vtkPVComparativeAnimationCue.h
14 #ifndef vtkPVComparativeAnimationCue_h
15 #define vtkPVComparativeAnimationCue_h
16
17 #include "vtkObject.h"
18 #include "vtkRemotingViewsModule.h" //needed for exports
20 class vtkSMDomain;
21 class vtkSMProperty;
22 class vtkSMProxy;
23 class vtkPVXMLElement;
24
26 {
27 public:
30  void PrintSelf(ostream& os, vtkIndent indent) override;
31
33
36  void SetAnimatedProxy(vtkSMProxy*);
37  vtkGetObjectMacro(AnimatedProxy, vtkSMProxy);
38  void RemoveAnimatedProxy();
40
42
45  vtkSetStringMacro(AnimatedPropertyName);
46  vtkGetStringMacro(AnimatedPropertyName);
48
50
53  vtkSetStringMacro(AnimatedDomainName);
54  vtkGetStringMacro(AnimatedDomainName);
56
58
63  vtkSetMacro(AnimatedElement, int);
64  vtkGetMacro(AnimatedElement, int);
66
68
71  vtkSetMacro(Enabled, bool);
72  vtkGetMacro(Enabled, bool);
73  vtkBooleanMacro(Enabled, bool);
75
84  void UpdateXRange(int y, double minx, double maxx) { this->UpdateXRange(y, &minx, &maxx, 1); }
85  void UpdateYRange(int x, double miny, double maxy) { this->UpdateYRange(x, &miny, &maxy, 1); }
86  void UpdateWholeRange(double mint, double maxt) { this->UpdateWholeRange(&mint, &maxt, 1); }
87  void UpdateValue(int x, int y, double value) { this->UpdateValue(x, y, &value, 1); }
88
90
95  void UpdateXRange(int y, double* minx, double* maxx, unsigned int numvalues);
96  void UpdateYRange(int x, double* minx, double* maxx, unsigned int numvalues);
97  void UpdateWholeRange(double* mint, double* maxt, unsigned int numValues)
98  {
99  this->UpdateWholeRange(mint, maxt, numValues, false);
100  }
101  void UpdateWholeRange(double* mint, double* maxt, unsigned int numValues, bool vertical_first);
102  void UpdateValue(int x, int y, double* value, unsigned int numValues);
104
110  void UpdateAnimatedValue(int x, int y, int dx, int dy);
111
113
118  double GetValue(int x, int y, int dx, int dy)
119  {
120  unsigned int numValues = 0;
121  double* vals = this->GetValues(x, y, dx, dy, numValues);
122  if (numValues > 0)
123  {
124  return vals[0];
125  }
126  return -1.0;
127  }
129
134  double* GetValues(int x, int y, int dx, int dy, unsigned int& numValues);
135
136  vtkPVXMLElement* AppendCommandInfo(vtkPVXMLElement* proxyElem);
137  int LoadCommandInfo(vtkPVXMLElement* proxyElement);
138
139 protected:
141  ~vtkPVComparativeAnimationCue() override;
142
146  vtkSMProperty* GetAnimatedProperty();
147
151  vtkSMDomain* GetAnimatedDomain();
152
157  double* Values;
158  bool Enabled;
159
160 private:
162  void operator=(const vtkPVComparativeAnimationCue&) = delete;
163
164  class vtkInternals;
165  vtkInternals* Internals;
166 };
167
168 #endif
void UpdateWholeRange(double *mint, double *maxt, unsigned int numValues)
Use these methods when the parameter can have multiple values eg.
represents the possible values a property can have
Definition: vtkSMDomain.h:37
Methods use to fill up the values for the parameter over the comparative grid.
cue used for parameter animation by the comparative view.
Definition: vtkSMProxy.h:140
value
Computes the value for a particular location in the comparative grid.
static vtkObject * New()
