1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Remoting/Misc 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkPVEnsembleDataReaderInformation.h" 48 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkPVMultiServerDataSource.h" 49 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkSMCameraConfigurationReader.h" 50 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkSMCameraConfigurationWriter.h" 51 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkSMEnsembleDataReaderProxy.h" 52 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkSMExtractSelectionProxyInitializationHelper.h" 53 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkSMInteractionUndoStackBuilder.h" 54 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkSMInteractiveSelectionPipeline.h" 55 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkSMMultiServerSourceProxy.h" 56 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkSMOMETIFFChannelCalculatorInitializationHelper.h" 57 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkSMPLYWriterProxyInitializationHelper.h" 58 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkSMPreselectionPipeline.h" 59 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkSMProxyClipboard.h" 60 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkSMProxyConfigurationReader.h" 61 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkSMProxyConfigurationWriter.h" 62 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkSMTesting.h" 63 "/builds/gitlab-kitware-sciviz-ci/Remoting/Misc/vtkSMTooltipSelectionPipeline.h" 64 "/builds/gitlab-kitware-sciviz-ci/build/Remoting/Misc/vtkRemotingMiscModule.h" 68 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 69 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkRemotingMisc-hierarchy.txt
vtk/hierarchy/ParaView/vtkRemotingMisc-hierarchy.txt
") 72 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 74 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingMisc-pv5.13.so.5.13
" 75 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingMisc-pv5.13.so.1
" 77 if(EXISTS "${file}
" AND 78 NOT IS_SYMLINK "${file}
") 81 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 84 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 85 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingMisc-pv5.13.so.5.13
" 86 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingMisc-pv5.13.so.1
" 89 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingMisc-pv5.13.so.5.13
" 90 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingMisc-pv5.13.so.1
" 92 if(EXISTS "${file}
" AND 93 NOT IS_SYMLINK "${file}
") 96 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 97 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 98 if(CMAKE_INSTALL_DO_STRIP) 99 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 105 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 106 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingMisc-pv5.13.so
" AND 107 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingMisc-pv5.13.so
") 109 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingMisc-pv5.13.so
" 110 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 112 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingMisc-pv5.13.so
") 113 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingMisc-pv5.13.so
" AND 114 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingMisc-pv5.13.so
") 116 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingMisc-pv5.13.so
" 117 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 118 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 119 if(CMAKE_INSTALL_DO_STRIP) 120 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingMisc-pv5.13.so
