Public Slots | Signals | Public Member Functions | List of all members
pqCollaborationManager Class Reference
pqCollaborationManager is a QObject that aims to handle the collaboration for the Qt layer. More...
#include <pqCollaborationManager.h>
Inherits QObject.
Public Slots
void onServerAdded (pqServer *)
 Slot used to keep track of all possible vtkSMCollaborationManagers They are used in pqCollaborationBehavior to listen to the ServerManagerModel... More...
void onServerRemoved (pqServer *)
void onChatMessage (pqServer *server, int userId, QString &msgContent)
 This will be triggered by the triggerChatMessage() signal and will broadcast to other client a chat message. More...
void updateEnabledState ()
 updates the enabled-state for application wide widgets and actions based whether the application is a master or not. More...
void updateMousePointerLocation (QMouseEvent *e)
 Method called localy when user want to broadcast its pointer to other users. More...
void sendMousePointerLocationToOtherClients ()
 Method triggered by the internal collaboration Timer. More...
void sendChartViewBoundsToOtherClients ()
void attachMouseListenerTo3DViews ()
 Attach a mouse listener if its a 3D view so we can share that information with other clients. More...
void enableMousePointerSharing (bool)
 Enable/disable local mouse pointer location. More...
void disableFurtherConnections (bool disable)
 Enable/disable further connections to the server. More...
void setConnectID (int connectID)
 Set the connect-id. More...
Signals
void triggerChatMessage (pqServer *server, int userId, QString &msgContent)
 This will be triggered by the remote clients to update any interesting components. More...
void triggerStateClientOnlyMessage (pqServer *origin, vtkSMMessage *msg)
 This will forward client_only message to anyone that may interessted when not managed locally. More...
void triggeredMasterUser (int)
 Signal triggered when user information get updated regardless the active one A nice thing TODO could be to just forward from the pqServer but ONLY IF (activeServer == sender) More...
void triggeredMasterChanged (bool)
void triggeredUserName (int, QString &)
void triggeredUserListChanged ()
void triggerFollowCamera (int)
 This will be triggered when a remote master client has requested the other users to follow a given camera. More...
 pqCollaborationManager (QObject *parent)
 ~pqCollaborationManager () override
vtkSMCollaborationManageractiveCollaborationManager ()
 Return the vtkSMCollaborationManager. More...
This class is used to synchronize the ActiveObject across client instances as well as managing the rendering request when data has been changed by other clients. This class is responsible to synchronize
Definition at line 30 of file pqCollaborationManager.h.
◆ pqCollaborationManager()
pqCollaborationManager::pqCollaborationManager ( QObject *  parent)
◆ ~pqCollaborationManager()
pqCollaborationManager::~pqCollaborationManager ( )
override
◆ activeCollaborationManager()
vtkSMCollaborationManager* pqCollaborationManager::activeCollaborationManager ( )
◆ triggerChatMessage
void pqCollaborationManager::triggerChatMessage ( pqServer server,
int  userId,
QString &  msgContent
signal
This should be triggered by local client to broadcast to the other clients
◆ triggerStateClientOnlyMessage
void pqCollaborationManager::triggerStateClientOnlyMessage ( pqServer origin,
vtkSMMessage msg
signal
◆ triggeredMasterUser
void pqCollaborationManager::triggeredMasterUser ( int  )
signal
◆ triggeredMasterChanged
void pqCollaborationManager::triggeredMasterChanged ( bool  )
signal
◆ triggeredUserName
void pqCollaborationManager::triggeredUserName ( int  ,
QString &
signal
◆ triggeredUserListChanged
void pqCollaborationManager::triggeredUserListChanged ( )
signal
◆ triggerFollowCamera
void pqCollaborationManager::triggerFollowCamera ( int  )
signal
◆ onServerAdded
void pqCollaborationManager::onServerAdded ( pqServer )
slot
(preServerAdded/aboutToRemoveServer)
◆ onServerRemoved
void pqCollaborationManager::onServerRemoved ( pqServer )
slot
◆ onChatMessage
void pqCollaborationManager::onChatMessage ( pqServer server,
int  userId,
slot
◆ updateEnabledState
void pqCollaborationManager::updateEnabledState ( )
slot
Widget/Actions need to set a dynamic property named PV_MUST_BE_MASTER or PV_MUST_BE_MASTER_TO_SHOW. Only the state for widgets/actions with these any of properties will be updated by this method.
◆ updateMousePointerLocation
void pqCollaborationManager::updateMousePointerLocation ( QMouseEvent *  e)
slot
◆ sendMousePointerLocationToOtherClients
void pqCollaborationManager::sendMousePointerLocationToOtherClients ( )
slot
This timer prevent a network overload by only sending the latest mouse location to the other clients every 100 ms
◆ sendChartViewBoundsToOtherClients
void pqCollaborationManager::sendChartViewBoundsToOtherClients ( )
slot
This timer prevent a network overload by only sending the latest modified view location to the other clients every 100 ms
◆ attachMouseListenerTo3DViews
void pqCollaborationManager::attachMouseListenerTo3DViews ( )
slot
◆ enableMousePointerSharing
void pqCollaborationManager::enableMousePointerSharing ( bool  )
slot
◆ disableFurtherConnections
void pqCollaborationManager::disableFurtherConnections ( bool  disable)
slot
◆ setConnectID
void pqCollaborationManager::setConnectID ( int  connectID)
slot
Set the connect-id.
