vtkSynchronizedRenderers subclass that uses IceT for parallel rendering and compositing. More...
#include <vtkIceTSynchronizedRenderers.h>
typedef vtkSynchronizedRenderers | Superclass |
void | SetRenderer (vtkRenderer *) override |
Set the renderer to be synchronized by this instance. More... | |
void | SetTileDimensions (int x, int y) |
Set the tile dimensions. More... | |
void | SetTileMullions (int x, int y) |
Set the tile mullions. More... | |
void | SetDataReplicatedOnAllProcesses (bool val) |
Set to true if data is replicated on all processes. More... | |
void | SetOrderedCompositingHelper (vtkOrderedCompositingHelper *helper) |
partition ordering that gives processes ordering. More... | |
void | SetUseOrderedCompositing (bool uoc) |
Set this to true, if compositing must be done in a specific order. More... | |
void | SetImageReductionFactor (int val) override |
Set the image reduction factor. More... | |
int | GetImageReductionFactor () override |
void | SetUseDepthBuffer (bool) |
Activates or de-activated the use of Depth Buffer. More... | |
void | SetRenderEmptyImages (bool) |
Enable/Disable empty images optimization. More... | |
void | SetParallelController (vtkMultiProcessController *cont) override |
Set the parallel message communicator. More... | |
void | SetImageProcessingPass (vtkImageProcessingPass *) |
Get/Set an image processing pass to process the rendered images. More... | |
virtual vtkImageProcessingPass * | GetImageProcessingPass () |
void | SetRenderPass (vtkRenderPass *) |
Get/Set geometry rendering pass. More... | |
virtual vtkRenderPass * | GetRenderPass () |
virtual vtkIceTCompositePass * | GetIceTCompositePass () |
Provides access to the internal vtkIceTCompositePass. More... | |
vtkSynchronizedRenderers * | NewInstance () const |
void | CollectiveExpandForVisiblePropBounds (double bounds[6]) |
virtual vtkRenderer * | GetRenderer () |
virtual vtkMultiProcessController * | GetParallelController () |
virtual void | SetParallelRendering (bool) |
virtual bool | GetParallelRendering () |
virtual void | ParallelRenderingOn () |
virtual void | ParallelRenderingOff () |
virtual void | SetWriteBackImages (bool) |
virtual bool | GetWriteBackImages () |
virtual void | WriteBackImagesOn () |
virtual void | WriteBackImagesOff () |
virtual void | SetRootProcessId (int) |
virtual int | GetRootProcessId () |
virtual void | SetCaptureDelegate (vtkSynchronizedRenderers *) |
virtual vtkSynchronizedRenderers * | GetCaptureDelegate () |
virtual void | SetAutomaticEventHandling (bool) |
virtual bool | GetAutomaticEventHandling () |
virtual void | AutomaticEventHandlingOn () |
virtual void | AutomaticEventHandlingOff () |
virtual void | Modified () |
static vtkIceTSynchronizedRenderers * | New () |
static vtkIceTSynchronizedRenderers * | SafeDownCast (vtkObject *o) |
static vtkSynchronizedRenderers * | New () |
static vtkSynchronizedRenderers * | SafeDownCast (vtkObjectBase *o) |
static vtkObject * | New () |
vtkIceTSynchronizedRenderers () | |
~vtkIceTSynchronizedRenderers () override | |
vtkRawImage & | CaptureRenderedImage () override |
Overridden to capture image from icet buffers instead of the screen. More... | |
virtual vtkObjectBase * | NewInstanceInternal () const |
vtkSynchronizedRenderers () | |
~vtkSynchronizedRenderers () | |
virtual void | HandleStartRender () |
virtual void | HandleEndRender () |
virtual void | HandleAbortRender () |
virtual void | MasterStartRender () |
virtual void | SlaveStartRender () |
virtual void | MasterEndRender () |
virtual void | SlaveEndRender () |
virtual void | PushImageToScreen () |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkCameraPass * | CameraRenderPass |
vtkIceTCompositePass * | IceTCompositePass |
vtkRenderPass * | RenderPass |
vtkImageProcessingPass * | ImageProcessingPass |
vtkMultiProcessController * | ParallelController |
vtkOpenGLRenderer * | Renderer |
vtkSynchronizedRenderers * | CaptureDelegate |
vtkRawImage | ReducedImage |
vtkRawImage | FullImage |
bool | ParallelRendering |
int | ImageReductionFactor |
bool | WriteBackImages |
int | RootProcessId |
bool | AutomaticEventHandling |
bool | Debug |
vtkTimeStamp | MTime |
SYNC_RENDERER_TAG | |
RESET_CAMERA_TAG | |
COMPUTE_BOUNDS_TAG | |
vtkIceTSynchronizedRenderers uses IceT (the Image Compositing Engine for Tiles) for parallel rendering and compositing. This class simply uses vtkIceTCompositePass internally, even though this class is designed to be used with traditional renderers and not those using render-passes. Note that this class internally does indeed leverage the RenderPass mechanism to intercept render calls from a vtkRenderer. In other words, if you are using render passes, you should not use this class. Your render passes will be overridden.
Definition at line 29 of file vtkIceTSynchronizedRenderers.h.
Definition at line 33 of file vtkIceTSynchronizedRenderers.h.
Reimplemented from vtkSynchronizedRenderers.
A vtkSynchronizedRenderers instance can be used to synchronize exactly 1 renderer on each processes. You can create multiple instances on vtkSynchronizedRenderers to synchronize multiple renderers.
Default is (1, 1). If any of the dimensions is > 1 then tile display mode is assumed.
Definition at line 48 of file vtkIceTSynchronizedRenderers.h.
The mullions are measured in pixels. Use negative numbers for overlap.
Definition at line 54 of file vtkIceTSynchronizedRenderers.h.
This will enable IceT to minimize communications since data is available on all process. Off by default.
Definition at line 61 of file vtkIceTSynchronizedRenderers.h.
Initial value is a nullptr pointer. This is used only when UseOrderedCompositing is true.
Definition at line 70 of file vtkIceTSynchronizedRenderers.h.
This is necessary when rendering volumes or translucent geometries. When UseOrderedCompositing is set to true, it is expected that the PartitionOrdering is set as well. The PartitionOrdering is used to decide the process-order for compositing.
Definition at line 81 of file vtkIceTSynchronizedRenderers.h.
Overrides superclass implementation.
inlineoverridevirtual |
Definition at line 90 of file vtkIceTSynchronizedRenderers.h.
This is used to communicate among processes.
Definition at line 100 of file vtkIceTSynchronizedRenderers.h.
void vtkIceTSynchronizedRenderers::SetImageProcessingPass | ( | vtkImageProcessingPass * | ) |
void vtkIceTSynchronizedRenderers::SetUseDepthBuffer | ( | bool | ) |
void vtkIceTSynchronizedRenderers::SetRenderEmptyImages | ( | bool | ) |
Render empty images is disabled by default. It may be needed if a painter needs to make MPI global collective communication.
void vtkIceTSynchronizedRenderers::SetRenderPass | ( | vtkRenderPass * | ) |
This pass is used to render the geometry. If none specified then default rendering pipeline is used. This is typically the render-pass pipeline after the CameraPass. The CameraPass is setup by ParaView specially since ParaView needs some customizations for multiviews/icet etc.
Only use this if you know what you're doing.
overrideprotectedvirtual |
Definition at line 157 of file vtkIceTSynchronizedRenderers.h.
Definition at line 158 of file vtkIceTSynchronizedRenderers.h.
Definition at line 161 of file vtkIceTSynchronizedRenderers.h.
Definition at line 162 of file vtkIceTSynchronizedRenderers.h.
