pqActiveObjects is a singleton that keeps track of "active objects" including active view, active source, active representation etc. More...
#include <pqActiveObjects.h>
Inherits QObject.
Public Slots | |
| void | setActiveView (pqView *view) |
| Set the active view. More... | |
| void | setActiveServer (pqServer *) |
| Set the active server. More... | |
| void | setSelection (const pqProxySelection &selection, pqServerManagerModelItem *current) |
| Sets the selected set of proxies. More... | |
| void | setActivePipelineProxy (pqProxy *proxy) |
| Set the active source. More... | |
| void | setActiveSource (pqPipelineSource *source) |
| void | setActivePort (pqOutputPort *port) |
Signals | |
| void | serverChanged (pqServer *) |
| These signals are fired when any of the corresponding active items change. More... | |
| void | pipelineProxyChanged (pqProxy *) |
| void | sourceChanged (pqPipelineSource *) |
| void | portChanged (pqOutputPort *) |
| void | representationChanged (pqDataRepresentation *) |
| void | representationChanged (pqRepresentation *) |
| void | selectionChanged (const pqProxySelection &) |
| void | dataUpdated () |
| this signal is fired when the active source fires the dataUpdated() signal. More... | |
| void | representationUpdated () |
| this signal is fired when the active representation fires the updated() signal. More... | |
| void | viewUpdated () |
| this signal is fired when the active view fires the dataUpdated() signal. More... | |
| pqView * | activeView () const |
| Returns the active view. More... | |
| pqOutputPort * | activePort () const |
| Returns the active port. More... | |
| pqServer * | activeServer () const |
| Returns the active server. More... | |
| pqDataRepresentation * | activeRepresentation () const |
| Returns the active representation. More... | |
| vtkSMProxySelectionModel * | activeSourcesSelectionModel () const |
| const pqProxySelection & | selection () const |
| Returns the current source selection. More... | |
| Returns the proxyManager() from the active server, if any. More... | |
| vtkSMViewLayoutProxy * | activeLayout () const |
| Convenience method to get the layout for the active view. More... | |
| int | activeLayoutLocation () const |
| Convenience method to locate the active vtkSMViewLayoutProxy and the active cell in it. More... | |
| pqProxy * | activePipelineProxy () const |
| Returns the active pipeline proxy e.g. More... | |
| pqPipelineSource * | activeSource () const |
| static pqActiveObjects & | instance () |
| Provides access to the singleton. More... | |
| pqActiveObjects () | |
| ~pqActiveObjects () override | |
| void | triggerSignals () |
| single method that fires appropriate signals based on state changes. More... | |
pqActiveObjects also keeps track of selected sources (known as 'selection'). setActiveSource/setActivePort will affect the selection but not vice-versa (unless dealing with multiple server sessions).
Definition at line 34 of file pqActiveObjects.h.
Definition at line 48 of file pqActiveObjects.h.
a pqPipelineSource or pqExtractor.
Historical note: until ParaView 5.9, the only types of objects that could be part of the data-processing pipeline were pqPipelineSource (or subclass) instances i.e. they were all vtkAlgorithm-based. With 5.9, we introduced a concept of extractors (pqExtractor) which are not vtkAlgorithm-based and hence cannot be pqPipelineSource. To avoid major disruption to API and applications, here was the chosen strategy: we let active-source be either a pqPipelineSource or pqExtractor. setActiveSource/activeSource() remains unchanged but will likely get deprecated in the future. setActivePipelineProxy and activePipelineProxy() is the now recommended API to get access to the active source and active extractor.
Definition at line 64 of file pqActiveObjects.h.
| pqPipelineSource* pqActiveObjects::activeSource | ( | ) | const |
| pqOutputPort* pqActiveObjects::activePort | ( | ) | const |
Definition at line 76 of file pqActiveObjects.h.
Definition at line 81 of file pqActiveObjects.h.
Definition at line 83 of file pqActiveObjects.h.
Definition at line 91 of file pqActiveObjects.h.
| vtkSMSessionProxyManager* pqActiveObjects::proxyManager | ( | ) | const |
Equivalent to calling this->activeServer()->proxyManager();
| vtkSMViewLayoutProxy* pqActiveObjects::activeLayout | ( | ) | const |
| int pqActiveObjects::activeLayoutLocation | ( | ) | const |
Since currently this information is not available at the server-manager level, especially if the active view is nullptr, we use pqMultiViewWidget and pqTabbedMultiViewWidget to find this.
Returns 0 if one could not determined.
slot |
Changing the active view may lead to change in active representation as well.
slot |
Changing the active source may lead to changes in active port, and active representation.
Using setActivePipelineProxy is the recommended approach since ParaView 5.9 since it allows for supporting pqExtractor items.
inlineslot |
Definition at line 130 of file pqActiveObjects.h.
inlineslot |
Definition at line 131 of file pqActiveObjects.h.
slot |
Changing the server typically leads to changes all other active items.
slot |
All proxies in the selection must be on the same server/session. This generally doesn't affect the activeSource etc. unless the server is different from the active server. In which case, the active server is changed before the selection is updated.
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
This is used by components in the GUI that need to be updated when the active source's pipeline updates.
signal |
This is used by components in the GUI that need to be updated when the active representation updates.
signal |
This is used by components in the GUI that need to be updated when the active view updates.
This also ensures that the Cached* variables are updated correctly.
1.8.13 on Sat Dec 13 2025
