pqContextView.h
4 #ifndef pqContextView_h
5 #define pqContextView_h
6
7 #include "pqView.h"
8 #include "vtkType.h"
9
11 class vtkContextView;
12 class vtkObject;
13 class vtkSelection;
14
20 {
21  Q_OBJECT
22  typedef pqView Superclass;
23
24 public:
25  ~pqContextView() override;
26
31  virtual vtkContextView* getVTKContextView() const;
32
36  virtual vtkSMContextViewProxy* getContextViewProxy() const;
37
41  virtual bool supportsSelection() const;
42
48  bool supportsCapture() const override { return true; }
49
54  // Default is vtkChart::SELECT_RECTANGLE
55  virtual void setSelectionAction(int selAction);
56  virtual int selectionAction();
57
61  void resetDisplay(bool closest = false) override;
62
63 protected Q_SLOTS:
65
70  void startInteraction();
71  void endInteraction();
73
74 protected: // NOLINT(readability-redundant-access-specifiers)
84  pqContextView(const QString& type, const QString& group, const QString& name,
85  vtkSMViewProxy* view, pqServer* server, QObject* parent = nullptr);
86
91  QWidget* createWidget() override;
92
96  virtual void selectionChanged();
97
101  virtual void setSelection(vtkSelection*);
102  class command;
103  command* Command;
104
105 private:
106  Q_DISABLE_COPY(pqContextView)
107
108  class pqInternal;
109  pqInternal* Internal;
110 };
111
112 #endif
type
pqContextView is an abstract base class for all charting views based on the VTK context charting libr...
Definition: pqContextView.h:19
Superclass for all view proxies.
This is a PQ abstraction of a generic view module.
Definition: pqView.h:26
name
#define PQCORE_EXPORT
Definition: pqCoreModule.h:15
abstract base class for all Chart Views.
command * Command
virtual void resetDisplay(bool closest=false)
Called to reset the view's display.
Definition: pqView.h:116
virtual QWidget * createWidget()=0
Subclasses must override this method to create a widget for the view.
pqServer (should be renamed to pqSession) is a pqServerManagerModelItem subclass that represents a vt...
Definition: pqServer.h:35
Returns if this view module can support image capture.
Definition: pqContextView.h:48
