builder server manager undo sets for render view interactions and pushes them on the undo stack. More...
#include <vtkSMInteractionUndoStackBuilder.h>
void | Clear () |
Clear the undo set currently being recorded. More... | |
void | StartInteraction () |
Called to record the state at the beginning of an interaction. More... | |
void | EndInteraction () |
Called to record the state at the end of an interaction and push it on the stack. More... | |
void | SetRenderView (vtkSMRenderViewProxy *) |
Get/Set the render view proxy for which we are monitoring the interactions. More... | |
virtual vtkSMRenderViewProxy * | GetRenderView () |
virtual vtkSMUndoStack * | GetUndoStack () |
Get/Set the undo stack that this builder will build. More... | |
virtual void | SetUndoStack (vtkSMUndoStack *) |
virtual void | Modified () |
static vtkSMInteractionUndoStackBuilder * | New () |
static vtkSMInteractionUndoStackBuilder * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMInteractionUndoStackBuilder () | |
~vtkSMInteractionUndoStackBuilder () override | |
void | ExecuteEvent (vtkObject *caller, unsigned long event, void *data) |
Event handler. More... | |
void | PropertyModified (const char *pname) |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkSMRenderViewProxy * | RenderView |
vtkSMUndoStack * | UndoStack |
vtkUndoSet * | UndoSet |
bool | Debug |
vtkTimeStamp | MTime |
Friends | |
class | vtkSMInteractionUndoStackBuilderObserver |
vtkSMInteractionUndoStackBuilder specializes in interaction. This class can create undo elements for only one render view at a time.
Definition at line 24 of file vtkSMInteractionUndoStackBuilder.h.
Definition at line 28 of file vtkSMInteractionUndoStackBuilder.h.
void vtkSMInteractionUndoStackBuilder::SetRenderView | ( | vtkSMRenderViewProxy * | ) |
void vtkSMInteractionUndoStackBuilder::Clear | ( | ) |
void vtkSMInteractionUndoStackBuilder::StartInteraction | ( | ) |
Usually, this method isn't called directly, since the builder listens to interaction events on the interactor and calls it automatically. May be used when changing the camera programmatically.
void vtkSMInteractionUndoStackBuilder::EndInteraction | ( | ) |
Event handler.
friend |
Definition at line 87 of file vtkSMInteractionUndoStackBuilder.h.
Definition at line 76 of file vtkSMInteractionUndoStackBuilder.h.
Definition at line 77 of file vtkSMInteractionUndoStackBuilder.h.
Definition at line 78 of file vtkSMInteractionUndoStackBuilder.h.
