Special key frame for animating Camera. More...
#include <vtkPVCameraKeyFrame.h>
typedef vtkPVKeyFrame | Superclass |
void | UpdateValue (double currenttime, vtkPVAnimationCue *cue, vtkPVKeyFrame *next) override |
If the vtkPVCameraCueManipulator is in CAMERA mode, then this method is not even called since the interpolation is done by vtkCameraInterpolator maintained by vtkPVCameraCueManipulator itself. More... | |
void | SetKeyValue (unsigned int, double) override |
Get/Set the animated value at this key frame. More... | |
void | SetKeyValue (double) override |
virtual double | GetKeyValue (unsigned int) |
virtual vtkCamera * | GetCamera () |
Get the camera i.e. More... | |
void | SetPosition (double x, double y, double z) |
Methods to set the current camera value. More... | |
void | SetFocalPoint (double x, double y, double z) |
void | SetViewUp (double x, double y, double z) |
void | SetViewAngle (double angle) |
void | SetParallelScale (double scale) |
void | AddPositionPathPoint (double x, double y, double z) |
Forwarded to vtkCameraInterpolator2. More... | |
void | ClearPositionPath () |
void | AddFocalPathPoint (double x, double y, double z) |
void | ClearFocalPath () |
void | SetFocalPointMode (int val) |
void | SetPositionMode (int val) |
void | SetClosedFocalPath (bool val) |
void | SetClosedPositionPath (bool val) |
virtual void | RemoveAllKeyValues () |
Removes all key values. More... | |
virtual void | SetKeyTime (double) |
Key time is the time at which this key frame is associated. More... | |
virtual double | GetKeyTime () |
double | GetKeyValue () |
double | GetKeyValue (unsigned int index) |
unsigned int | GetNumberOfKeyValues () |
Set/Get the number of key values this key frame currently stores. More... | |
virtual void | SetNumberOfKeyValues (unsigned int num) |
virtual void | Modified () |
static vtkPVCameraKeyFrame * | New () |
static vtkPVCameraKeyFrame * | SafeDownCast (vtkObject *o) |
static vtkPVKeyFrame * | SafeDownCast (vtkObject *o) |
static vtkPVKeyFrame * | New () |
static vtkObject * | New () |
vtkPVCameraKeyFrame () | |
~vtkPVCameraKeyFrame () override | |
vtkPVKeyFrame () | |
~vtkPVKeyFrame () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkCamera * | Camera |
vtkCameraInterpolator2 * | Interpolator |
double | KeyTime |
vtkPVKeyFrameInternals * | Internals |
bool | Debug |
vtkTimeStamp | MTime |
Unlike typical keyframes, this keyframe interpolates a camera and not a property on the camera.
Definition at line 20 of file vtkPVCameraKeyFrame.h.
Definition at line 24 of file vtkPVCameraKeyFrame.h.
Reimplemented from vtkPVKeyFrame.
However, in PATH mode, this method is called to allow the key frame to use vtkCameraInterpolator2 to do path-based interpolations for the camera.
inlineoverridevirtual |
Note that is the number of values is adjusted to fit the index specified in SetKeyValue.
Definition at line 37 of file vtkPVCameraKeyFrame.h.
Definition at line 38 of file vtkPVCameraKeyFrame.h.
Definition at line 39 of file vtkPVCameraKeyFrame.h.
Get the camera i.e.
the key value for this key frame.
void vtkPVCameraKeyFrame::SetViewAngle | ( | double | angle | ) |
void vtkPVCameraKeyFrame::SetParallelScale | ( | double | scale | ) |
void vtkPVCameraKeyFrame::ClearPositionPath | ( | ) |
void vtkPVCameraKeyFrame::ClearFocalPath | ( | ) |
void vtkPVCameraKeyFrame::SetFocalPointMode | ( | int | val | ) |
void vtkPVCameraKeyFrame::SetPositionMode | ( | int | val | ) |
void vtkPVCameraKeyFrame::SetClosedFocalPath | ( | bool | val | ) |
void vtkPVCameraKeyFrame::SetClosedPositionPath | ( | bool | val | ) |
Definition at line 77 of file vtkPVCameraKeyFrame.h.
Definition at line 78 of file vtkPVCameraKeyFrame.h.
