#include <vtkPVCameraCueManipulator.h>
enum | Modes { CAMERA, PATH, FOLLOW_DATA } |
typedef vtkPVKeyFrameCueManipulator | Superclass |
typedef vtkPVCueManipulator | Superclass |
enum | { StateModifiedEvent = 2000 } |
StateModifiedEvent - This event is fired when the manipulator modifies the animated proxy. More... | |
void | SetDataSourceProxy (vtkSMProxy *dataSourceProxy) |
Set the data source proxy. More... | |
virtual void | SetMode (int) |
This manipulator has three modes: More... | |
virtual int | GetMode () |
virtual void | SetInterpolationMode (int) |
Set the interpolation mode for the CAMERA mode. More... | |
virtual int | GetInterpolationMode () |
int | AddKeyFrame (vtkPVKeyFrame *keyframe) |
Add a key frame. More... | |
void | RemoveKeyFrame (vtkPVKeyFrame *keyframe) |
Removes a key frame at the specified time, if any. More... | |
void | RemoveAllKeyFrames () |
Removes all key frames, if any. More... | |
vtkPVKeyFrame * | GetKeyFrame (double time) |
Returns a pointer to the key frame at the given time. More... | |
unsigned int | GetNumberOfKeyFrames () |
Get the number of keyframes. More... | |
vtkPVKeyFrame * | GetKeyFrameAtIndex (int index) |
Access the keyframe collection using the indices. More... | |
virtual int | GetLastAddedKeyFrameIndex () |
This method returns the index of the last added key frame. More... | |
vtkPVKeyFrame * | GetStartKeyFrame (double time) |
Given the current time, determine the key frames between which the current time lies. More... | |
vtkPVKeyFrame * | GetEndKeyFrame (double time) |
vtkPVKeyFrame * | GetNextKeyFrame (vtkPVKeyFrame *keyFrame) |
Get the next/previous key frame relative to argument key frame. More... | |
vtkPVKeyFrame * | GetPreviousKeyFrame (vtkPVKeyFrame *keyFrame) |
virtual void | Modified () |
vtkPVCameraCueManipulator () | |
~vtkPVCameraCueManipulator () override | |
void | Initialize (vtkPVAnimationCue *) override |
This method is called when the AnimationCue's StartAnimationCueEvent is triggered, to let the animation manipulator know that the cue has been restarted. More... | |
void | Finalize (vtkPVAnimationCue *) override |
This method is called when the AnimationCue's EndAnimationCueEvent is triggered. More... | |
void | UpdateValue (double currenttime, vtkPVAnimationCue *cueproxy) override |
This updates the values based on currenttime. More... | |
int | AddKeyFrameInternal (vtkPVKeyFrame *keyframe) |
int | RemoveKeyFrameInternal (vtkPVKeyFrame *keyframe) |
void | ExecuteEvent (vtkObject *obj, unsigned long event, void *) |
vtkPVKeyFrameCueManipulator () | |
This method iterates over all added keyframe proxies and updates the domains for all keyframes, such that for every keyframe J, with keytime between keyframes I and K, the domain for keytime of J is (DomainJ)min = KeyTimeI and (DomainJ)max = KeyTimeK. More... | |
~vtkPVKeyFrameCueManipulator () override | |
vtkPVCueManipulator () | |
~vtkPVCueManipulator () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
int | Mode |
int | InterpolationMode |
vtkCameraInterpolator * | CameraInterpolator |
vtkSMProxy * | DataSourceProxy |
vtkPVKeyFrameCueManipulatorInternals * | Internals |
vtkPVKeyFrameCueManipulatorObserver * | Observer |
int | SendEndEvent |
int | LastAddedKeyFrameIndex |
bool | Debug |
vtkTimeStamp | MTime |
Definition at line 25 of file vtkPVCameraCueManipulator.h.
Definition at line 29 of file vtkPVCameraCueManipulator.h.
Enumerator | |
CAMERA | |
PATH | |
FOLLOW_DATA |
Definition at line 32 of file vtkPVCameraCueManipulator.h.
Reimplemented from vtkPVKeyFrameCueManipulator.
void vtkPVCameraCueManipulator::SetDataSourceProxy | ( | vtkSMProxy * | dataSourceProxy | ) |
This is used when in the FOLLOW_DATA mode. The camera will track the data referred to by the data source proxy.
overrideprotectedvirtual |
This is here for one major reason: after the last key frame, the state of the scene must be as it was left a the the last key frame. This does not happened automatically, since if while animating the currentime never coincides with the last key frame's key time, then it never gets a chance to update the properties value. Hence, we note when the cue begins. Then, if the currentime is beyond that of the last key frame we pretend that the current time coincides with that of the last key frame and let it update the properties. This is done only once per Animation cycle. The Initialize method is used to indicate that a new animation cycle has begun.
Reimplemented from vtkPVCueManipulator.
Typically, the Manipulator will set the state of the Cue to that at the end of the cue.
currenttime is normalized to the time range of the Cue.
Implements vtkPVCueManipulator.
Definition at line 75 of file vtkPVCameraCueManipulator.h.
Definition at line 76 of file vtkPVCameraCueManipulator.h.
Definition at line 86 of file vtkPVCameraCueManipulator.h.
Definition at line 87 of file vtkPVCameraCueManipulator.h.
