property representing a vector of doubles More...
#include <vtkSMDoubleVectorProperty.h>
typedef vtkSMVectorProperty | Superclass |
typedef vtkSMProperty | Superclass |
unsigned int | GetNumberOfElements () override |
Returns the size of the vector. More... | |
void | SetNumberOfElements (unsigned int num) override |
Sets the size of the vector. More... | |
int | SetElement (unsigned int idx, double value) |
Set the value of 1 element. More... | |
int | SetElements1 (double value0) |
Set the value of 1st element. More... | |
int | SetElements2 (double value0, double value1) |
Set the values of the first 2 elements. More... | |
int | SetElements3 (double value0, double value1, double value2) |
Set the values of the first 3 elements. More... | |
int | SetElements4 (double value0, double value1, double value2, double value3) |
Set the values of the first 4 elements. More... | |
int | AppendElements (const double *values, unsigned int numValues) |
Append the values. More... | |
int | AppendUncheckedElements (const double *values, unsigned int numValues) |
Append the values to the unchecked elements. More... | |
double | GetElement (unsigned int idx) |
Returns the value of 1 element. More... | |
unsigned int | GetNumberOfUncheckedElements () override |
Returns the size of unchecked elements. More... | |
double | GetUncheckedElement (unsigned int idx) |
Returns the value of 1 unchecked element. More... | |
void | SetUncheckedElement (unsigned int idx, double value) |
Set the value of 1 unchecked element. More... | |
void | Copy (vtkSMProperty *src) override |
Copy all property values. More... | |
void | ClearUncheckedElements () override |
API for setting unchecked element values. More... | |
bool | IsValueDefault () override |
Returns true if the property's value is different from the default value. More... | |
void | ResetToXMLDefaults () override |
For properties that support specifying defaults in XML configuration, this method will reset the property value to the default values specified in the XML. More... | |
int | SetElements (const double *values) |
Set the values of all elements. More... | |
int | SetElements (const double *values, unsigned int numValues) |
double * | GetElements () |
int | SetUncheckedElements (const double *values) |
Sets the values of all the unchecked elements. More... | |
int | SetUncheckedElements (const double *values, unsigned int numValues) |
virtual int | GetArgumentIsArray () |
If ArgumentIsArray is true, multiple elements are passed in as array arguments. More... | |
virtual void | SetArgumentIsArray (int) |
virtual void | SetInitialString (const char *) |
virtual char * | GetInitialString () |
bool | ResetToDomainDefaults (bool use_unchecked_values=false) override |
Overridden to add support to load defaults from this->GetInformationProperty(), if one exists. More... | |
virtual int | GetRepeatCommand () |
If RepeatCommand is true, the command is invoked multiple times, each time with NumberOfElementsPerCommand values. More... | |
virtual void | SetRepeatCommand (int) |
virtual void | RepeatCommandOn () |
virtual void | RepeatCommandOff () |
virtual int | GetNumberOfElementsPerCommand () |
virtual void | SetNumberOfElementsPerCommand (int) |
virtual int | GetUseIndex () |
If UseIndex and RepeatCommand are true, the property will add an index integer before each command. More... | |
virtual void | SetUseIndex (int) |
virtual void | UseIndexOn () |
virtual void | UseIndexOff () |
virtual void | SetCleanCommand (const char *) |
Command that can be used to remove all values. More... | |
virtual char * | GetCleanCommand () |
virtual void | SetSetNumberCommand (const char *) |
If SetNumberCommand is set, it is called before Command with the number of arguments as the parameter. More... | |
virtual char * | GetSetNumberCommand () |
int | IsInDomains () |
Returns true if all values are in all domains, false otherwise. More... | |
int | IsInDomains (vtkSMDomain **domain) |
Overload of IsInDomains() that provides a mechanism to return the first domain that fails the check. More... | |
void | UnRegister (vtkObjectBase *obj) override |
Overloaded to break the reference loop caused by the internal domain iterator. More... | |
vtkSMDomainIterator * | NewDomainIterator () |
Creates, initializes and returns a new domain iterator. More... | |
vtkSMDomain * | GetDomain (const char *name) |
Returns a domain give a name. More... | |
vtkSMDomain * | FindDomain (const char *classname) |
Returns the first domain which is of the specified type. More... | |
template<class DomainType > | |
DomainType * | FindDomain () |
Same as FindDomain(classname), except the classname is deduced from the type. More... | |
unsigned int | GetNumberOfDomains () |
Returns the number of domains this property has. More... | |
void | AddDomain (const char *name, vtkSMDomain *dom) |
Properties can have one or more domains. More... | |
virtual void | AddLinkedProperty (vtkSMProperty *targetProperty) |
Add a link to a property whose value should be synchronized with this property value. More... | |
virtual void | RemoveLinkedProperty (vtkSMProperty *targetProperty) |
Remove a link to a property added with AddLinkedProperty() More... | |
virtual void | RemoveFromSourceLink () |
Remove a link from the source property. More... | |
void | ResetToDefault () |
Simply calls this->ResetToDomainDefaults() and if that returns false, calls this->ResetToXMLDefaults(). More... | |
bool | ResetToSettings (double priority) |
Reset property value with settings. More... | |
vtkSMProxy * | GetParent () |
Get the proxy to which this property belongs. More... | |
virtual bool | IsStateIgnored () |
bool | HasDomainsWithRequiredProperties () |
Returns true if the property has a domain with required properties. More... | |
virtual void | SetCommand (const char *) |
The command name used to set the value on the server object. More... | |
virtual char * | GetCommand () |
virtual void | SetImmediateUpdate (int) |
If ImmediateUpdate is true, the value of the property will be pushed to the server as soon as it is modified. More... | |
virtual int | GetImmediateUpdate () |
virtual int | GetInformationOnly () |
Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More... | |
virtual int | GetIgnoreSynchronization () |
If IgnoreSynchronization is set to true, this property is used to prevent that property from being updated when changed remotely by another collaborative client. More... | |
virtual vtkSMProperty * | GetInformationProperty () |
Get the associated information property. More... | |
virtual void | SetAnimateable (int) |
Get/Set if the property is animateable. More... | |
virtual int | GetAnimateable () |
virtual void | SetIsInternal (int) |
Get/Set if the property is internal to server manager. More... | |
virtual int | GetIsInternal () |
virtual void | SetNoCustomDefault (int) |
Set/Get whether the property should ignore custom default settings. More... | |
virtual int | GetNoCustomDefault () |
virtual void | SetPanelVisibility (const char *) |
Set/Get the panel visibility for the property. More... | |
virtual char * | GetPanelVisibility () |
virtual void | SetPanelVisibilityDefaultForRepresentation (const char *) |
Set/Get the panel visibility to default if the current representation type matches representation . More... | |
virtual char * | GetPanelVisibilityDefaultForRepresentation () |
virtual void | SetPanelWidget (const char *) |
Set/Get the name of the custom panel widget to use for the property. More... | |
virtual char * | GetPanelWidget () |
virtual void | SetDisableSubTrace (const char *) |
Set/Get the tracing of sub property of this property. More... | |
virtual char * | GetDisableSubTrace () |
Returns the documentation for this proxy. More... | |
The label assigned by the xml parser. More... | |
The name assigned by the xml parser. More... | |
virtual int | GetRepeatable () |
If repeatable, a property can have 1 or more values of the same kind. More... | |
The server manager configuration XML may define <Hints/> element for a property. More... | |
void | SetHints (vtkPVXMLElement *hints) |
void | Modified () override |
Overridden to support blocking of modified events. More... | |
static vtkSMDoubleVectorProperty * | New () |
static vtkSMDoubleVectorProperty * | SafeDownCast (vtkObject *o) |
static vtkSMVectorProperty * | SafeDownCast (vtkObject *o) |
static vtkSMProperty * | New () |
static vtkSMProperty * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMDoubleVectorProperty () | |
~vtkSMDoubleVectorProperty () override | |
void | WriteTo (vtkSMMessage *) override |
Let the property write its content into the stream. More... | |
void | ReadFrom (const vtkSMMessage *, int msg_offset, vtkSMProxyLocator *) override |
Let the property read and set its content from the stream. More... | |
int | ReadXMLAttributes (vtkSMProxy *parent, vtkPVXMLElement *element) override |
Set the appropriate ivars from the xml element. More... | |
void | SetNumberOfUncheckedElements (unsigned int num) override |
Sets the size of unchecked elements. More... | |
int | LoadState (vtkPVXMLElement *element, vtkSMProxyLocator *loader) override |
Load the XML state. More... | |
void | SaveStateValues (vtkPVXMLElement *propElement) override |
This method must be overridden by concrete class in order to save the real property data. More... | |
vtkSMVectorProperty () | |
~vtkSMVectorProperty () override | |
vtkSMProperty () | |
~vtkSMProperty () override | |
virtual void | ReadFrom (const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *) |
virtual void | UpdateAllInputs () |
Update all proxies referred by this property (if any). More... | |
vtkSMProperty * | NewProperty (const char *name) |
Internal. More... | |
void | AddDependent (vtkSMDomain *dom) |
void | RemoveAllDependents () |
Removes all dependents. More... | |
void | UpdateDomains () |
Calls Update() on all domains contained by the property as well as all dependent domains. More... | |
virtual void | SaveState (vtkPVXMLElement *parent, const char *property_name, const char *uid, int saveDomains=1) |
Save the property state in XML. More... | |
virtual void | SaveDomainState (vtkPVXMLElement *propertyElement, const char *uid) |
Save property domain. More... | |
virtual void | SetXMLLabel (const char *) |
virtual void | SetInformationOnly (int) |
virtual void | SetIgnoreSynchronization (int) |
void | SetInformationProperty (vtkSMProperty *ip) |
void | SetDocumentation (vtkSMDocumentation *) |
void | SetParent (vtkSMProxy *proxy) |
virtual void | SetStateIgnored (bool) |
virtual void | StateIgnoredOn () |
virtual void | StateIgnoredOff () |
bool | SetBlockModifiedEvents (bool block) |
Block/unblock modified events, returns the current state of the block flag. More... | |
virtual bool | GetPendingModifiedEvents () |
Returns if any modified evetns are pending. More... | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Friends | |
class | vtkSMRenderViewProxy |
vtkSMDoubleVectorProperty is a concrete sub-class of vtkSMVectorProperty representing a vector of doubles.
Definition at line 21 of file vtkSMDoubleVectorProperty.h.
Definition at line 25 of file vtkSMDoubleVectorProperty.h.
Reimplemented from vtkSMVectorProperty.
Implements vtkSMVectorProperty.
If num is larger than the current number of elements, this may cause reallocation and copying.
The vector is resized as necessary. Returns 0 if Set fails either because the property is read only or the value is not in all domains. Returns 1 otherwise.
The size of the values array has to be equal or larger to the size of the vector. Returns 0 if Set fails either because the property is read only or one or more of the values is not in all domains. Returns 1 otherwise.
double* vtkSMDoubleVectorProperty::GetElements | ( | ) |
int vtkSMDoubleVectorProperty::SetUncheckedElements | ( | const double * | values, |
unsigned int | numValues | ||
The vector is resized as necessary. Returns 0 if Set fails either because the property is read only or one or more of the values is not in all domains. Returns 1 otherwise.
int vtkSMDoubleVectorProperty::SetElements4 | ( | double | value0, |
double | value1, | ||
double | value2, | ||
double | value3 | ||
Append the values.
int vtkSMDoubleVectorProperty::AppendUncheckedElements | ( | const double * | values, |
Usually this is the same as the number of elements but can be different before a domain check is performed.
These are used by domains. SetElement() first sets the value of 1 unchecked element and then calls IsInDomain and updates the value of the corresponding element only if IsInDomain passes.
This can be used to check if a value is in all domains of the property. Call this and call IsInDomains().
For example, For example, if RepeatCommand is true, NumberOfElementsPerCommand is 2, the command is SetFoo and the values are 1 2 3 4 5 6, the resulting stream will have:
* * Invoke obj SetFoo array(1, 2) * * Invoke obj SetFoo array(3, 4) * * Invoke obj SetFoo array(5, 6) *
Reimplemented from vtkSMProperty.
overrideprotectedvirtual |
Load the XML state.
friend |
Definition at line 173 of file vtkSMDoubleVectorProperty.h.
Definition at line 187 of file vtkSMDoubleVectorProperty.h.
