custom property widget using vtkBoxWidget2 and vtkBoxRepresentation. More...
#include <pqBoxPropertyWidget.h>
| pqBoxPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr, bool hideReferenceBounds=false) | |
| ~pqBoxPropertyWidget () override | |
| void | apply () override |
| Applies unchecked values; in matrix mode parses text to properties and refreshes. More... | |
Public Member Functions inherited from pqInteractivePropertyWidget | |
| pqInteractivePropertyWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) | |
| ~pqInteractivePropertyWidget () override | |
| vtkSMNewWidgetRepresentationProxy * | widgetProxy () const |
| Returns the proxy for the 3D interactive widget. More... | |
Public Member Functions inherited from pqInteractivePropertyWidgetAbstract | |
| pqInteractivePropertyWidgetAbstract (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) | |
| ~pqInteractivePropertyWidgetAbstract () override | |
| void | reset () override |
| Overridden to call this->render() to ensure that the widget is redrawn. More... | |
| void | setView (pqView *view) override |
| Overridden to show the widget proxy in the new view. More... | |
| bool | isWidgetVisible () const |
| Returns the interactive widget's visibility. More... | |
| vtkSMProxy * | dataSource () const |
| Returns the data source. More... | |
| vtkBoundingBox | dataBounds (bool visibleOnly=false) const |
| Returns bounds from the dataSource, if possible. More... | |
| vtkSMPropertyGroup * | propertyGroup () const |
| Returns the vtkSMPropertyGroup pass to the constructor. More... | |
| void | hideEvent (QHideEvent *) override |
| Overriden in order to hide the VTK widget. More... | |
| void | showEvent (QShowEvent *) override |
| Overriden in order to show the VTK widget. More... | |
| void | select () override |
| In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More... | |
| void | deselect () override |
| void | selectPort (int portIndex) final |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | setReadOnly (bool readOnly) |
| Set widget in read-only mode. More... | |
Protected Slots | |
| void | placeWidget () override |
| Places the interactive widget using current data source information. More... | |
Protected Slots inherited from pqInteractivePropertyWidgetAbstract | |
| virtual void | placeWidget ()=0 |
| void | render () |
| Safe call render on the view. More... | |
| virtual void | updateWidgetVisibility () |
| This method is called to update the state of Visibility and Enabled properties on the widget based on the state of isWidgetVisible(), isSelected() and the active view. More... | |
Public Slots inherited from pqInteractivePropertyWidgetAbstract | |
| virtual void | setWidgetVisible (bool val) |
| Toggle the interactive widget's visibility. More... | |
| void | setDataSource (vtkSMProxy *dataSource) |
| DataSource is used by interactive widgets to determine now to place the widget in the view e.g. More... | |
Signals inherited from pqInteractivePropertyWidgetAbstract | |
| void | widgetVisibilityToggled (bool) |
| Fired whenever setWidgetVisible() changes the widget's visibility. More... | |
| void | widgetVisibilityUpdated (bool) |
| Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More... | |
| void | startInteraction () |
| Fired by the underlying interactive widget representation proxy, for each respective events. More... | |
| void | interaction () |
| void | endInteraction () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
Protected Member Functions inherited from pqInteractivePropertyWidget | |
| vtkSMNewWidgetRepresentationProxyAbstract * | internalWidgetProxy () final |
| Get the internal instance of the widget proxy. More... | |
Protected Member Functions inherited from pqInteractivePropertyWidgetAbstract | |
| void | setupConnections (vtkSMNewWidgetRepresentationProxyAbstract *widget, vtkSMPropertyGroup *smgroup, vtkSMProxy *smproxy) |
| Setup all the links and events for the given widget and SM property group. More... | |
| void | setupUserObserver (vtkSMProxy *smproxy) |
Protected Attributes inherited from pqInteractivePropertyWidgetAbstract | |
| bool | VisibleState = true |
| bool | WidgetVisibility = false |
| int | LinkedPortIndex = -1 |
Properties inherited from pqInteractivePropertyWidgetAbstract | |
| pqSMProxy | dataSource |
pqBoxPropertyWidget is a custom property widget that uses "BoxWidgetRepresentation" to help users interactively set the origin, orientation and scale for an oriented bounding box.
To use this widget for a property group (vtkSMPropertyGroup), use "InteractiveBox" as the "panel_widget" in the XML configuration for the proxy. The property group should have properties for following functions (all of which are optional):
UseReferenceBounds and ReferenceBounds must be used together i.e. both are required for this to work.
The constructor accepts a boolean "hideReferenceBounds" to toggle the visibility of reference bounds items. This is useful when reference bounds are fixed by an external entity that doesn't want the user to modify it.
Note while all of the above are optional, it really doesn't make much sense to use this widget if any of them are not specified.
In addition to the PRS editors, this widget also provides a "Matrix" tab to edit the transform as a 4×4 matrix. The tab is enabled only when the "Position", "Rotation" and "Scale" properties are available on the group. The 4×4 values are converted to/from PRS; a dedicated 16‑element "Matrix" property is not required.
Definition at line 57 of file pqBoxPropertyWidget.h.
| pqBoxPropertyWidget::pqBoxPropertyWidget | ( | vtkSMProxy * | proxy, |
| vtkSMPropertyGroup * | smgroup, | ||
| QWidget * | parent = nullptr, |
| bool | hideReferenceBounds = false |
Reimplemented from pqPropertyWidget.
overrideprotectedslot |
1.8.13 on Sun Dec 14 2025
