| vtkRemoteWriterHelper (const vtkRemoteWriterHelper &)=delete |
void | operator= (const vtkRemoteWriterHelper &)=delete |
int | Write () |
| Write the data. More...
void | SetWriter (vtkAlgorithm *writer) |
| Get/Set the Image writer. More...
virtual vtkAlgorithm * | GetWriter () |
virtual void | SetOutputDestination (vtkTypeUInt32) |
| Get/Set the process on which the data must be written. More...
virtual vtkTypeUInt32 | GetOutputDestination () |
virtual void | SetTryWritingInBackground (bool) |
| If set to true, this helper will attempt writing the file in the background in parallel. More...
virtual bool | GetTryWritingInBackground () |
virtual void | TryWritingInBackgroundOn () |
virtual void | TryWritingInBackgroundOff () |
virtual void | SetState (int) |
| Set the state of the writer. More...
virtual int | GetState () |
void | SetInterpreter (vtkClientServerInterpreter *interp) |
| Set the interpreter to use to call methods on the writer. More...
virtual vtkClientServerInterpreter * | GetInterpreter () |
vtkDataObjectAlgorithm * | NewInstance () const |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
