Signals | Public Member Functions | Static Public Member Functions | Protected Slots | Protected Member Functions | List of all members
pqServerConnectDialog Class Reference
pqServerConnectDialog is a dialog that can be used to show the user a selection of server configurations to connect to a server. More...
#include <pqServerConnectDialog.h>
Inherits QDialog.
Signals
void serverAdded ()
 Emitted when a server is added. More...
void serverDeleted ()
 Emitted when a server is deleted. More...
 pqServerConnectDialog (QWidget *parent=nullptr, const pqServerResource &selector=pqServerResource())
 If selector is specified, only those server-configurations that match the selector's scheme and hostname are shown. More...
 ~pqServerConnectDialog () override
const pqServerConfigurationconfigurationToConnect () const
 returns the configuration to connect to. More...
static bool selectServer (pqServerConfiguration &selected_configuration, QWidget *dialogParent=nullptr, const pqServerResource &selector=pqServerResource())
 convenience method to determine which server to connect. More...
Protected Slots
void updateConfigurations ()
 called to update the shown server configurations. More...
void onServerSelected ()
 called when user selects a server. More...
void editServer ()
 called when user clicks "edit-server" More...
void addServer ()
 called when user clicks "add-server" More...
void updateButtons ()
 Called when a server has been added or deleted. More...
void updateServerType ()
 called when user changes the server-type. More...
void goToFirstPage ()
 called to cancel . More...
void acceptConfigurationPage1 ()
 called when user accepts the configuration page #1. More...
void acceptConfigurationPage2 ()
 called when user accepts the configuration page #2. More...
void editServerStartup ()
 called to proceed to page that allows the user to edit the startup. More...
void onNameChanged ()
void deleteServer ()
 called to delete one or all servers. More...
void deleteAllServers ()
void loadServers ()
 called to load/save servers. More...
void saveServers ()
void connect ()
 called to connect to selected server. More...
void updateDialogTitle (int page_number)
 called when the main-stacked widget's active page changes. More...
void fetchServers ()
 called when user clicks "Fetch Servers". More...
void authenticationRequired (QNetworkReply *, QAuthenticator *)
 called when the importer needs authentication from the user. More...
void updateImportableConfigurations ()
 called update importable configs. More...
void importError (const QString &message)
 called to report error from importer. More...
void importServersSelectionChanged ()
 called when user selects some servers to import. More...
void importServers ()
 called to import selected configurations. More...
void editSources ()
 called to edit the sources url. More...
void saveSourcesList ()
void cancelEditSources ()
void editConfiguration (const pqServerConfiguration &)
bool serverNameExists (const QString &name)
This dialog can show all the server-configurations known to pqApplicationCore or show only a subset of those depending on whether a selector was specified in the constructor.
On successful completion, this dialog provides access to the server-configuration selected by the user. It does not make an real attempts to connect to that server.
Definition at line 29 of file pqServerConnectDialog.h.
◆ pqServerConnectDialog()
pqServerConnectDialog::pqServerConnectDialog ( QWidget *  parent = nullptr,
const pqServerResource selector = pqServerResource()
◆ ~pqServerConnectDialog()
pqServerConnectDialog::~pqServerConnectDialog ( )
override
◆ configurationToConnect()
const pqServerConfiguration& pqServerConnectDialog::configurationToConnect ( ) const
This returns a valid response only when pqServerConnectDialog::exec() returns QDialog::Accepted.
◆ selectServer()
static bool pqServerConnectDialog::selectServer ( pqServerConfiguration selected_configuration,
QWidget *  dialogParent = nullptr,
If the selector is specified and matches a single server, then the user is not presented with a dialog, otherwise the user can choose the configuration to use to connect to the server. When the method returns true, selected_configuration will be set to the chosen configuration.
◆ serverAdded
void pqServerConnectDialog::serverAdded ( )
signal
◆ serverDeleted
void pqServerConnectDialog::serverDeleted ( )
signal
◆ updateConfigurations
void pqServerConnectDialog::updateConfigurations ( )
protectedslot
◆ onServerSelected
void pqServerConnectDialog::onServerSelected ( )
protectedslot
◆ editServer
void pqServerConnectDialog::editServer ( )
protectedslot
◆ addServer
void pqServerConnectDialog::addServer ( )
protectedslot
◆ updateButtons
void pqServerConnectDialog::updateButtons ( )
protectedslot
◆ updateServerType
void pqServerConnectDialog::updateServerType ( )
protectedslot
◆ goToFirstPage
void pqServerConnectDialog::goToFirstPage ( )
protectedslot
called to cancel .
◆ acceptConfigurationPage1
void pqServerConnectDialog::acceptConfigurationPage1 ( )
protectedslot
◆ acceptConfigurationPage2
void pqServerConnectDialog::acceptConfigurationPage2 ( )
protectedslot
◆ editServerStartup
void pqServerConnectDialog::editServerStartup ( )
protectedslot
◆ onNameChanged
void pqServerConnectDialog::onNameChanged ( )
protectedslot
◆ deleteServer
void pqServerConnectDialog::deleteServer ( )
protectedslot
◆ deleteAllServers
void pqServerConnectDialog::deleteAllServers ( )
protectedslot
◆ loadServers
void pqServerConnectDialog::loadServers ( )
protectedslot
◆ saveServers
void pqServerConnectDialog::saveServers ( )
protectedslot
◆ connect
void pqServerConnectDialog::connect ( )
protectedslot
◆ updateDialogTitle
void pqServerConnectDialog::updateDialogTitle ( int  page_number)
protectedslot
We update the dialog;s title text to match the page being displayed.
◆ fetchServers
void pqServerConnectDialog::fetchServers ( )
protectedslot
◆ authenticationRequired
void pqServerConnectDialog::authenticationRequired ( QNetworkReply *  ,
QAuthenticator *
protectedslot
◆ updateImportableConfigurations
void pqServerConnectDialog::updateImportableConfigurations ( )
protectedslot
◆ importError
void pqServerConnectDialog::importError ( const QString &  message)
protectedslot
◆ importServersSelectionChanged
void pqServerConnectDialog::importServersSelectionChanged ( )
protectedslot
◆ importServers
void pqServerConnectDialog::importServers ( )
protectedslot
◆ editSources
void pqServerConnectDialog::editSources ( )
protectedslot
◆ saveSourcesList
void pqServerConnectDialog::saveSourcesList ( )
protectedslot
◆ cancelEditSources
void pqServerConnectDialog::cancelEditSources ( )
protectedslot
◆ editConfiguration()
void pqServerConnectDialog::editConfiguration ( const pqServerConfiguration )
◆ serverNameExists()
bool pqServerConnectDialog::serverNameExists ( const QString &  name)
