Point tooltip mode enables the user to inspect points (coordinates, data array values) by hovering the mouse cursor over a point. More...
#include <vtkSMTooltipSelectionPipeline.h>
typedef vtkSMPreselectionPipeline | Superclass |
bool | CanDisplayTooltip (bool &showTooltip) |
Return true if a tooltip can be displayed according to the context, otherwise return false. More... | |
void | Hide (vtkSMRenderViewProxy *view) override |
Re-implemented from vtkSMPreselectionPipeline. More... | |
void | Show (vtkSMSourceProxy *sourceRepresentation, vtkSMSourceProxy *selection, vtkSMRenderViewProxy *view) override |
bool | GetTooltipInfo (int association, std::string &tooltipText) |
Get information about the tooltip to be displayed in a HTML formated string. More... | |
bool | GetTooltipInfo (int association, std::string &tooltipText, std::string &plainTooltipText) |
void | CopyLabels (vtkSMProxy *representation) |
Copies the labels for interactive selection from the selection labels in the representation parameter. More... | |
virtual vtkSMProxy * | GetSelectionRepresentation () const |
Get/Create the interactive selection representation. More... | |
virtual vtkSMProxy * | GetOrCreateSelectionRepresentation () |
virtual vtkSMProxy * | CreateSelectionRepresentation (vtkSMSourceProxy *extract, vtkSMRenderViewProxy *view) |
virtual vtkSMProxy * | CreateSelectionRepresentation (vtkSMSourceProxy *extract) |
virtual void | Modified () |
vtkSMTooltipSelectionPipeline () | |
~vtkSMTooltipSelectionPipeline () override | |
void | ClearCache () override |
vtkDataObject * | ConnectPVMoveSelectionToClient (vtkSMSourceProxy *source, unsigned int sourceOutputPort) |
Connect the ClientServerMoveData filter to the pipeline to get the selection on the client side. More... | |
bool | GetCurrentSelectionId (vtkSMRenderViewProxy *view, vtkIdType &selId) |
Get the id of the selected point. More... | |
vtkDataSet * | FindDataSet (vtkDataObject *dataObject, bool &compositeFound, std::string &compositeName) |
Extract dataset from the dataObject, which can be either directly a dataset or a composite dataset containing only one dataset. More... | |
vtkSMPreselectionPipeline () | |
~vtkSMPreselectionPipeline () override | |
vtkSMSourceProxy * | ConnectPVExtractSelection (vtkSMSourceProxy *source, unsigned int sourceOutputPort, vtkSMSourceProxy *selection) |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkSmartPointer< vtkSMProxy > | DataMover |
vtkIdType | PreviousSelectionId |
bool | SelectionFound |
bool | TooltipEnabled |
vtkSMSourceProxy * | ExtractInteractiveSelection |
vtkSMProxy * | SelectionRepresentation |
vtkWeakPointer< vtkSMRenderViewProxy > | PreviousView |
vtkWeakPointer< vtkSMSourceProxy > | PreviousRepresentation |
vtkCallbackCommand * | ColorObserver |
vtkCallbackCommand * | ConnectionObserver |
bool | Debug |
vtkTimeStamp | MTime |
static void | OnColorModified (vtkObject *source, unsigned long eid, void *clientdata, void *calldata) |
static void | ClearCache (vtkObject *source, unsigned long eid, void *clientdata, void *calldata) |
This is a global object that holds the pipeline for showing the point tooltip mode.
Definition at line 28 of file vtkSMTooltipSelectionPipeline.h.
Definition at line 32 of file vtkSMTooltipSelectionPipeline.h.
Reimplemented from vtkSMPreselectionPipeline.
bool vtkSMTooltipSelectionPipeline::CanDisplayTooltip | ( | bool & | showTooltip | ) |
The argument showTooltip is true if the tooltip must be shown, false if the tooltip must be hidden.
bool vtkSMTooltipSelectionPipeline::GetTooltipInfo | ( | int | association, |
std::string & | tooltipText | ||
tooltipText received a HTML formatted string, while plainTooltipText receive a plain text version. Return false if the method failed computing information.
std::string & | tooltipText, | ||
std::string & | plainTooltipText | ||
overrideprotectedvirtual |
Definition at line 90 of file vtkSMTooltipSelectionPipeline.h.
Definition at line 91 of file vtkSMTooltipSelectionPipeline.h.
Definition at line 92 of file vtkSMTooltipSelectionPipeline.h.
Definition at line 93 of file vtkSMTooltipSelectionPipeline.h.
