| pqCylinderPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) |
| ~pqCylinderPropertyWidget () override |
| pqInteractivePropertyWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) |
| ~pqInteractivePropertyWidget () override |
vtkSMNewWidgetRepresentationProxy * | widgetProxy () const |
| Returns the proxy for the 3D interactive widget. More...
| pqInteractivePropertyWidgetAbstract (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) |
| ~pqInteractivePropertyWidgetAbstract () override |
void | reset () override |
| Overridden to call this->render() to ensure that the widget is redrawn. More...
void | setView (pqView *view) override |
| Overridden to show the widget proxy in the new view. More...
bool | isWidgetVisible () const |
| Returns the interactive widget's visibility. More...
vtkSMProxy * | dataSource () const |
| Returns the data source. More...
vtkBoundingBox | dataBounds (bool visibleOnly=false) const |
| Returns bounds from the dataSource, if possible. More...
vtkSMPropertyGroup * | propertyGroup () const |
| Returns the vtkSMPropertyGroup pass to the constructor. More...
void | hideEvent (QHideEvent *) override |
| Overriden in order to hide the VTK widget. More...
void | showEvent (QShowEvent *) override |
| Overriden in order to show the VTK widget. More...
void | select () override |
| In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More...
void | deselect () override |
void | selectPort (int portIndex) final |
| pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr) |
| ~pqPropertyWidget () override |
virtual void | apply () |
pqView * | view () const |
vtkSMProxy * | proxy () const |
vtkSMProperty * | property () const |
virtual char * | panelVisibility () const |
| Forward calls to vtkSMProperty. More...
virtual void | setPanelVisibility (const char *vis) |
virtual bool | isSingleRowItem () const |
| Determines if the PropertyWidget must be constructed using a single row. More...
bool | showLabel () const |
const QList< QPointer< pqPropertyWidgetDecorator > > & | decorators () const |
| Provides access to the decorators for this widget. More...
virtual void | setReadOnly (bool readOnly) |
| Set widget in read-only mode. More...
void | setProperty (vtkSMProperty *property) |
bool | isSelected () const |
| These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More...
void | widgetVisibilityToggled (bool) |
| Fired whenever setWidgetVisible() changes the widget's visibility. More...
void | widgetVisibilityUpdated (bool) |
| Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More...
void | startInteraction () |
| Fired by the underlying interactive widget representation proxy, for each respective events. More...
void | interaction () |
void | endInteraction () |
void | viewChanged (pqView *view) |
| This signal is emitted when the current view changes. More...
void | changeAvailable () |
| This signal is fired as soon as the user starts editing in the widget. More...
void | changeFinished () |
| This signal is fired as soon as the user is done with making an atomic change. More...
void | restartRequired () |
| Indicates that a restart of the program is required for the setting to take effect. More...
template<class T > |
static QString | getXMLName (T *object) |
| Description: This static utility method returns the XML name for an object as a QString. More...
static QString | getTooltip (vtkSMProperty *property) |
| Returns the tooltip to use for the property. More...
static int | hintsWidgetHeightNumberOfRows (vtkPVXMLElement *hints, int defaultValue=10) |
| Helper method to return value from WidgetHeight XML hint, if any. More...
static std::vector< std::string > | parseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0) |
| Parse a XML element as a list of label to use for this widget. More...
vtkSMNewWidgetRepresentationProxyAbstract * | internalWidgetProxy () final |
| Get the internal instance of the widget proxy. More...
void | setupConnections (vtkSMNewWidgetRepresentationProxyAbstract *widget, vtkSMPropertyGroup *smgroup, vtkSMProxy *smproxy) |
| Setup all the links and events for the given widget and SM property group. More...
void | setupUserObserver (vtkSMProxy *smproxy) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | setShowLabel (bool show) |
void | setChangeAvailableAsChangeFinished (bool status) |
| For most pqPropertyWidget subclasses a changeAvailable() signal, corresponds to a changeFinished() signal. More...
void | addDecorator (pqPropertyWidgetDecorator *) |
| Register a decorator. More...
void | removeDecorator (pqPropertyWidgetDecorator *) |
| Unregisters a decorator. More...
pqPropertyLinks & | links () |
| Provides access to the pqPropertyLinks instance. More...
bool | VisibleState = true |
bool | WidgetVisibility = false |
int | LinkedPortIndex = -1 |
pqSMProxy | dataSource |
pqCylinderPropertyWidget is a custom property widget that uses "ImplicitCylinderWidgetRepresentation" to help users interactively set the center, radius and axis for a cylinder.
To use this widget for a property group (vtkSMPropertyGroup), use "InteractiveCylinder" as the "panel_widget" in the XML configuration for the proxy. The property group should have properties for following functions:
Definition at line 27 of file pqCylinderPropertyWidget.h.
