Signals | Public Member Functions | Protected Slots | Protected Member Functions | Properties | List of all members
pqFontPropertyWidget Class Reference
pqFontPropertyWidget is a pqPropertyWidget that can be used to set properties relating to fonts. More...
#include <pqFontPropertyWidget.h>
Inheritance diagram for pqFontPropertyWidget:
Collaboration diagram for pqFontPropertyWidget:
Signals
void horizontalJustificationChanged (QString &)
void verticalJustificationChanged (QString &)
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqFontPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqFontPropertyWidget () override
QString HorizontalJustification () const
QString VerticalJustification () const
- Public Member Functions inherited from pqPropertyGroupWidget
 pqPropertyGroupWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=nullptr)
vtkSMPropertyGrouppropertyGroup () const
void addPropertyLink (QComboBox *cb, const char *propertyName, int smindex=-1)
void addPropertyLink (QLineEdit *edit, const char *propertyName, int smindex=-1)
void addPropertyLink (QCheckBox *button, const char *propertyName, int smindex=-1)
void addPropertyLink (QToolButton *button, const char *propertyName, int smindex=-1)
void addPropertyLink (QGroupBox *groupBox, const char *propertyName, int smindex=-1)
void addPropertyLink (QDoubleSpinBox *spinBox, const char *propertyName, int smindex=-1)
void addPropertyLink (QSpinBox *spinBox, const char *propertyName, int smindex=-1)
void addPropertyLink (pqColorChooserButton *color, const char *propertyName, int smindex=-1)
void addPropertyLink (pqDoubleSliderWidget *slider, const char *propertyName, int smindex=-1)
char * panelVisibility () const override
 Overwrite pqPropertyWidget to forward calls to vtkSMPropertyGroup. More...
void setPanelVisibility (const char *vis) override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqViewview () const
vtkSMProxyproxy () const
vtkSMPropertyproperty () const
bool showLabel () const
virtual void setReadOnly (bool readOnly)
 Set widget in read-only mode. More...
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
void changeHorizontalJustificationIcon (QAction *)
void changeVerticalJustificationIcon (QAction *)
void onFontFamilyChanged ()
void setHorizontalJustification (QString &)
void setVerticalJustification (QString &)
void setupHorizontalJustificationButton ()
void setupVerticalJustificationButton ()
void UpdateToolButtonIcon (QString &str, QToolButton *justification)
QActionGroup * CreateFontActionGroup (QToolButton *justification)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinkslinks ()
Properties
template<class T >
static std::vector< std::stringparseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0)
The widget expects the property-group to have properties with functions set to "Color", "Opacity", "Family", "Size", "Bold", "Italics" and "Shadow". If any property is missing, the corresponding widget will be hidden.
Definition at line 20 of file pqFontPropertyWidget.h.
◆ pqFontPropertyWidget()
pqFontPropertyWidget::pqFontPropertyWidget ( vtkSMProxy proxy,
vtkSMPropertyGroup smgroup,
QWidget *  parent = nullptr
◆ ~pqFontPropertyWidget()
pqFontPropertyWidget::~pqFontPropertyWidget ( )
override
◆ HorizontalJustification()
QString pqFontPropertyWidget::HorizontalJustification ( ) const
◆ VerticalJustification()
QString pqFontPropertyWidget::VerticalJustification ( ) const
◆ horizontalJustificationChanged
void pqFontPropertyWidget::horizontalJustificationChanged ( QString &  )
signal
◆ verticalJustificationChanged
void pqFontPropertyWidget::verticalJustificationChanged ( QString &  )
signal
◆ setHorizontalJustification()
void pqFontPropertyWidget::setHorizontalJustification ( QString &  )
◆ setVerticalJustification()
void pqFontPropertyWidget::setVerticalJustification ( QString &  )
◆ setupHorizontalJustificationButton()
void pqFontPropertyWidget::setupHorizontalJustificationButton ( )
◆ setupVerticalJustificationButton()
void pqFontPropertyWidget::setupVerticalJustificationButton ( )
◆ UpdateToolButtonIcon()
void pqFontPropertyWidget::UpdateToolButtonIcon ( QString &  str,
QToolButton *  justification
◆ CreateFontActionGroup()
QActionGroup* pqFontPropertyWidget::CreateFontActionGroup ( QToolButton *  justification)
◆ changeHorizontalJustificationIcon
void pqFontPropertyWidget::changeHorizontalJustificationIcon ( QAction *  )
protectedslot
◆ changeVerticalJustificationIcon
void pqFontPropertyWidget::changeVerticalJustificationIcon ( QAction *  )
protectedslot
◆ onFontFamilyChanged
void pqFontPropertyWidget::onFontFamilyChanged ( )
protectedslot
Property Documentation
readwrite
Definition at line 24 of file pqFontPropertyWidget.h.
readwrite
Definition at line 26 of file pqFontPropertyWidget.h.
