pqAnimationScene is a representation for a vtkSMAnimationScene proxy. More...
#include <pqAnimationScene.h>
Public Slots | |
void | play () |
Play animation. More... | |
void | pause () |
Pause animation. More... | |
void | setAnimationTime (double time) |
Set the animation time. More... | |
Signals | |
void | preAddedCue (pqAnimationCue *) |
Fired before a new cue is added to the scene. More... | |
void | addedCue (pqAnimationCue *) |
Fired after a new cue has been added to the scene. More... | |
void | preRemovedCue (pqAnimationCue *) |
Fired before a cue is removed from the scene. More... | |
void | removedCue (pqAnimationCue *) |
Fired after a cue has been removed from the scene. More... | |
void | cuesChanged () |
Fired after cues have been added/removed. More... | |
void | playModeChanged () |
Emitted when the play mode changes. More... | |
void | loopChanged () |
Emitted when the looping state changes on the underlying proxy. More... | |
void | clockTimeRangesChanged () |
Emitted when the clock time ranges change. More... | |
void | beginPlay (vtkObject *caller, unsigned long, void *, void *reversed) |
Emitted when animation starts playing. More... | |
void | endPlay (vtkObject *caller, unsigned long, void *, void *reversed) |
Emitted when animation ends playing. More... | |
void | tick (int percentCompleted) |
Emitted when playing animation. More... | |
void | animationTime (double time) |
Emitted when playing (or when animation time for the scene is set). More... | |
void | frameCountChanged () |
Emitted when the number of frames changes. More... | |
void | timeStepsChanged () |
Emitted when the number of timesteps changes. More... | |
void | timeLabelChanged () |
Emitted when a source is changing the label that should be use for time. More... | |
void | nameChanged (pqServerManagerModelItem *) |
Fired when the name of the proxy is changed. More... | |
void | modifiedStateChanged (pqServerManagerModelItem *) |
Fired when the modified status changes for the proxy. More... | |
pqAnimationScene (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr) | |
~pqAnimationScene () override | |
pqAnimationCue * | getCue (vtkSMProxy *proxy, const char *propertyname, int index) const |
Returns the cue that animates the given index of the given property on the given proxy , in this scene, if any. More... | |
void | removeCues (vtkSMProxy *proxy) |
Removes all cues which animate the indicated proxy, if any. More... | |
void | removeCue (pqAnimationCue *cue) |
Removes cue. More... | |
bool | contains (pqAnimationCue *) const |
returns true is the cue is present in this scene. More... | |
QPair< double, double > | getClockTimeRange () const |
Get the clock time range set on the animation scene proxy. More... | |
QSet< pqAnimationCue * > | getCues () const |
Get all the cues in this scene. More... | |
double | getAnimationTime () const |
Returns the current animation time. More... | |
QList< double > | getTimeSteps () const |
Returns the timesteps from the timekeeper for the animation scene. More... | |
pqAnimationCue * | createCue (vtkSMProxy *proxy, const char *propertyname, int index) |
Creates and initializes a new cue that can animate the index of the property on the given proxy in this scene. More... | |
pqAnimationCue * | createCue (vtkSMProxy *proxy, const char *propertyname, int index, const QString &cuetype) |
pqAnimationCue * | createCue (const QString &cuetype) |
pqAnimationCue * | createCue (const pqAnimatedPropertyInfo &propInfo) |
pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr) | |
~pqProxy () override | |
pqServer * | getServer () const |
Get the server on which this proxy exists. More... | |
void | rename (const QString &newname) |
This is a convenience method. More... | |
const QString & | getSMName () |
Get the name with which this proxy is registered on the server manager. More... | |
const QString & | getSMGroup () |
vtkSMProxy * | getProxy () const |
Get the vtkSMProxy this object stands for. More... | |
ModifiedState | modifiedState () const |
Gets whether or not the source has been modified. More... | |
void | setModifiedState (ModifiedState modified) |
Sets whether or not the source has been modified. More... | |
vtkPVXMLElement * | getHints () const |
Returns the hints for this proxy, if any. More... | |
QList< vtkSMProxy * > | getHelperProxies () const |
Returns a list of all helper proxies. More... | |
QList< vtkSMProxy * > | getHelperProxies (const QString &key) const |
Returns a list of all the helper proxies added with a given key. More... | |
QList< QString > | getHelperKeys () const |
Returns the keys for helper proxies. More... | |
virtual void | addHelperProxy (const QString &key, vtkSMProxy *) |
Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More... | |
void | removeHelperProxy (const QString &key, vtkSMProxy *) |
void | updateHelperProxies () const |
Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More... | |
vtkSMSessionProxyManager * | proxyManager () const |
Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More... | |
bool | userModifiedSMName () |
Return whether or not the user has modified the GUI name of the source. More... | |
pqServerManagerModelItem (QObject *parent=nullptr) | |
~pqServerManagerModelItem () override | |
void | initializeCue (vtkSMProxy *proxy, const char *propertyname, int index, pqAnimationCue *cue) |
Initializes the newly create animation cue with default keyframes. More... | |
void | setSMName (const QString &new_name) |
Make this pqProxy take on a new identity. More... | |
virtual void | initialize () |
virtual void | addInternalHelperProxy (const QString &key, vtkSMProxy *) const |
virtual void | removeInternalHelperProxy (const QString &key, vtkSMProxy *) const |
vtkEventQtSlotConnect * | getConnector () |
All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More... | |
enum | ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED } |
The modification state of this proxy. More... | |
static pqProxy * | findProxyWithHelper (vtkSMProxy *aproxy, QString &key) |
Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More... | |
static std::string | rstToHtml (const char *rstStr) |
convert proxy documentation from RST to HTML (so that it can be used in Qt) More... | |
static QString | rstToHtml (const QString &rstStr) |
void | onProxyRegistered (const QString &, const QString &, vtkSMProxy *) |
void | onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *) |
It provides API to access AnimationCues in the scene and to the scene times.
Definition at line 21 of file pqAnimationScene.h.
pqAnimationScene::pqAnimationScene | ( | const QString & | group, |
const QString & | name, | ||
vtkSMProxy * | proxy, | ||
pqServer * | server, | ||
QObject * | parent = nullptr |
pqAnimationCue* pqAnimationScene::getCue | ( | vtkSMProxy * | proxy, |
const char * | propertyname, | ||
int | index | ||
) | const |
on the given proxy
pqAnimationCue* pqAnimationScene::createCue | ( | vtkSMProxy * | proxy, |
int | index | ||
of the property
on the given proxy
in this scene.
This method does not check is such a cue already exists, use getCue() before calling this to avoid duplicates.
int | index, | ||
const QString & | cuetype | ||
of the property
on the given proxy
in this scene.
pqAnimationCue* pqAnimationScene::createCue | ( | const QString & | cuetype | ) |
of the property
on the given proxy
in this scene.
pqAnimationCue* pqAnimationScene::createCue | ( | const pqAnimatedPropertyInfo & | propInfo | ) |
of the property
on the given proxy
in this scene.
void pqAnimationScene::removeCues | ( | vtkSMProxy * | proxy | ) |
void pqAnimationScene::removeCue | ( | pqAnimationCue * | cue | ) |
Removes cue.
bool pqAnimationScene::contains | ( | pqAnimationCue * | ) | const |
QSet<pqAnimationCue*> pqAnimationScene::getCues | ( | ) | const |
double pqAnimationScene::getAnimationTime | ( | ) | const |
QList<double> pqAnimationScene::getTimeSteps | ( | ) | const |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
reversed
is a pointer to boolean that indicates if the playback direction is backward
signal |
reversed
signal |
Argument is the percent of play completed.
signal |
time
is the animation clock time.
signal |
signal |
signal |
slot |
Play animation.
slot |
Pause animation.
slot |
