iterates over all registered proxies (and groups) More...
#include <vtkSMProxyIterator.h>
enum | TraversalMode { GROUPS_ONLY = 0, ONE_GROUP = 1, ALL = 2 } |
void | SetSessionProxyManager (vtkSMSessionProxyManager *) |
Override the set session so the SessionProxyManager could be cache for. More... | |
void | SetSession (vtkSMSession *session) |
Convenience method. More... | |
void | Begin () |
Go to the beginning of the collection. More... | |
void | Begin (const char *groupName) |
Go to the beginning of one group, and set mode to iterate over one group. More... | |
int | IsAtEnd () |
Is the iterator pointing past the last element? More... | |
void | Next () |
Move to the next property. More... | |
const char * | GetGroup () |
Get the group at the current iterator location. More... | |
const char * | GetKey () |
Get the key (proxy name) at the current iterator location. More... | |
vtkSMProxy * | GetProxy () |
Get the proxy at the current iterator location. More... | |
virtual void | SetMode (int) |
The traversal mode for the iterator. More... | |
virtual int | GetMode () |
void | SetModeToGroupsOnly () |
void | SetModeToOneGroup () |
void | SetModeToAll () |
virtual void | SetSkipPrototypes (bool) |
When set to true (default), the iterator will skip prototype proxies. More... | |
virtual bool | GetSkipPrototypes () |
virtual void | SkipPrototypesOn () |
virtual void | SkipPrototypesOff () |
virtual void | Modified () |
static vtkSMProxyIterator * | New () |
static vtkSMProxyIterator * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMProxyIterator () | |
~vtkSMProxyIterator () override | |
void | NextInternal () |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
bool | SkipPrototypes |
int | Mode |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMProxyIterator iterates over all proxies registered with the proxy manager. It can also iterate over groups.
Definition at line 25 of file vtkSMProxyIterator.h.
Definition at line 29 of file vtkSMProxyIterator.h.
Enumerator | |
GROUPS_ONLY | |
ONE_GROUP | |
ALL |
Definition at line 101 of file vtkSMProxyIterator.h.
void vtkSMProxyIterator::SetSessionProxyManager | ( | vtkSMSessionProxyManager * | ) |
void vtkSMProxyIterator::SetSession | ( | vtkSMSession * | session | ) |
Convenience method.
Internally calls this->SetSessionProxyManager(session->GetSessionProxyManager());
void vtkSMProxyIterator::Begin | ( | ) |
void vtkSMProxyIterator::Begin | ( | const char * | groupName | ) |
int vtkSMProxyIterator::IsAtEnd | ( | ) |
void vtkSMProxyIterator::Next | ( | ) |
const char* vtkSMProxyIterator::GetGroup | ( | ) |
const char* vtkSMProxyIterator::GetKey | ( | ) |
vtkSMProxy* vtkSMProxyIterator::GetProxy | ( | ) |
If the traversal mode is set to GROUPS, each Next() will move to the next group, in ONE_GROUP mode, all proxies in one group are visited and finally in ALL mode, all proxies are visited.
Definition at line 87 of file vtkSMProxyIterator.h.
Definition at line 88 of file vtkSMProxyIterator.h.
Definition at line 89 of file vtkSMProxyIterator.h.
Definition at line 112 of file vtkSMProxyIterator.h.
Definition at line 113 of file vtkSMProxyIterator.h.
