IceT enabled render pass for distributed rendering. More...
#include <vtkIceTCompositePass.h>
typedef vtkRenderPass | Superclass |
void | Render (const vtkRenderState *s) override |
Perform rendering according to a render state s . More... | |
void | ReleaseGraphicsResources (vtkWindow *w) override |
Release graphics resources and ask components to release their own resources. More... | |
void | GetLastRenderedTile (vtkSynchronizedRenderers::vtkRawImage &tile) |
Returns the last rendered tile from this process, if any. More... | |
vtkFloatArray * | GetLastRenderedDepths () |
Provides access to the last rendered depth-buffer, if any. More... | |
vtkFloatArray * | GetLastRenderedRGBA32F () |
Provides access to the last rendered float image in vtkValuePass, if any. More... | |
void | PushIceTDepthBufferToScreen (const vtkRenderState *render_state) |
Obtains the composited depth-buffer from IceT and pushes it to the screen. More... | |
virtual vtkMultiProcessController * | GetController () |
Controller If it is nullptr, nothing will be rendered and a warning will be emitted. More... | |
virtual void | SetController (vtkMultiProcessController *controller) |
void | SetRenderPass (vtkRenderPass *) |
Get/Set the render pass used to do the actual rendering. More... | |
virtual vtkRenderPass * | GetRenderPass () |
virtual void | SetTileDimensions (int, int) |
Get/Set the tile dimensions. More... | |
void | SetTileDimensions (int [2]) |
virtual int * | GetTileDimensions () |
virtual void | GetTileDimensions (int &, int &) |
virtual void | GetTileDimensions (int [2]) |
virtual void | SetTileMullions (int, int) |
Get/Set the tile mullions. More... | |
void | SetTileMullions (int [2]) |
virtual int * | GetTileMullions () |
virtual void | GetTileMullions (int &, int &) |
virtual void | GetTileMullions (int [2]) |
virtual void | SetDataReplicatedOnAllProcesses (bool) |
Set to true if data is replicated on all processes. More... | |
virtual bool | GetDataReplicatedOnAllProcesses () |
virtual void | DataReplicatedOnAllProcessesOn () |
virtual void | DataReplicatedOnAllProcessesOff () |
virtual void | SetImageReductionFactor (int) |
Set the image reduction factor. More... | |
virtual int | GetImageReductionFactor () |
virtual vtkOrderedCompositingHelper * | GetOrderedCompositingHelper () |
partition ordering that gives processes ordering. More... | |
virtual void | SetOrderedCompositingHelper (vtkOrderedCompositingHelper *helper) |
virtual bool | GetRenderEmptyImages () |
Enable/disable rendering of empty images. More... | |
virtual void | SetRenderEmptyImages (bool) |
virtual void | RenderEmptyImagesOn () |
virtual void | RenderEmptyImagesOff () |
virtual bool | GetUseOrderedCompositing () |
Set this to true, if compositing must be done in a specific order. More... | |
virtual void | SetUseOrderedCompositing (bool) |
virtual void | UseOrderedCompositingOn () |
virtual void | UseOrderedCompositingOff () |
virtual void | SetEnableFloatValuePass (bool) |
Adjusts this pass to handle vtkValuePass::FLOATING_POINT, in which floating- point values are rendered to vtkValuePass's internal FBO. More... | |
virtual void | SetDisplayRGBAResults (bool) |
When set to true, vtkIceTCompositePass will push back compositing results to the display on ranks where the IceT generated a composited result. More... | |
virtual bool | GetDisplayRGBAResults () |
virtual void | SetDisplayDepthResults (bool) |
virtual bool | GetDisplayDepthResults () |
void | Draw (const vtkRenderState *render_state, const IceTDrawParams &) |
vtkRenderPass * | NewInstance () const |
virtual int | GetNumberOfRenderedProps () |
virtual void | Modified () |
static vtkIceTCompositePass * | New () |
static vtkIceTCompositePass * | SafeDownCast (vtkObject *o) |
static vtkRenderPass * | SafeDownCast (vtkObjectBase *o) |
static vtkObject * | New () |
vtkIceTCompositePass () | |
~vtkIceTCompositePass () override | |
void | ReadyProgram (vtkOpenGLRenderWindow *context) |
Create program (if needed) and prepare it for texture mapping. More... | |
void | UpdateTileInformation (const vtkRenderState *) |
Updates the IceT tile information during each render. More... | |
void | DisplayResultsIfNeeded (const vtkRenderState *) |
Called after Icet results have been generated. More... | |
void | UpdateMatrices (const vtkRenderState *, double aspect) |
Update projection and model view matrices using current camera and provided aspect ratio. More... | |
virtual void | SetupContext (const vtkRenderState *) |
Spits the different components for the rendering process. More... | |
virtual void | CleanupContext (const vtkRenderState *) |
virtual vtkObjectBase * | NewInstanceInternal () const |
vtkRenderPass () | |
virtual | ~vtkRenderPass () |
void | UpdateCamera (vtkRenderer *renderer) |
void | ClearLights (vtkRenderer *renderer) |
void | UpdateLightGeometry (vtkRenderer *renderer) |
void | UpdateLights (vtkRenderer *renderer) |
void | UpdateGeometry (vtkRenderer *renderer) |
void | SetLastRenderingUsedDepthPeeling (vtkRenderer *renderer, bool value) |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkMultiProcessController * | Controller |
vtkOrderedCompositingHelper * | OrderedCompositingHelper |
vtkRenderPass * | RenderPass |
vtkIceTContext * | IceTContext |
bool | RenderEmptyImages |
bool | UseOrderedCompositing |
bool | DataReplicatedOnAllProcesses |
bool | EnableFloatValuePass |
int | TileDimensions [2] |
int | TileMullions [2] |
int | ImageReductionFactor |
bool | DisplayRGBAResults |
bool | DisplayDepthResults |
vtkNew< vtkFloatArray > | LastRenderedDepths |
vtkNew< vtkFloatArray > | LastRenderedRGBA32F |
vtkPixelBufferObject * | PBO |
vtkTextureObject * | ZTexture |
vtkOpenGLHelper * | Program |
std::unique_ptr< vtkSynchronizedRenderers::vtkRawImage > | LastRenderedRGBAColors |
int | NumberOfRenderedProps |
bool | Debug |
vtkTimeStamp | MTime |
vtkIceTCompositePass is a vtkRenderPass subclass that can be used for compositing images (RGBA_UBYTE, depth or RGBA_32F) across processes using IceT. This can be used in lieu of vtkCompositeRGBAPass. The usage of this pass differs slightly from vtkCompositeRGBAPass. vtkCompositeRGBAPass composites the active frame buffer, while this class requires that the render pass to render info the frame buffer that needs to be composited should be set as an ivar using SetRenderPass().
This class also provides support for tile-displays. Simply set the TileDimensions > [1, 1] and instead of rendering a composited image on the root node, it will split the view among all tiles and generate renderings on all processes.
Warning: Compositing RGBA_32F is only supported for a specific pass (vtkValuePass). For a more generic integration, vtkRenderPass should expose an internal FBO API.
Definition at line 46 of file vtkIceTCompositePass.h.
Definition at line 50 of file vtkIceTCompositePass.h.
Reimplemented from vtkRenderPass.
Implements vtkRenderPass.
Initial value is a nullptr pointer.
void vtkIceTCompositePass::SetRenderPass | ( | vtkRenderPass * | ) |
The result of this delete pass is what gets composited using IceT. Initial value is a nullptr pointer.
Default is (1, 1). If any of the dimensions is
1 than tile display mode is assumed.
void vtkIceTCompositePass::SetTileDimensions | ( | int | [2] | ) |
The mullions are measured in pixels. Use negative numbers for overlap. Initial value is {0,0}.
void vtkIceTCompositePass::SetTileMullions | ( | int | [2] | ) |
This will enable IceT to minimize communications since data is available on all process. Off by default. Initial value is false.
This can be used to speed up compositing. When using vtkIceTCompositePass use this image reduction factor rather than that on vtkSynchronizedRenderers since using vtkSynchronizedRenderers::ImageReductionFactor will not work correctly with IceT. Initial value is 1.
Initial value is a nullptr pointer. This is used only when UseOrderedCompositing is true.
Painters that use MPI global collective communication need to enable this. Initial value is false.
This is necessary when rendering volumes or translucent geometries. When UseOrderedCompositing is set to true, it is expected that the OrderedCompositingHelper is set as well. OrderedCompositingHelper is used to decide the process-order for compositing. Initial value is false.
void vtkIceTCompositePass::GetLastRenderedTile | ( | vtkSynchronizedRenderers::vtkRawImage & | tile | ) |
Image is invalid if tile is not available on the current process.
vtkFloatArray* vtkIceTCompositePass::GetLastRenderedDepths | ( | ) |
May return nullptr if depth buffer was not composited and available on the current rank.
vtkFloatArray* vtkIceTCompositePass::GetLastRenderedRGBA32F | ( | ) |
May return nullptr if a float image was not composited and is not available on the current rank.
void vtkIceTCompositePass::PushIceTDepthBufferToScreen | ( | const vtkRenderState * | render_state | ) |
This is only done when DepthOnly is true.
Generally speaking, for a vtkRenderPass, this must always be true
. However, for ParaView use cases many times we display the compositing result on the server-side. In which case, we can save on the extra work to push results to screen. Hence, vtkIceTCompositePass sets this to false by default.
void vtkIceTCompositePass::Draw | ( | const vtkRenderState * | render_state, |
const IceTDrawParams & | |||
protectedvirtual |
protectedvirtual |
vtkIceTCompositePass will paste back the IceT results image to the viewport if so requested by DisplayDepthResults and DisplayRGBAResults flags.
Definition at line 257 of file vtkIceTCompositePass.h.
Definition at line 258 of file vtkIceTCompositePass.h.
Definition at line 259 of file vtkIceTCompositePass.h.
Definition at line 260 of file vtkIceTCompositePass.h.
Definition at line 262 of file vtkIceTCompositePass.h.
Definition at line 263 of file vtkIceTCompositePass.h.
Definition at line 264 of file vtkIceTCompositePass.h.
Definition at line 265 of file vtkIceTCompositePass.h.
Definition at line 266 of file vtkIceTCompositePass.h.
Definition at line 267 of file vtkIceTCompositePass.h.
Definition at line 269 of file vtkIceTCompositePass.h.
Definition at line 271 of file vtkIceTCompositePass.h.
Definition at line 272 of file vtkIceTCompositePass.h.
Definition at line 274 of file vtkIceTCompositePass.h.
Definition at line 276 of file vtkIceTCompositePass.h.
Definition at line 278 of file vtkIceTCompositePass.h.
Definition at line 279 of file vtkIceTCompositePass.h.
Definition at line 280 of file vtkIceTCompositePass.h.
Definition at line 282 of file vtkIceTCompositePass.h.
