Public Types | Public Slots | Signals | Public Member Functions | Protected Slots | Properties | List of all members
pqAnimationTimeWidget Class Reference
pqAnimationTimeWidget is a widget that can be used to show/set the current animation time. More...
#include <pqAnimationTimeWidget.h>
Inherits QWidget.
using RealNumberNotation = pqDoubleLineEdit::RealNumberNotation
Public Slots
void render ()
 Re render the widget. More...
Signals
void playModeChanged ()
void dummySignal ()
 pqAnimationTimeWidget (QWidget *parent=nullptr)
 ~pqAnimationTimeWidget () override
vtkSMProxyanimationScene () const
 Provides access to the animation scene proxy currently controlled/reflected by this widget. More...
void setAnimationScene (pqAnimationScene *animationScene)
 Set the animation scene which is reflected/controlled by this widget. More...
void setCurrentTime (double t)
 Set the current animation time. More...
RealNumberNotation notation () const
 Return the notation used to display the number. More...
int precision () const
 Return the precision used to display the number. More...
void setTimestepValues (const QList< QVariant > &list)
 Get/Set the list of timestep. More...
const QList< QVariant > & timestepValues () const
void setStartTime (double start)
 Get/Set the animation start time. More...
double startTime () const
void setEndTime (double end)
 Get/Set the animation end time. More...
double endTime () const
void setNumberOfFrames (int nbOfFrame)
 Get/Set the number of frames. More...
int numberOfFrames () const
void setPlayMode (const QString &mode)
 Get/set the animation playback mode. More...
QString playMode () const
void setTimeLabel (const QString &val)
 Get/set the label text to use for the "time" parameter. More...
QString timeLabel () const
Protected Slots
void updateCurrentTime (double t)
 Update the current time in the widget GUI. More...
Properties
QString playMode
int numberOfFrames
double startTime
double endTime
QString timeLabel
QList< QVariant > timestepValues
The widget allow the user to do the following:
Definition at line 26 of file pqAnimationTimeWidget.h.
◆ RealNumberNotation
Definition at line 42 of file pqAnimationTimeWidget.h.
◆ pqAnimationTimeWidget()
pqAnimationTimeWidget::pqAnimationTimeWidget ( QWidget *  parent = nullptr)
◆ ~pqAnimationTimeWidget()
pqAnimationTimeWidget::~pqAnimationTimeWidget ( )
override
◆ animationScene()
vtkSMProxy* pqAnimationTimeWidget::animationScene ( ) const
◆ setAnimationScene()
void pqAnimationTimeWidget::setAnimationScene ( pqAnimationScene animationScene)
◆ setTimestepValues()
void pqAnimationTimeWidget::setTimestepValues ( const QList< QVariant > &  list)
QList<QVariant> is a list of variants convertible to double.
◆ timestepValues()
const QList<QVariant>& pqAnimationTimeWidget::timestepValues ( ) const
◆ setStartTime()
void pqAnimationTimeWidget::setStartTime ( double  start)
◆ startTime()
double pqAnimationTimeWidget::startTime ( ) const
◆ setEndTime()
void pqAnimationTimeWidget::setEndTime ( double  end)
◆ endTime()
double pqAnimationTimeWidget::endTime ( ) const
◆ setNumberOfFrames()
void pqAnimationTimeWidget::setNumberOfFrames ( int  nbOfFrame)
◆ numberOfFrames()
int pqAnimationTimeWidget::numberOfFrames ( ) const
◆ setCurrentTime()
void pqAnimationTimeWidget::setCurrentTime ( double  t)
◆ notation()
RealNumberNotation pqAnimationTimeWidget::notation ( ) const
See also
setNotation()
◆ precision()
int pqAnimationTimeWidget::precision ( ) const
See also
setPrecision()
◆ setPlayMode()
void pqAnimationTimeWidget::setPlayMode ( const QString &  mode)
◆ playMode()
QString pqAnimationTimeWidget::playMode ( ) const
◆ setTimeLabel()
void pqAnimationTimeWidget::setTimeLabel ( const QString &  val)
◆ timeLabel()
QString pqAnimationTimeWidget::timeLabel ( ) const
◆ playModeChanged
void pqAnimationTimeWidget::playModeChanged ( )
signal
◆ dummySignal
void pqAnimationTimeWidget::dummySignal ( )
signal
◆ render
void pqAnimationTimeWidget::render ( )
slot
This can be helpful when notation/precision settings have changed.
◆ updateCurrentTime
void pqAnimationTimeWidget::updateCurrentTime ( double  t)
protectedslot
Property Documentation
◆ playMode
readwrite
Definition at line 30 of file pqAnimationTimeWidget.h.
◆ numberOfFrames
readwrite
Definition at line 31 of file pqAnimationTimeWidget.h.
◆ startTime
readwrite
Definition at line 32 of file pqAnimationTimeWidget.h.
◆ endTime
readwrite
Definition at line 33 of file pqAnimationTimeWidget.h.
◆ timeLabel
readwrite
Definition at line 34 of file pqAnimationTimeWidget.h.
◆ timestepValues
QList<QVariant> pqAnimationTimeWidget::timestepValues
readwrite
Definition at line 35 of file pqAnimationTimeWidget.h.
