Reaction to rescale the active lookup table's range to match the active representation.
#include <pqRescaleScalarRangeReaction.h>
You can disable tracking of the active representation, instead explicitly provide one using setRepresentation() by pass track_active_objects as false to the constructor.
Definition at line 27 of file pqRescaleScalarRangeReaction.h.
◆ Modes
◆ pqRescaleScalarRangeReaction()
pqRescaleScalarRangeReaction::pqRescaleScalarRangeReaction |
QAction * |
parent, |
bool |
track_active_objects = true , |
Modes |
mode = DATA |
if track_active_objects
is false, then the reaction will not track pqActiveObjects automatically.
◆ ~pqRescaleScalarRangeReaction()
pqRescaleScalarRangeReaction::~pqRescaleScalarRangeReaction |
◆ rescaleScalarRangeToData()
static bool pqRescaleScalarRangeReaction::rescaleScalarRangeToData |
pqPipelineRepresentation * |
repr = nullptr , |
int |
selectedPropertiesType = 0 |
Rescale to current data range.
- Parameters
[in] | repr | The data representation to use to determine the data range. If nullptr , then the active representation is used, if available. |
[in] | selectedPropertiesType | The selected properties type to use. |
- Returns
true
if the operation was successful, otherwise false
◆ rescaleScalarRangeToCustom() [1/3]
Rescale range to a custom range.
- Parameters
[in] | repr | The representation used to determine the transfer function to change range on. If repr is nullptr , then the active representation is used, if available. |
- Returns
- a pointer to the dialog if the operation was successful, otherwise
nullptr
◆ rescaleScalarRangeToCustom() [2/3]
- Parameters
[in] | tfProxies | The transfer function proxies to rescale the range on. |
[in] | separateOpacity | Show controls for setting the opacity function range separately from the color transfer function. |
- Returns
nullptr
◆ rescaleScalarRangeToCustom() [3/3]
- Parameters
[in] | tfProxy | The transfer function proxy to rescale the range on. |
- Returns
nullptr
Definition at line 99 of file pqRescaleScalarRangeReaction.h.
◆ rescaleScalarRangeToDataOverTime()
Rescale range to data range over time.
- Parameters
- Returns
true
◆ rescaleScalarRangeToVisible()
Rescale range to data range for data visible in the view.
- Parameters
- Returns
true
◆ updateEnableState
void pqRescaleScalarRangeReaction::updateEnableState |
overrideslot |
Updates the enabled state.
◆ setRepresentation [1/2]
Set the data representation explicitly when track_active_objects is false.
◆ setRepresentation [2/2]
◆ setActiveRepresentation
void pqRescaleScalarRangeReaction::setActiveRepresentation |
slot |
◆ onTriggered()
void pqRescaleScalarRangeReaction::onTriggered |
overrideprotectedvirtual |
Called when the action is triggered.
◆ onServerAdded
virtual void pqRescaleScalarRangeReaction::onServerAdded |
pqServer * |
server | ) |
protectedvirtualslot |
◆ onAboutToRemoveServer
virtual void pqRescaleScalarRangeReaction::onAboutToRemoveServer |
pqServer * |
server | ) |
