pqInputDataTypeDecorator is a pqPropertyWidgetDecorator subclass. More...
#include <pqInputDataTypeDecorator.h>
pqInputDataTypeDecorator (vtkPVXMLElement *config, pqPropertyWidget *parent) | |
~pqInputDataTypeDecorator () override | |
bool | enableWidget () const override |
Overridden to enable/disable the widget based on input data type. More... | |
bool | canShowWidget (bool show_advanced) const override |
Overriden to show or not the widget based on input data type. More... | |
pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent) | |
Constructor. More... | |
~pqPropertyWidgetDecorator () override | |
pqPropertyWidget * | parentWidget () const |
Returns the pqPropertyWidget parent. More... | |
virtual bool | processState () const |
vtkPVXMLElement * | xml () const |
void | visibilityChanged () |
This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More... | |
void | enableStateChanged () |
static pqPropertyWidgetDecorator * | create (vtkPVXMLElement *xml, pqPropertyWidget *parent) |
Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More... | |
For certain properties, they should update the enable state based on input data types. For example, "Computer Gradients" in Contour filter should only be enabled when an input data type is a StructuredData. Please see vtkPVDataInformation::IsDataStructured() for structured types.
Definition at line 21 of file pqInputDataTypeDecorator.h.
pqInputDataTypeDecorator::pqInputDataTypeDecorator | ( | vtkPVXMLElement * | config, |
pqPropertyWidget * | parent | ||
Reimplemented from pqPropertyWidgetDecorator.
protectedvirtual |
