Public Slots | Signals | Public Member Functions | List of all members
pqProxiesWidget Class Reference
pqProxiesWidget similar to pqProxyWidget with the difference being that unlike pqProxyWidget, pqProxiesWidget supports showing of multiple proxies in the same widget. More...
#include <pqProxiesWidget.h>
Inherits QWidget.
Public Slots
void clear ()
 Remove all proxy widgets added to the panel. More...
void addProxy (vtkSMProxy *, const QString &componentName=QString(), const QStringList &properties=QStringList(), bool applyChangesImmediately=false, bool showHeadersFooters=true)
 Add the widgets for a proxy. More...
void updateLayout ()
 Call this method once after all proxies have been added (or after clear) to update the layout for the panel. More...
bool filterWidgets (bool show_advanced=false, const QString &filterText=QString())
 Updates the property widgets shown based on the filterText or show_advanced flag. More...
void apply () const
 Accepts the property widget changes changes. More...
void reset () const
 Cleans the property widget changes and resets the widgets. More...
void setView (pqView *)
 Set the current view to use to show 3D widgets, if any for the panel. More...
void updatePanel ()
 Same as calling filterWidgets() with the arguments specified to the most recent call to filterWidgets(). More...
Signals
void changeAvailable (vtkSMProxy *proxy)
void changeFinished (vtkSMProxy *proxy)
void restartRequired (vtkSMProxy *proxy)
 pqProxiesWidget (QWidget *parent=nullptr, Qt::WindowFlags flags=Qt::WindowFlags{})
 ~pqProxiesWidget () override
QMap< QString, bool > expanderState () const
 Returns a map indicating which expand buttons are expanded and which ones aren't. More...
void setExpanderState (const QMap< QString, bool > &state)
 Set the expander state. More...
Internally, it indeed creates a pqProxyWidget for each of the added proxies.
To use this class, add all proxies to show in this panel using addProxy() and then call updateLayout() to update the layout.
pqProxiesWidget supports grouping of proxies in components (separated by using a pqExpanderButton). To use pqExpanderButton simply use a non-empty componentName when calling addProxy().
pqProxiesWidget provides API such as filterWidgets(), apply(), etc. the calls to which are simply forwarded to the internal pqProxyWidget instances. Similarly, pqProxiesWidget also forwards signals fired by pqProxyWidget such as changeFinished(), changeAvailable(), and restartRequired().
Definition at line 33 of file pqProxiesWidget.h.
◆ pqProxiesWidget()
pqProxiesWidget::pqProxiesWidget ( QWidget *  parent = nullptr,
Qt::WindowFlags  flags = Qt::WindowFlags{}
◆ ~pqProxiesWidget()
pqProxiesWidget::~pqProxiesWidget ( )
override
◆ expanderState()
QMap<QString, bool> pqProxiesWidget::expanderState ( ) const
Useful to save and then restore the state when resetting the panel. The key is the text used for componentName argument to addProxy call. The value is true for expanded, false otherwise.
◆ setExpanderState()
void pqProxiesWidget::setExpanderState ( const QMap< QString, bool > &  state)
If any key is unrecognized, it will be silently ignored. State for expanders not referred to in the state is left unchanged.
◆ clear
void pqProxiesWidget::clear ( )
slot
◆ addProxy
void pqProxiesWidget::addProxy ( vtkSMProxy ,
const QString &  componentName = QString(),
const QStringList &  properties = QStringList(),
bool  applyChangesImmediately = false,
bool  showHeadersFooters = true
slot
◆ updateLayout
void pqProxiesWidget::updateLayout ( )
slot
◆ filterWidgets
bool pqProxiesWidget::filterWidgets ( bool  show_advanced = false,
const QString &  filterText = QString()
slot
Calling filterWidgets() without any arguments will result in the panel showing all the non-advanced properties. Returns true, if any widgets were shown.
◆ apply
void pqProxiesWidget::apply ( ) const
slot
◆ reset
void pqProxiesWidget::reset ( ) const
slot
◆ setView
void pqProxiesWidget::setView ( pqView )
slot
◆ updatePanel
void pqProxiesWidget::updatePanel ( )
slot
◆ changeAvailable
void pqProxiesWidget::changeAvailable ( vtkSMProxy proxy)
signal
The editing may not be complete.
◆ changeFinished
void pqProxiesWidget::changeFinished ( vtkSMProxy proxy)
signal
changeAvailable() is always fired before changeFinished().
◆ restartRequired
void pqProxiesWidget::restartRequired ( vtkSMProxy proxy)
signal
