:22 | Utkarsh Ayachit | New Issue | |
2009-12-01 17:05 | Utkarsh Ayachit | Status | backlog => tabled |
2009-12-01 17:05 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-12-01 17:06 | Utkarsh Ayachit | Note Added: 0018632 | |
2009-12-01 17:06 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-12-01 17:06 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2009-12-01 17:06 | Utkarsh Ayachit | Resolution | open => fixed |
2009-12-02 14:15 | Utkarsh Ayachit | Relationship added | has duplicate 0009591 |
2009-12-02 20:18 | Alan Scott | Note Added: 0018675 | |
2009-12-02 20:18 | Alan Scott | Status | @80@ => closed |
