representation for "Histogram View". More...
#include <vtkPVHistogramChartRepresentation.h>
typedef vtkXYChartRepresentation | Superclass |
typedef vtkChartRepresentation | Superclass |
typedef vtkPVDataRepresentation | Superclass |
enum | { SkippedUpdateDataEvent = vtkCommand::UserEvent + 91, UpdateTimeChangedEvent } |
typedef vtkDataRepresentation | Superclass |
typedef vtkPassInputTypeAlgorithm | Superclass |
typedef vtkAlgorithm | Superclass |
enum | DesiredOutputPrecision |
void | SetHistogramColor (double r, double g, double b) |
Sets the color for the histograms. More... | |
void | SetUseColorMapping (bool colorMapping) |
Sets the histogram to be color mapped by the scalar. More... | |
void | SetLookupTable (vtkScalarsToColors *lut) |
Sets the lookup table that is used for color mapping by the scalar. More... | |
void | SetHistogramLineStyle (int style) |
Set the line style for the histogram. More... | |
vtkSmartPointer< vtkDataObject > | TransformInputData (vtkDataObject *data) override |
Method to be overridden to transform input data to a vtkTable. More... | |
bool | MapSelectionToInput (vtkSelection *) override |
Overridden to transform id-based selection produced by the histogram view to a threshold-based selection. More... | |
bool | MapSelectionToView (vtkSelection *sel) override |
Inverse of MapSelectionToInput(). More... | |
void | SetComponent (int) |
Controls which input data component should be binned, for input arrays with more-than-one component. More... | |
int | GetComponent () |
void | SetBinCount (int) |
Controls the number of bins N in the output histogram data. More... | |
int | GetBinCount () |
void | SetCenterBinsAroundMinAndMax (bool) |
Get/Set if first and last bins must be centered around the min and max data. More... | |
bool | GetCenterBinsAroundMinAndMax () |
void | SetCustomBinRanges (double min, double max) |
Get/Set custom bin ranges to use. More... | |
double * | GetCustomBinRanges () |
void | SetUseCustomBinRanges (bool) |
When set to true, CustomBinRanges will be used instead of using the full range for the selected array. More... | |
bool | GetUseCustomBinRanges () |
void | SetInputArrayToProcess (int idx, int port, int connection, int fieldAssociation, const char *name) override |
Overload the vtkAlgorithm method to update after the change. More... | |
void | SetVisibility (bool visible) override |
Set visibility of the representation. More... | |
void | SetChartTypeToLine () |
void | SetChartTypeToPoints () |
void | SetChartTypeToBar () |
void | SetChartTypeToStacked () |
void | SetChartTypeToBag () |
void | SetChartTypeToFunctionalBag () |
void | SetChartTypeToArea () |
vtkChartXY * | GetChart () |
Returns the vtkChartXY instance from the view to which this representation is added. More... | |
void | ClearSeriesVisibilities () |
void | ClearLineThicknesses () |
void | ClearLineStyles () |
void | ClearColors () |
void | ClearOpacities () |
void | ClearAxisCorners () |
void | ClearMarkerSizes () |
void | ClearMarkerStyles () |
void | ClearLabels () |
virtual void | SetSelectionColor (double, double, double) |
virtual void | SetSelectionColor (double [3]) |
virtual double * | GetSelectionColor () |
virtual void | GetSelectionColor (double &, double &, double &) |
virtual void | GetSelectionColor (double [3]) |
virtual void | SetChartType (int) |
Get/Set the chart type, defaults to line chart. More... | |
virtual int | GetChartType () |
virtual void | SetXAxisSeriesName (const char *) |
Set the series to use as the X-axis. More... | |
virtual char * | GetXAxisSeriesName () |
virtual void | SetUseIndexForXAxis (bool) |
Set whether the index should be used for the x axis. More... | |
virtual bool | GetUseIndexForXAxis () |
void | SetSortDataByXAxis (bool val) |
Get/set whether the points in the chart should be sorted by their x-axis value. More... | |
virtual bool | GetSortDataByXAxis () |
void | SetSeriesVisibility (const char *seriesname, bool visible) |
Set/Clear the properties for Y series/columns. More... | |
void | SetLineThickness (const char *name, double value) |
void | SetLineStyle (const char *name, int value) |
void | SetColor (const char *name, double r, double g, double b) |
void | SetOpacity (const char *seriesname, double opacity) |
void | SetAxisCorner (const char *name, int corner) |
void | SetMarkerStyle (const char *name, int style) |
void | SetMarkerSize (const char *name, double value) |
void | SetLabel (const char *name, const char *label) |
void | SetUseColorMapping (const char *name, bool useColorMapping) |
void | SetLookupTable (const char *name, vtkScalarsToColors *lut) |
const char * | GetLabel (const char *name) const |
virtual void | SetSeriesLabelPrefix (const char *) |
Get/Set the series label prefix. More... | |
virtual char * | GetSeriesLabelPrefix () |
bool | Export (vtkAbstractChartExporter *exporter) override |
Called by vtkPVContextView::Export() to export the representation's data to a CSV file. More... | |
void | SetSelectionRepresentation (vtkChartSelectionRepresentation *) |
These must only be set during initialization before adding the representation to any views or calling Update(). More... | |
void | MarkModified () override |
This needs to be called on all instances of vtkGeometryRepresentation when the input is modified. More... | |
void | SetCompositeDataSetIndex (unsigned int) |
void | AddCompositeDataSetIndex (unsigned int) |
void | ResetCompositeDataSetIndices () |
unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override |
Override because of internal selection representations that need to be initialized as well. More... | |
virtual std::string | GetDefaultSeriesLabel (const std::string &tableName, const std::string &columnName) |
Method to provide the default name given the name of a table and a column in that table. More... | |
void | SetFieldAssociation (int) |
Set the field association for arrays to use. More... | |
virtual int | GetFieldAssociation () |
virtual void | SetFlattenTable (int) |
Flatten the table, i.e. More... | |
virtual int | GetFlattenTable () |
virtual bool | Export (vtkAbstractChartExporter *vtkNotUsed(exporter)) |
unsigned int | GetUniqueIdentifier () |
Return 0 if the Initialize() method was not called otherwise a unique ID that will be shared across the processes for that same object. More... | |
virtual bool | GetVisibility () |
virtual vtkDataObject * | GetRenderedDataObject (int vtkNotUsed(port)) |
Returns the data object that is rendered from the given input port. More... | |
double | GetCacheKey () const |
Returns the cache-key the representation is currently using. More... | |
vtkAlgorithmOutput * | GetInternalOutputPort () override |
Retrieves an output port for the input data object at the specified port and connection index. More... | |
vtkAlgorithmOutput * | GetInternalOutputPort (int port) override |
vtkAlgorithmOutput * | GetInternalOutputPort (int port, int conn) override |
vtkView * | GetView () const |
Provides access to the view. More... | |
vtkMTimeType | GetPipelineDataTime () |
Returns the timestamp when RequestData was executed on the representation. More... | |
bool | GetNeedsUpdate () |
Returns true if the representation needs an update. More... | |
virtual void | SetArrayIdNames (const char *vtkNotUsed(pointArray), const char *vtkNotUsed(cellArray)) |
Specify the array names used for the selection. More... | |
virtual void | SetUpdateTime (double time) |
Set the update time. More... | |
virtual double | GetUpdateTime () |
virtual bool | GetUpdateTimeValid () |
Get whether the UpdateTime is valid. More... | |
void | ResetUpdateTime () |
virtual void | SetForcedCacheKey (double val) |
Generally, caching is within the purview of the vtkPVView (and subclasses). More... | |
virtual void | SetForceUseCache (bool val) |
virtual double | GetForcedCacheKey () |
virtual bool | GetForceUseCache () |
bool | AddToView (vtkView *view) override |
Making these methods public. More... | |
bool | RemoveFromView (vtkView *view) override |
virtual void | SetLogName (const std::string &name) |
This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged. More... | |
const std::string & | GetLogName () const |
virtual bool | GetHasTemporalPipeline () |
This flag indicates if the representation is for a temporal pipeline. More... | |
virtual void | SetHasTemporalPipeline (bool) |
void | SetInputConnection (int port, vtkAlgorithmOutput *input) override |
Overridden to ensure that MarkModified is called. More... | |
void | AddInputConnection (int port, vtkAlgorithmOutput *input) override |
vtkDataRepresentation * | NewInstance () const |
virtual void | ApplyViewTheme (vtkViewTheme *vtkNotUsed(theme)) |
virtual vtkSelection * | ConvertSelection (vtkView *view, vtkSelection *selection) |
vtkAlgorithmOutput * | GetInputConnection (int port=0, int index=0) |
vtkAnnotationLink * | GetAnnotationLink () |
void | SetAnnotationLink (vtkAnnotationLink *link) |
void | Select (vtkView *view, vtkSelection *selection) |
void | Select (vtkView *view, vtkSelection *selection, bool extend) |
void | Annotate (vtkView *view, vtkAnnotationLayers *annotations) |
void | Annotate (vtkView *view, vtkAnnotationLayers *annotations, bool extend) |
virtual void | SetSelectable (bool) |
virtual bool | GetSelectable () |
virtual void | SelectableOn () |
virtual void | SelectableOff () |
void | UpdateSelection (vtkSelection *selection) |
void | UpdateSelection (vtkSelection *selection, bool extend) |
void | UpdateAnnotations (vtkAnnotationLayers *annotations) |
void | UpdateAnnotations (vtkAnnotationLayers *annotations, bool extend) |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort () |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort (int port) |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort (int port, int conn) |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort () |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort (int port) |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort (int port, int conn) |
virtual void | SetSelectionType (int) |
virtual int | GetSelectionType () |
virtual void | SetSelectionArrayNames (vtkStringArray *names) |
virtual vtkStringArray * | GetSelectionArrayNames () |
virtual void | SetSelectionArrayName (const char *name) |
virtual const char * | GetSelectionArrayName () |
vtkPassInputTypeAlgorithm * | NewInstance () const |
vtkPolyData * | GetPolyDataOutput () |
vtkStructuredPoints * | GetStructuredPointsOutput () |
vtkImageData * | GetImageDataOutput () |
vtkStructuredGrid * | GetStructuredGridOutput () |
vtkUnstructuredGrid * | GetUnstructuredGridOutput () |
vtkRectilinearGrid * | GetRectilinearGridOutput () |
vtkTable * | GetTableOutput () |
vtkGraph * | GetGraphOutput () |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
SINGLE_PRECISION | |
DOUBLE_PRECISION | |
DEFAULT_PRECISION | |
int | AbortExecute |
typedef std::map< std::string, std::pair< vtkSmartPointer< vtkTable >, unsigned int > > | MapOfTables |
static vtkInformationIntegerKey * | PORT_REQUIREMENTS_FILLED () |
static vtkExecutive * | DefaultExecutivePrototype |
vtkPVHistogramChartRepresentation is the vtkPVDataRepresentation subclass for showing an data in the "Histogram View". The representation pipeline extracts histogram from the input dataset and then shows that in the view.
Definition at line 23 of file vtkPVHistogramChartRepresentation.h.
Definition at line 27 of file vtkPVHistogramChartRepresentation.h.
Reimplemented from vtkXYChartRepresentation.
Reimplemented from vtkChartRepresentation.
void vtkPVHistogramChartRepresentation::SetComponent | ( | int | ) |
int vtkPVHistogramChartRepresentation::GetComponent | ( | ) |
void vtkPVHistogramChartRepresentation::SetBinCount | ( | int | ) |
int vtkPVHistogramChartRepresentation::GetBinCount | ( | ) |
void vtkPVHistogramChartRepresentation::SetCenterBinsAroundMinAndMax | ( | bool | ) |
This is only used when UseCustomBinRanges is set to false. Default is false.
bool vtkPVHistogramChartRepresentation::GetCenterBinsAroundMinAndMax | ( | ) |
These are used only when UseCustomBinRanges is set to true.
double* vtkPVHistogramChartRepresentation::GetCustomBinRanges | ( | ) |
void vtkPVHistogramChartRepresentation::SetUseCustomBinRanges | ( | bool | ) |
By default, set to false.
bool vtkPVHistogramChartRepresentation::GetUseCustomBinRanges | ( | ) |
void vtkPVHistogramChartRepresentation::SetUseColorMapping | ( | bool | colorMapping | ) |
void vtkPVHistogramChartRepresentation::SetLookupTable | ( | vtkScalarsToColors * | lut | ) |
void vtkPVHistogramChartRepresentation::SetHistogramLineStyle | ( | int | style | ) |
overrideprotectedvirtual |
This method is called before actual render if this->MTime was modified since the last time this method was called.
Subclasses should override to update "appearance" related changes that don't affect data. When this method is called, you're assured that this->ContextView is valid. Note that this method will not be called if this->GetVisibility() returns false, this subclasses should also override SetVisibility() to hide "actors" and such.
Definition at line 126 of file vtkPVHistogramChartRepresentation.h.
