decorator to show/hide or enable/disable property widget based on the session. More...
#include <pqSessionTypeDecorator.h>
pqSessionTypeDecorator (vtkPVXMLElement *config, pqPropertyWidget *parent) | |
~pqSessionTypeDecorator () override | |
bool | canShowWidget (bool show_advanced) const override |
Methods overridden from pqPropertyWidget. More... | |
bool | enableWidget () const override |
pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent) | |
Constructor. More... | |
~pqPropertyWidgetDecorator () override | |
pqPropertyWidget * | parentWidget () const |
Returns the pqPropertyWidget parent. More... | |
void | visibilityChanged () |
This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More... | |
void | enableStateChanged () |
static pqPropertyWidgetDecorator * | create (vtkPVXMLElement *xml, pqPropertyWidget *parent) |
Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More... | |
vtkPVXMLElement * | xml () const |
pqSessionTypeDecorator is a pqPropertyWidgetDecorator subclass that can be used to show/hide or enable/disable a pqPropertyWidget based on the current session.
The XML config for this decorate takes two attributes 'requires' and 'mode'. 'mode' can have values 'visibility' or 'enabled_state' which dictates whether the decorator shows/hides or enables/disables the widget respectively.
'requires' can have values 'remote', 'parallel', 'parallel_data_server', or 'parallel_render_server' indicating if the session must be remote, or parallel with either data server or render server having more than 1 rank, or parallel data-server, or parallel render-server respectively.
Definition at line 29 of file pqSessionTypeDecorator.h.
pqSessionTypeDecorator::pqSessionTypeDecorator | ( | vtkPVXMLElement * | config, |
pqPropertyWidget * | parent | ||
Reimplemented from pqPropertyWidgetDecorator.
