vtkPVComparativeAnimationCue Class Reference
cue used for parameter animation by the comparative view. More...
#include <vtkPVComparativeAnimationCue.h>
Inheritance diagram for vtkPVComparativeAnimationCue:
Collaboration diagram for vtkPVComparativeAnimationCue:
void UpdateXRange (int y, double minx, double maxx)
 Methods use to fill up the values for the parameter over the comparative grid. More...
void UpdateYRange (int x, double miny, double maxy)
void UpdateWholeRange (double mint, double maxt)
void UpdateValue (int x, int y, double value)
void UpdateAnimatedValue (int x, int y, int dx, int dy)
 Update the animated property's value based on those specified using the Update. More...
doubleGetValues (int x, int y, int dx, int dy, unsigned int &numValues)
 NOTE: Returned values is only valid until the next call to this method. More...
vtkPVXMLElementAppendCommandInfo (vtkPVXMLElement *proxyElem)
int LoadCommandInfo (vtkPVXMLElement *proxyElement)
void SetAnimatedProxy (vtkSMProxy *)
 Set/Get the animated proxy. More...
virtual vtkSMProxyGetAnimatedProxy ()
void RemoveAnimatedProxy ()
virtual void SetAnimatedPropertyName (const char *)
 Set/Get the animated property name. More...
virtual char * GetAnimatedPropertyName ()
virtual void SetAnimatedDomainName (const char *)
 Set/Get the animated domain name. More...
virtual char * GetAnimatedDomainName ()
virtual void SetAnimatedElement (int)
 The index of the element of the property this cue animates. More...
virtual int GetAnimatedElement ()
virtual void SetEnabled (bool)
 Enable/Disable the cue. More...
virtual bool GetEnabled ()
virtual void EnabledOn ()
virtual void EnabledOff ()
void UpdateXRange (int y, double *minx, double *maxx, unsigned int numvalues)
 Use these methods when the parameter can have multiple values eg. More...
void UpdateYRange (int x, double *minx, double *maxx, unsigned int numvalues)
void UpdateWholeRange (double *mint, double *maxt, unsigned int numValues)
void UpdateWholeRange (double *mint, double *maxt, unsigned int numValues, bool vertical_first)
void UpdateValue (int x, int y, double *value, unsigned int numValues)
double GetValue (int x, int y, int dx, int dy)
 Computes the value for a particular location in the comparative grid. More...
static vtkPVComparativeAnimationCueNew ()
static vtkPVComparativeAnimationCueSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVComparativeAnimationCue ()
 ~vtkPVComparativeAnimationCue () override
vtkSMPropertyGetAnimatedProperty ()
 Get the property being animated. More...
vtkSMDomainGetAnimatedDomain ()
 Get the domain being animated. More...
vtkSMProxyAnimatedProxy
int AnimatedElement
char * AnimatedPropertyName
char * AnimatedDomainName
doubleValues
bool Enabled
vtkPVComparativeAnimationCue is a animation cue used for parameter animation by the ComparativeView. It provides a non-conventional API i.e. without using properties to allow the user to setup parameter values over the comparative grid.
Definition at line 25 of file vtkPVComparativeAnimationCue.h.
Definition at line 29 of file vtkPVComparativeAnimationCue.h.
◆ vtkPVComparativeAnimationCue()
vtkPVComparativeAnimationCue::vtkPVComparativeAnimationCue ( )
◆ ~vtkPVComparativeAnimationCue()
vtkPVComparativeAnimationCue::~vtkPVComparativeAnimationCue ( )
static vtkPVComparativeAnimationCue* vtkPVComparativeAnimationCue::New ( )
virtual const char* vtkPVComparativeAnimationCue::GetClassName ( )
static int vtkPVComparativeAnimationCue::IsTypeOf ( const char *  type)
virtual int vtkPVComparativeAnimationCue::IsA ( const char *  type)
static vtkPVComparativeAnimationCue* vtkPVComparativeAnimationCue::SafeDownCast ( vtkObject o)
void vtkPVComparativeAnimationCue::PrintSelf ( ostream &  os,
◆ SetAnimatedProxy()
void vtkPVComparativeAnimationCue::SetAnimatedProxy ( vtkSMProxy )
◆ GetAnimatedProxy()
virtual vtkSMProxy* vtkPVComparativeAnimationCue::GetAnimatedProxy ( )
◆ RemoveAnimatedProxy()
void vtkPVComparativeAnimationCue::RemoveAnimatedProxy ( )
◆ SetAnimatedPropertyName()
virtual void vtkPVComparativeAnimationCue::SetAnimatedPropertyName ( const char *  )
◆ GetAnimatedPropertyName()
virtual char* vtkPVComparativeAnimationCue::GetAnimatedPropertyName ( )
◆ SetAnimatedDomainName()
virtual void vtkPVComparativeAnimationCue::SetAnimatedDomainName ( const char *  )
◆ GetAnimatedDomainName()
virtual char* vtkPVComparativeAnimationCue::GetAnimatedDomainName ( )
◆ SetAnimatedElement()
virtual void vtkPVComparativeAnimationCue::SetAnimatedElement ( int  )
If the index is -1, the cue will animate all the elements of the animated property.
◆ GetAnimatedElement()
virtual int vtkPVComparativeAnimationCue::GetAnimatedElement ( )
◆ SetEnabled()
virtual void vtkPVComparativeAnimationCue::SetEnabled ( bool  )
◆ GetEnabled()
virtual bool vtkPVComparativeAnimationCue::GetEnabled ( )
◆ EnabledOn()
virtual void vtkPVComparativeAnimationCue::EnabledOn ( )
◆ EnabledOff()
virtual void vtkPVComparativeAnimationCue::EnabledOff ( )
◆ UpdateXRange() [1/2]
void vtkPVComparativeAnimationCue::UpdateXRange ( int  y,
double  minx,
double  maxx
inline
These are order dependent methods i.e. the result of calling UpdateXRange() and then UpdateYRange() are different from calling UpdateYRange() and then UpdateXRange(). These methods are convenience methods when the value can only be a single value.
Definition at line 84 of file vtkPVComparativeAnimationCue.h.
◆ UpdateYRange() [1/2]
void vtkPVComparativeAnimationCue::UpdateYRange ( int  x,
double  miny,
double  maxy
inline
Definition at line 85 of file vtkPVComparativeAnimationCue.h.
◆ UpdateWholeRange() [1/3]
void vtkPVComparativeAnimationCue::UpdateWholeRange ( double  mint,
double  maxt
inline
Definition at line 86 of file vtkPVComparativeAnimationCue.h.
◆ UpdateValue() [1/2]
void vtkPVComparativeAnimationCue::UpdateValue ( int  x,
int  y,
double  value
inline
Definition at line 87 of file vtkPVComparativeAnimationCue.h.
◆ UpdateXRange() [2/2]
double minx,
double maxx,
IsoValues for the Contour filter. The "AnimatedElement" for such properties must be set to -1, otherwise UpdateAnimatedValue() will raise an error.
◆ UpdateYRange() [2/2]
double minx,
double maxx,
◆ UpdateWholeRange() [2/3]
double maxt,
inline
Definition at line 97 of file vtkPVComparativeAnimationCue.h.
◆ UpdateWholeRange() [3/3]
double maxt,
bool  vertical_first
◆ UpdateValue() [2/2]
int  y,
double value,
◆ UpdateAnimatedValue()
void vtkPVComparativeAnimationCue::UpdateAnimatedValue ( int  x,
int  y,
int  dx,
int  dy
  • methods. (x,y) is the location in the comparative grid, while (dx, dy) are the dimensions of the comparative grid.
◆ GetValue()
double vtkPVComparativeAnimationCue::GetValue ( int  x,
int  y,
int  dx,
int  dy
inline
Definition at line 118 of file vtkPVComparativeAnimationCue.h.
◆ GetValues()
double* vtkPVComparativeAnimationCue::GetValues ( int  x,
int  y,
int  dx,
int  dy,
Return value is only valid when numValues > 0.
◆ AppendCommandInfo()
vtkPVXMLElement* vtkPVComparativeAnimationCue::AppendCommandInfo ( vtkPVXMLElement proxyElem)
◆ LoadCommandInfo()
int vtkPVComparativeAnimationCue::LoadCommandInfo ( vtkPVXMLElement proxyElement)
◆ GetAnimatedProperty()
vtkSMProperty* vtkPVComparativeAnimationCue::GetAnimatedProperty ( )
◆ GetAnimatedDomain()
vtkSMDomain* vtkPVComparativeAnimationCue::GetAnimatedDomain ( )
◆ AnimatedProxy
vtkSMProxy* vtkPVComparativeAnimationCue::AnimatedProxy
Definition at line 153 of file vtkPVComparativeAnimationCue.h.
◆ AnimatedElement
int vtkPVComparativeAnimationCue::AnimatedElement
Definition at line 154 of file vtkPVComparativeAnimationCue.h.
◆ AnimatedPropertyName
char* vtkPVComparativeAnimationCue::AnimatedPropertyName
Definition at line 155 of file vtkPVComparativeAnimationCue.h.
◆ AnimatedDomainName
char* vtkPVComparativeAnimationCue::AnimatedDomainName
Definition at line 156 of file vtkPVComparativeAnimationCue.h.
◆ Values
double* vtkPVComparativeAnimationCue::Values
Definition at line 157 of file vtkPVComparativeAnimationCue.h.
◆ Enabled
bool vtkPVComparativeAnimationCue::Enabled
Definition at line 158 of file vtkPVComparativeAnimationCue.h.
