pqRenderViewSelectionReaction handles various selection modes available on RenderViews.
#include <pqRenderViewSelectionReaction.h>
enum | SelectionMode {
SELECT_SURFACE_CELLS,
SELECT_SURFACE_POINTS,
SELECT_FRUSTUM_CELLS,
SELECT_FRUSTUM_POINTS,
SELECT_SURFACE_CELLS_POLYGON,
SELECT_SURFACE_POINTS_POLYGON,
SELECT_BLOCKS,
SELECT_FRUSTUM_BLOCKS,
SELECT_CUSTOM_BOX,
SELECT_CUSTOM_POLYGON,
ZOOM_TO_BOX,
CLEAR_SELECTION,
GROW_SELECTION,
SHRINK_SELECTION,
SELECT_SURFACE_POINTDATA_INTERACTIVELY,
SELECT_SURFACE_CELLDATA_INTERACTIVELY,
SELECT_SURFACE_CELLS_INTERACTIVELY,
SELECT_SURFACE_POINTS_INTERACTIVELY,
SELECT_SURFACE_POINTS_TOOLTIP,
SELECT_SURFACE_CELLS_TOOLTIP
Simply create multiple instances of pqRenderViewSelectionReaction to handle selection modes for that RenderView. pqRenderViewSelectionReaction uses internal static members to ensure that at most 1 view (and 1 type of selection) is in selection-mode at any given time.
Definition at line 30 of file pqRenderViewSelectionReaction.h.
◆ SelectionMode
Enumerator |
SELECT_SURFACE_CELLS | |
SELECT_SURFACE_POINTS | |
SELECT_FRUSTUM_CELLS | |
SELECT_FRUSTUM_POINTS | |
SELECT_SURFACE_CELLS_POLYGON | |
SELECT_SURFACE_POINTS_POLYGON | |
SELECT_BLOCKS | |
SELECT_FRUSTUM_BLOCKS | |
SELECT_CUSTOM_BOX | |
SELECT_CUSTOM_POLYGON | |
ZOOM_TO_BOX | |
CLEAR_SELECTION | |
GROW_SELECTION | |
SHRINK_SELECTION | |
SELECT_SURFACE_POINTDATA_INTERACTIVELY | |
SELECT_SURFACE_CELLDATA_INTERACTIVELY | |
SELECT_SURFACE_CELLS_INTERACTIVELY | |
SELECT_SURFACE_POINTS_INTERACTIVELY | |
SELECT_SURFACE_POINTS_TOOLTIP | |
SELECT_SURFACE_CELLS_TOOLTIP | |
Definition at line 36 of file pqRenderViewSelectionReaction.h.
◆ pqRenderViewSelectionReaction()
pqRenderViewSelectionReaction::pqRenderViewSelectionReaction |
QAction * |
parentAction, |
pqRenderView * |
view, |
SelectionMode |
mode, |
QActionGroup * |
modifierGroup = nullptr |
If view
is nullptr, this reaction will track the active-view maintained by pqActiveObjects.
◆ ~pqRenderViewSelectionReaction()
pqRenderViewSelectionReaction::~pqRenderViewSelectionReaction |
Call CleanupObservers on destruction.
◆ selectedCustomBox [1/2]
void pqRenderViewSelectionReaction::selectedCustomBox |
int |
xmin, |
int |
ymin, |
int |
xmax, |
int |
ymax |
signal |
Signals emitted when the event happens.
◆ selectedCustomBox [2/2]
const int |
region[4] | ) |
signal |
◆ selectedCustomPolygon
void pqRenderViewSelectionReaction::selectedCustomPolygon |
vtkIntArray * |
polygon | ) |
signal |
◆ actionTriggered
virtual void pqRenderViewSelectionReaction::actionTriggered |
bool |
val | ) |
protectedvirtualslot |
◆ updateEnableState
void pqRenderViewSelectionReaction::updateEnableState |
overrideprotectedslot |
Handles enable state for the CLEAR_SELECTION
, GROW_SELECTION
, and SHRINK_SELECTION
modes.
◆ setView
virtual void pqRenderViewSelectionReaction::setView |
pqView * |
view | ) |
Called when this object was created with nullptr as the view and the active view changes.
Please note that this method will cast the pqView to a pqRenderView.
◆ setRepresentation
Called when the active representation changes.
◆ beginSelection
virtual void pqRenderViewSelectionReaction::beginSelection |
starts the selection i.e.
setup render view in selection mode.
◆ endSelection
virtual void pqRenderViewSelectionReaction::endSelection |
finishes the selection.
Doesn't cause the selection, just returns the render view to previous interaction mode.
◆ preSelection
virtual void pqRenderViewSelectionReaction::preSelection |
◆ fastPreSelection
virtual void pqRenderViewSelectionReaction::fastPreSelection |
makes fast pre-selection.
◆ onMouseStop
virtual void pqRenderViewSelectionReaction::onMouseStop |
callback called for mouse stop events when in 'interactive selection' modes.
◆ clearSelectionCache
virtual void pqRenderViewSelectionReaction::clearSelectionCache |
clears the selection cache.
◆ selectionChanged()
virtual void pqRenderViewSelectionReaction::selectionChanged |
vtkObject * |
unsigned |
long, |
void * |
calldata |
protectedvirtual |
◆ onMouseMove()
virtual void pqRenderViewSelectionReaction::onMouseMove |
protectedvirtual |
callback called for mouse move events when in 'interactive selection' modes.
◆ onLeftButtonRelease()
virtual void pqRenderViewSelectionReaction::onLeftButtonRelease |
protectedvirtual |
callback called for click events when in 'interactive selection' modes.
◆ onWheelRotate()
virtual void pqRenderViewSelectionReaction::onWheelRotate |
protectedvirtual |
◆ onRightButtonPressed()
virtual void pqRenderViewSelectionReaction::onRightButtonPressed |
protectedvirtual |
◆ onRightButtonRelease()
virtual void pqRenderViewSelectionReaction::onRightButtonRelease |
protectedvirtual |
◆ getSelectionModifier()
int pqRenderViewSelectionReaction::getSelectionModifier |
overrideprotectedvirtual |
◆ isCompatible()
virtual bool pqRenderViewSelectionReaction::isCompatible |
SelectionMode |
mode | ) |
protectedvirtual |
Check this selection is compatible with another type of selection.
◆ UpdateTooltip()
virtual void pqRenderViewSelectionReaction::UpdateTooltip |
protectedvirtual |
Display/hide the tooltip of the selected point in mode SELECT_SURFACE_POINTS_TOOLTIP.
◆ cleanupObservers()
virtual void pqRenderViewSelectionReaction::cleanupObservers |
protectedvirtual |
