19 #ifndef vtkXYChartRepresentation_h 20 #define vtkXYChartRepresentation_h 48 vtkSetMacro(ChartType,
int);
49 vtkGetMacro(ChartType,
int);
52 void SetChartTypeToLine();
53 void SetChartTypeToPoints();
54 void SetChartTypeToBar();
55 void SetChartTypeToStacked();
56 void SetChartTypeToBag();
57 void SetChartTypeToFunctionalBag();
58 void SetChartTypeToArea();
71 vtkSetStringMacro(XAxisSeriesName);
72 vtkGetStringMacro(XAxisSeriesName);
80 vtkSetMacro(UseIndexForXAxis,
bool);
81 vtkGetMacro(UseIndexForXAxis,
bool);
90 void SetSortDataByXAxis(
bool val);
91 vtkGetMacro(SortDataByXAxis,
bool);
98 void SetSeriesVisibility(
const char* seriesname,
bool visible);
99 void SetLineThickness(
const char* name,
double value);
100 void SetLineStyle(
const char* name,
int value);
101 void SetColor(
const char* name,
double r,
double g,
double b);
102 void SetOpacity(
double opacity);
103 void SetAxisCorner(
const char* name,
int corner);
104 void SetMarkerStyle(
const char* name,
int style);
105 void SetMarkerSize(
const char* name,
double value);
106 void SetLabel(
const char* name,
const char* label);
107 void SetUseColorMapping(
const char* name,
bool useColorMapping);
109 const char* GetLabel(
const char* name)
const;
112 void ClearSeriesVisibilities();
113 void ClearLineThicknesses();
114 void ClearLineStyles();
116 void ClearOpacities();
117 void ClearAxisCorners();
118 void ClearMarkerSizes();
119 void ClearMarkerStyles();
122 vtkSetVector3Macro(SelectionColor,
double);
123 vtkGetVector3Macro(SelectionColor,
double);
129 vtkSetStringMacro(SeriesLabelPrefix);
130 vtkGetStringMacro(SeriesLabelPrefix);
164 class SortTableFilter;
171 char* XAxisSeriesName;
172 bool UseIndexForXAxis;
173 bool SortDataByXAxis;
174 bool PlotDataHasChanged;
175 double SelectionColor[3];
176 char* SeriesLabelPrefix;
static vtkChartRepresentation * New()
virtual void PrepareForRendering()
This method is called before actual render if this->MTime was modified since the last time this metho...
vtkXYChartRepresentation is representation that is used to add vtkPlot subclasses to a vtkChartXY ins...
void SetVisibility(bool visible) override
Set visibility of the representation.
virtual vtkSmartPointer< vtkDataObject > TransformTable(vtkSmartPointer< vtkDataObject > table)
Method to be overridden to apply an operation of the table after it is gathered to the first rank for...
virtual bool Export(vtkAbstractChartExporter *vtkNotUsed(exporter))
Called by vtkPVContextView::Export() to export the representation's data to a CSV file...
vtkChartRepresentation is the base representation for charting representations.
int ProcessViewRequest(vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo) override
exporter used by certain views to export data into a file or stream.
bool RemoveFromView(vtkView *view) override
int RequestData(vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
Subclasses should override this to connect inputs to the internal pipeline as necessary.
