pqOpenVRHidingDecorator's purpose is to prevent the GUI from showing any of the OpenVR specific rendering controls when Paraview is not configured with PARAVIEW_USE_OpenVR More...
#include <pqOpenVRHidingDecorator.h>
pqOpenVRHidingDecorator (vtkPVXMLElement *config, pqPropertyWidget *parentObject) | |
~pqOpenVRHidingDecorator () override | |
bool | canShowWidget (bool show_advanced) const override |
Overridden to hide the widget when OpenVR is not compiled in. More... | |
pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent) | |
Constructor. More... | |
~pqPropertyWidgetDecorator () override | |
pqPropertyWidget * | parentWidget () const |
Returns the pqPropertyWidget parent. More... | |
virtual bool | enableWidget () const |
Override this method to override the enable state of the widget in the panel. More... | |
void | visibilityChanged () |
This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More... | |
void | enableStateChanged () |
static pqPropertyWidgetDecorator * | create (vtkPVXMLElement *xml, pqPropertyWidget *parent) |
Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More... | |
vtkPVXMLElement * | xml () const |
Definition at line 12 of file pqOpenVRHidingDecorator.h.
pqOpenVRHidingDecorator::pqOpenVRHidingDecorator | ( | vtkPVXMLElement * | config, |
pqPropertyWidget * | parentObject | ||
Reimplemented from pqPropertyWidgetDecorator.
