| pqComparativeRenderView (const QString &group, const QString &name, vtkSMViewProxy *renModule, pqServer *server, QObject *parent=nullptr) |
| ~pqComparativeRenderView () override |
vtkSMComparativeViewProxy * | getComparativeRenderViewProxy () const |
| Returns the comparative view proxy. More...
vtkSMRenderViewProxy * | getRenderViewProxy () const override |
| Returns the root render view in the comparative view. More...
| pqRenderView (const QString &group, const QString &name, vtkSMViewProxy *renModule, pqServer *server, QObject *parent=nullptr) |
| pqRenderView (const QString &tname, const QString &group, const QString &name, vtkSMViewProxy *renModule, pqServer *server, QObject *parent=nullptr) |
| ~pqRenderView () override |
void | resetCamera (bool closest=false, double offsetRatio=0.9) override |
| Resets the camera to include all visible data. More...
virtual void | resetCenterOfRotation () |
| Resets the center of rotation to the focal point. More...
virtual void | resetParallelScale () |
| Resets the parallel scale which is used for a parallel projection. More...
virtual bool | getOrientationAxesVisibility () const |
| Get if the orientation axes is visible. More...
virtual bool | getOrientationAxesInteractivity () const |
| Get if the orientation axes is interactive. More...
virtual QColor | getOrientationAxesLabelColor () const |
| Get orientation axes label color. More...
virtual QColor | getOrientationAxesOutlineColor () const |
| Get orientation axes outline color. More...
virtual bool | getResetCenterWithCamera () const |
| Get whether resetCamera() resets the center of rotation as well. More...
virtual bool | getUseMultipleRepresentationSelection () const |
| Get whether selection will be done on multiple representations. More...
virtual bool | getCenterAxesVisibility () const |
| Get center axes visibility. More...
virtual void | getCenterOfRotation (double center[3]) const |
| Get the current center of rotation. More...
bool | supportsUndo () const override |
| Returns if this view module can support undo/redo. More...
bool | supportsCapture () const override |
| Returns if this view module can support image capture. More...
virtual void | clearUndoStack () |
| Clears interaction undo stack of this view (and all linked views, if any). More...
virtual void | resetViewDirection (double look_x, double look_y, double look_z, double up_x, double up_y, double up_z) |
| Reset/Adjust camera view direction. More...
virtual void | adjustView (const int &adjustType, const double &angle) |
virtual void | adjustAzimuth (const double &value) |
virtual void | adjustElevation (const double &value) |
virtual void | adjustRoll (const double &value) |
virtual void | adjustZoom (const double &value) |
virtual void | applyIsometricView () |
virtual void | resetViewDirectionToPositiveX () |
virtual void | resetViewDirectionToNegativeX () |
virtual void | resetViewDirectionToPositiveY () |
virtual void | resetViewDirectionToNegativeY () |
virtual void | resetViewDirectionToPositiveZ () |
virtual void | resetViewDirectionToNegativeZ () |
virtual pqDataRepresentation * | pick (int pos[2]) |
| Picks the representation at the given position. More...
virtual pqDataRepresentation * | pickBlock (int pos[2], unsigned int &flatIndex, int &rank) |
virtual void | selectBlock (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT) |
| Creates a "block" selection given the rectangle in display coordinates. More...
bool | canUndo () const override |
| Returns if the view module can undo/redo interaction given the current state of the interaction undo stack. More...
bool | canRedo () const override |
virtual void | linkUndoStack (pqRenderView *other) |
| For linking of interaction undo stacks. More...
virtual void | unlinkUndoStack (pqRenderView *other) |
virtual void | setCursor (const QCursor &) |
| Let internal class handle which internal widget should change its cursor This is usually used for selection and in case of QuadView/SliceView which contains an aggregation of QWidget, we don't necessary want all of them to share the same cursor. More...
virtual QCursor | cursor () |
void | setCursorVisible (bool visible) |
| Set / get the cursor visibility when the mouse hovers the widget associated with this view. More...
bool | cursorVisible () |
virtual void | selectCellsOnSurface (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT, const char *array=nullptr) |
virtual void | selectPointsOnSurface (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT, const char *array=nullptr) |
virtual void | selectFrustumCells (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT) |
virtual void | selectFrustumPoints (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT) |
virtual void | selectFrustumBlocks (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT) |
virtual void | selectPolygonPoints (vtkIntArray *polygon, int selectionModifier=pqView::PV_SELECTION_DEFAULT) |
| Creates a new surface selection given the polygon in display coordinates. More...
virtual void | selectPolygonCells (vtkIntArray *polygon, int selectionModifier=pqView::PV_SELECTION_DEFAULT) |
| ~pqRenderViewBase () override |
void | resetDisplay (bool closest=false) override |
| Called to reset the view's display. More...
| ~pqView () override |
vtkSMViewProxy * | getViewProxy () const |
| Returns the internal render Module proxy associated with this object. More...
virtual vtkView * | getClientSideView () const |
| Return the client-side vtkView encapsulated by this view (if any), or return nullptr. More...
QWidget * | widget () |
| Return a widget associated with this view. More...
QString | getViewType () const |
| Returns the type of this view module. More...
virtual QSize | getSize () |
| Returns the current size of the rendering context. More...
bool | hasRepresentation (pqRepresentation *repr) const |
| This method checks if the representation is shown in this view. More...
int | getNumberOfRepresentations () const |
| Returns the number representations in the view. More...
int | getNumberOfVisibleRepresentations () const |
int | getNumberOfVisibleDataRepresentations () const |
pqRepresentation * | getRepresentation (int index) const |
| Returns the representation for the specified index where (index < getNumberOfRepresentations()). More...
QList< pqRepresentation * > | getRepresentations () const |
| Returns a list of representations in this view. More...
bool | canDisplay (pqOutputPort *opPort) const |
| This method returns is any pqPipelineSource can be displayed in this view. More...
| pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr) |
| ~pqProxy () override |
pqServer * | getServer () const |
| Get the server on which this proxy exists. More...
void | rename (const QString &newname) |
| This is a convenience method. More...
const QString & | getSMName () |
| Get the name with which this proxy is registered on the server manager. More...
const QString & | getSMGroup () |
vtkSMProxy * | getProxy () const |
| Get the vtkSMProxy this object stands for. More...
ModifiedState | modifiedState () const |
| Gets whether or not the source has been modified. More...
void | setModifiedState (ModifiedState modified) |
| Sets whether or not the source has been modified. More...
vtkPVXMLElement * | getHints () const |
| Returns the hints for this proxy, if any. More...
QList< vtkSMProxy * > | getHelperProxies () const |
| Returns a list of all helper proxies. More...
QList< vtkSMProxy * > | getHelperProxies (const QString &key) const |
| Returns a list of all the helper proxies added with a given key. More...
QList< QString > | getHelperKeys () const |
| Returns the keys for helper proxies. More...
virtual void | addHelperProxy (const QString &key, vtkSMProxy *) |
| Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More...
void | removeHelperProxy (const QString &key, vtkSMProxy *) |
void | updateHelperProxies () const |
| Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More...
vtkSMSessionProxyManager * | proxyManager () const |
| Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More...
bool | userModifiedSMName () |
| Return whether or not the user has modified the GUI name of the source. More...
| pqServerManagerModelItem (QObject *parent=nullptr) |
| ~pqServerManagerModelItem () override |
QWidget * | createWidget () override |
| Creates a new instance of the QWidget subclass to be used to show this view. More...
virtual void | fakeUndoRedo (bool redo, bool self) |
| Updates undo stack without actually performing the undo/redo actions. More...
virtual void | fakeInteraction (bool start) |
| Updates undo stack of all linked views to record a programmatic change in camera as a interaction. More...
void | initialize () override |
| Overridden to initialize the interaction undo/redo stack. More...
| pqRenderViewBase (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *renModule, pqServer *server, QObject *parent=nullptr) |
bool | eventFilter (QObject *caller, QEvent *e) override |
| Overridden to popup the context menu, if some actions have been added using addMenuAction. More...
| Use this method to initialize the pqObject state using the underlying vtkSMProxy. More...
| pqView (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *view, pqServer *server, QObject *parent=nullptr) |
| Constructor: type :- view type. More...
void | setSMName (const QString &new_name) |
| Make this pqProxy take on a new identity. More...
virtual void | addInternalHelperProxy (const QString &key, vtkSMProxy *) const |
virtual void | removeInternalHelperProxy (const QString &key, vtkSMProxy *) const |
vtkEventQtSlotConnect * | getConnector () |
| All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More...
enum | SelectionModifier { PV_SELECTION_DEFAULT = 0,
PV_SELECTION_ADDITION,
PV_SELECTION_SUBTRACTION,
PV_SELECTION_TOGGLE
enum | ModifiedState { UNINITIALIZED,
MODIFIED,
UNMODIFIED
| The modification state of this proxy. More...
virtual void | setOrientationAxesVisibility (bool visible) |
virtual void | setOrientationAxesInteractivity (bool interactive) |
virtual void | setOrientationAxesLabelColor (const QColor &) |
virtual void | setOrientationAxesOutlineColor (const QColor &) |
virtual void | setCenterOfRotation (double x, double y, double z) |
virtual void | setCenterOfRotation (double xyz[3]) |
virtual void | setParallelScale (double scale) |
virtual void | setCenterAxesVisibility (bool visible) |
virtual void | setResetCenterWithCamera (bool b) |
| Get/Set whether resetCamera() resets the center of rotation as well. More...
virtual void | setUseMultipleRepresentationSelection (bool b) |
| Set whether selection will be done on multiple representations. More...
virtual void | linkToOtherView () |
| start the link to other view process More...
void | removeViewLinks () |
| Remove all camera link connected to this view. More...
void | undo () override |
| Called to undo interaction. More...
void | redo () override |
| Called to redo interaction. More...
virtual void | resetCenterOfRotationIfNeeded () |
| Resets center of rotation if this->ResetCenterWithCamera is true. More...
virtual void | updateInteractionMode (pqOutputPort *opPort) |
| Try to provide the best view orientation and interaction mode. More...
virtual void | render () |
| Request a StillRender on idle. More...
virtual void | forceRender () |
| Forces an immediate render. More...
void | cancelPendingRenders () |
| Cancels any pending renders. More...
virtual void | undo () |
virtual void | redo () |
void | updateInteractionMode (int mode) |
void | updateDataEvent () |
| Fired when the vtkSMViewProxy fires the vtkCommand::UpdateDataEvent The view proxy fires this event at the end of vtkSMViewProxy::Update() when the update executes, not just when the method is called. More...
void | representationAdded (pqRepresentation *) |
| Fired after a representation has been added to this view. More...
void | representationRemoved (pqRepresentation *) |
| Fired after a representation has been removed from this view. More...
void | beginRender () |
| Fired when the render module fires a vtkCommand::StartEvent signalling the beginning of rendering. More...
void | endRender () |
| Fired when the render module fires a vtkCommand::EndEvent signalling the end of rendering. More...
void | representationVisibilityChanged (pqRepresentation *repr, bool visible) |
| Fired when any representation visibility changes. More...
void | canUndoChanged (bool) |
| Fired when interaction undo stack status changes. More...
void | canRedoChanged (bool) |
void | selected (pqOutputPort *opport) |
| Fired when a selection is made in this view. More...
void | picked (pqOutputPort *opport) |
| Fired when a port is picked. More...
void | beginProgress () |
| Fired before doing any actions that may result in progress events that must be reported by the client. More...
void | endProgress () |
| Fired after performing any actions that may result in progress events. More...
void | progress (const QString &message, int percent_progress) |
| Fired to notify the current execution progress. More...
void | multipleSelected (QList< pqOutputPort *> opports) |
| Fired when UseMultipleRepresentationSelection is set to on and selection on multiple representations is made in this view. More...
void | nameChanged (pqServerManagerModelItem *) |
| Fired when the name of the proxy is changed. More...
void | modifiedStateChanged (pqServerManagerModelItem *) |
| Fired when the modified status changes for the proxy. More...
bool | ResetCenterWithCamera |
bool | UseMultipleRepresentationSelection |
RenderView used for comparative visualization (or film-strip visualization).
Definition at line 14 of file pqComparativeRenderView.h.
