void | SetView (vtkPVRenderView *view) |
| Set the view that will be used to exchange messages between all processes involved. More...
virtual vtkSelection * | Select (int region[4]) |
| Perform the selection over the specified region. More...
vtkSelection * | PolygonSelect (int *polygonPoints, vtkIdType count) |
| Same as Select() above, except this one use a polygon, instead of a rectangle region, and select elements inside the polygon. More...
virtual bool | NeedToRenderForSelection () |
| Returns true when the next call to Select() will result in renders to capture the selection-buffers. More...
void | InvalidateCachedSelection () |
| Called to invalidate the cache. More...
int | AssignUniqueId (vtkProp *) |
void | BeginRenderProp (vtkRenderWindow *) override |
| Set the local ProcessId. More...
vtkOpenGLHardwareSelector * | NewInstance () const |
virtual void | EndRenderProp () |
virtual void | RenderCompositeIndex (unsigned int index) |
virtual void | RenderAttributeId (vtkIdType attribid) |
virtual void | RenderProcessId (unsigned int processid) |
virtual void | BeginRenderProp () |
vtkHardwareSelector * | NewInstance () const |
vtkSelection * | Select () |
int | Render (vtkRenderer *renderer, vtkProp **propArray, int propArrayCount) |
vtkProp * | GetPropFromID (int id) |
virtual void | SetRenderer (vtkRenderer *) |
virtual vtkRenderer * | GetRenderer () |
virtual void | SetArea (unsigned int, unsigned int, unsigned int, unsigned int) |
virtual void | SetArea (unsigned int[4]) |
virtual unsigned int * | GetArea () |
virtual void | GetArea (unsigned int &, unsigned int &, unsigned int &, unsigned int &) |
virtual void | GetArea (unsigned int[4]) |
virtual void | SetFieldAssociation (int) |
virtual int | GetFieldAssociation () |
virtual void | SetUseProcessIdFromData (bool) |
virtual bool | GetUseProcessIdFromData () |
virtual bool | CaptureBuffers () |
PixelInformation | GetPixelInformation (const unsigned int display_position[2]) |
PixelInformation | GetPixelInformation (const unsigned int display_position[2], int maxDist) |
PixelInformation | GetPixelInformation (const unsigned int display_position[2], int maxDist, unsigned int selected_position[2]) |
void | ClearBuffers () |
virtual void | SetProcessID (int) |
virtual int | GetProcessID () |
virtual float * | GetPropColorValue () |
virtual void | GetPropColorValue (float &, float &, float &) |
virtual void | GetPropColorValue (float[3]) |
virtual void | SetPropColorValue (float, float, float) |
virtual void | SetPropColorValue (float[3]) |
virtual int | GetCurrentPass () |
virtual vtkSelection * | GenerateSelection () |
virtual vtkSelection * | GenerateSelection (unsigned int r[4]) |
virtual vtkSelection * | GenerateSelection (unsigned int x1, unsigned int y1, unsigned int x2, unsigned int y2) |
virtual vtkSelection * | GeneratePolygonSelection (int *polygonPoints, vtkIdType count) |
virtual void | Modified () |
