This class is the crux of the ParaView application. More...
#include <pqApplicationCore.h>
| enum | StateFileFormat : unsigned int { StateFileFormat::PVSM = 0, StateFileFormat::Python = 1 } |
| Enum to capture possible Save State file formats. More... | |
Public Slots | |
| void | prepareForQuit () |
| Applications calls this to ensure that any cleanup is performed correctly. More... | |
| void | quit () |
| Calls QCoreApplication::quit(). More... | |
| void | updateAvailableReadersAndWriters () |
| Update the available readers and writers using the factories. More... | |
| void | render () |
| Renders all windows. More... | |
| void | loadConfiguration (const QString &filename) |
| Load configuration xml. More... | |
| void | loadConfigurationXML (const char *xmldata) |
Signals | |
| void | aboutToWriteState (QString filename) |
| Fired before a state file, either python or XML, is written. More... | |
| void | aboutToReadState (QString filename) |
| Fired before a state file, either python or XML, is read. More... | |
| void | aboutToLoadState (vtkPVXMLElement *root) |
| Fired before a state xml is being loaded. More... | |
| void | stateLoaded (vtkPVXMLElement *root, vtkSMProxyLocator *locator) |
| Fired when a state file is loaded successfully. More... | |
| void | stateSaved (vtkPVXMLElement *root) |
| Fired to save state xml. More... | |
| void | undoStackChanged (pqUndoStack *) |
| Fired when the undo stack is set. More... | |
| void | loadXML (vtkPVXMLElement *) |
| Fired on loadConfiguration(). More... | |
| void | forceFilterMenuRefresh () |
| Fired when the filter menu state needs to be manually updated. More... | |
| void | updateMasterEnableState (bool) |
| Fired when master changed. More... | |
| void | clientEnvironmentDone () |
| Fired when the ParaView Client infrastructure has completed setting up the environment. More... | |
| pqApplicationCore (int &argc, char **argv, vtkCLIOptions *options=nullptr, bool addStandardArgs=true, QObject *parent=nullptr) | |
| Initializes the ParaView application engine. More... | |
| pqObjectBuilder * | getObjectBuilder () const |
| Get the Object Builder. More... | |
| void | setUndoStack (pqUndoStack *stack) |
| Set/Get the application's central undo stack. More... | |
| pqUndoStack * | getUndoStack () const |
| void | registerManager (const QString &function, QObject *manager) |
| Custom Applications may need use various "managers" All such manager can be registered with the pqApplicationCore so that that can be used by other components of the application. More... | |
| QObject * | manager (const QString &function) |
| Returns a manager for a particular function, if any. More... | |
| void | unRegisterManager (const QString &function) |
| Unregisters a manager for a particular function, if any. More... | |
| QHelpEngine * | helpEngine () |
| provides access to the help engine. More... | |
| void | registerDocumentation (const QString &filename) |
| QHelpEngine doesn't like filenames in resource space. More... | |
| pqServerManagerObserver * | getServerManagerObserver () |
| ServerManagerObserver observer the vtkSMProxyManager for changes to the server manager and fires signals on certain actions such as registeration/unregistration of proxies etc. More... | |
| pqServerManagerModel * | getServerManagerModel () const |
| ServerManagerModel is the representation of the ServerManager using pqServerManagerModelItem subclasses. More... | |
| pqInterfaceTracker * | interfaceTracker () const |
| Locates the interface tracker for the application. More... | |
| pqLinksModel * | getLinksModel () const |
| pqLinksModel is the model used to keep track of proxy/property links maintained by vtkSMProxyManager. More... | |
| pqMainWindowEventManager * | getMainWindowEventManager () const |
| pqMainWindowManager manages signals called for main window events. More... | |
| pqPluginManager * | getPluginManager () const |
| pqPluginManager manages all functionality associated with loading plugins. More... | |
| pqProgressManager * | getProgressManager () const |
| ProgressManager is the manager that streamlines progress. More... | |
| virtual pqTestUtility * | testUtility () |
| Provides access to the test utility. More... | |
| pqRecentlyUsedResourcesList & | recentlyUsedResources () |
| Returns the set of recently-used resources i.e. More... | |
| pqServerConfigurationCollection & | serverConfigurations () |
| Returns the collection of server configurations known. More... | |
| pqSettings * | settings () |
| Get the application settings. More... | |
| void | clearSettings () |
| Clears the user settings. More... | |
| QString | getDefaultSaveStateFileFormatQString (bool pythonAvailable, bool loading) |
| Return the QString to populate the pqFileDialog with available file formats for saving/loading State. More... | |
| void | useVersionedSettings (bool use) |
| Set versioned settings mode. More... | |
| vtkPVXMLElement * | saveState () |
| Save the ServerManager state to a XML element. More... | |
| bool | saveState (const QString &filename, vtkTypeUInt32 location=0x10) |
| Save the ServerManager state to a file. More... | |
| void | loadState (vtkPVXMLElement *root, pqServer *server, vtkSMStateLoader *loader=nullptr) |
| Loads the ServerManager state. More... | |
| void | loadState (const char *filename, pqServer *server, vtkSMStateLoader *loader=nullptr) |
| Load state xml from a file. More... | |
| void | loadStateFromString (const char *xmlcontents, pqServer *server, vtkSMStateLoader *loader=nullptr) |
| Loads state from an in-memory buffer. More... | |
| void | clearViewsForLoadingState (pqServer *server) |
| void | loadStateIncremental (vtkPVXMLElement *root, pqServer *server, vtkSMStateLoader *loader=nullptr) |
| Same as loadState() except that it doesn't clear the current visualization state. More... | |
| void | loadStateIncremental (const QString &filename, pqServer *server, vtkSMStateLoader *loader=nullptr) |
| void | setLoadingState (bool value) |
| Set the loading state flag. More... | |
| bool | isLoadingState () |
| Check to see if its in the process of loading a state Reliance on this flag is chimerical since we cannot set this ivar when state file is being loaded from python shell. More... | |
| pqServer * | getActiveServer () const |
| returns the active server is any. More... | |
| QString | getTranslationsPathFromInterfaceLanguage (QString prefix, QString locale) |
| returns a path to a directory containing a translation binary file located in a path specified by the PV_TRANSLATIONS_DIR environment variable or in the resources directory. More... | |
| QTranslator * | getQtTranslations (QString prefix, QString locale) |
| returns a QTranslator with a loaded qm file. More... | |
| QString | getInterfaceLanguage () |
| returns interface language in use in a locale code form. More... | |
| ~pqApplicationCore () override | |
| Destructor. More... | |
| void | _paraview_client_environment_complete () |
| INTERNAL. More... | |
| static pqApplicationCore * | instance () |
| static QString | stateFileFormatToExtension (pqApplicationCore::StateFileFormat format) |
| Return the extension for the given format See StateFileFormat. More... | |
Protected Slots | |
| void | onStateLoaded (vtkPVXMLElement *root, vtkSMProxyLocator *locator) |
| void | onStateSaved (vtkPVXMLElement *root) |
| void | onHelpEngineWarning (const QString &) |
Protected Attributes | |
| bool | LoadingState |
| pqLinksModel * | LinksModel |
| pqObjectBuilder * | ObjectBuilder |
| pqInterfaceTracker * | InterfaceTracker |
| pqMainWindowEventManager * | MainWindowEventManager |
| pqPluginManager * | PluginManager |
| pqProgressManager * | ProgressManager |
| pqServerManagerModel * | ServerManagerModel |
| pqServerManagerObserver * | ServerManagerObserver |
| pqUndoStack * | UndoStack |
| pqRecentlyUsedResourcesList * | RecentlyUsedResourcesList |
| pqServerConfigurationCollection * | ServerConfigurations |
| pqSettings * | Settings |
| QHelpEngine * | HelpEngine |
| QPointer< pqTestUtility > | TestUtility |
It creates and manages various managers which are necessary for the ParaView-based client to work with the ServerManager. For clients based of the pqCore library, simply instantiate this pqApplicationCore after QApplication initialization and then create your main window etc. like a standard Qt application. You can then use the facilities provided by pqCore such as the pqObjectBuilder, pqUndoStack etc. in your application. After that point.
Definition at line 60 of file pqApplicationCore.h.
strong |
| Enumerator | |
| PVSM | |
| Python | |
Definition at line 231 of file pqApplicationCore.h.
| pqApplicationCore::pqApplicationCore | ( | int & | argc, |
| char ** | argv, | ||
| vtkCLIOptions * | options = nullptr, |
| bool | addStandardArgs = true, |
| QObject * | parent = nullptr |
vtkCLIOptions may be provide if the application wants to customize command line argument processing. By default all standard ParaView-specific command line arguments will be supported. To avoid that, simply pass addStandardArgs=false.
pqApplicationCoreExitCode exception if the initialization process was short circuited and the application should simply quit.options is nullptr, an vtkCLIOptions instance will be created and used. It is also setup to accept extra / unknown arguments without raising errors.
Destructor.
Object Buider must be used to create complex objects such as sources, filters, readers, views, displays etc.
Definition at line 91 of file pqApplicationCore.h.
| void pqApplicationCore::setUndoStack | ( | pqUndoStack * | stack | ) |
By default no undo stack is provided. Applications must set on up as required.
Definition at line 98 of file pqApplicationCore.h.
| void pqApplicationCore::registerManager | ( | const QString & | function, |
| QObject * | manager | ||
Registering with pqApplicationCore gives easy access to these managers from the application code. Note that custom applications are not required to register managers. However certain optional components of the pqCore may expect some managers. Only one manager can be registered for a function.
| QObject* pqApplicationCore::manager | ( | const QString & | function | ) |
| void pqApplicationCore::unRegisterManager | ( | const QString & | function | ) |
| QHelpEngine* pqApplicationCore::helpEngine | ( | ) |
The engine is created the first time this method is called.
| void pqApplicationCore::registerDocumentation | ( | const QString & | filename | ) |
This method creates a temporary file for the resource and registers that with the QHelpEngine.
Returns the ServerManagerObserver used by the application.
Definition at line 142 of file pqApplicationCore.h.
It makes it possible to explore the ServerManager with ease by separating proxies based on their functionality/type.
Definition at line 150 of file pqApplicationCore.h.
pqInterfaceTracker is used to locate all interface implementations typically loaded from plugins.
Definition at line 157 of file pqApplicationCore.h.
TODO: It may be worthwhile to investigate if we even need a global pqLinksModel. All the information is already available in vtkSMProxyManager.
Definition at line 166 of file pqApplicationCore.h.
Definition at line 171 of file pqApplicationCore.h.
Definition at line 179 of file pqApplicationCore.h.
Definition at line 184 of file pqApplicationCore.h.
Reimplemented in pqPVApplicationCore.
| pqRecentlyUsedResourcesList& pqApplicationCore::recentlyUsedResources | ( | ) |
data files and state files.
| pqServerConfigurationCollection& pqApplicationCore::serverConfigurations | ( | ) |
Server configurations have information about connecting to different servers.
| pqSettings* pqApplicationCore::settings | ( | ) |
This uses a user settings file (created as needed) and falls back to an installed settings file for options not found in the user file.
When "--disable-registry (--dr)" is specified, a "XXX-dr.ini" alternative file is used instead of the usual config, so nothing is read/write on usual files. Then clearSettings is called.
| void pqApplicationCore::clearSettings | ( | ) |
Since various UI components that only read settings at creation time may get out of sync, it's best to warn the user to restart the application.
Any changes made to pqSettings after calling this method will be lost and will not get restored. If that's not desired, see QSettings::clear.
Site settings are still present, though.
Default to pvsm
| QString pqApplicationCore::getDefaultSaveStateFileFormatQString | ( | bool | pythonAvailable, |
| bool | loading | ||
Takes into account the default state file format setting.
| void pqApplicationCore::useVersionedSettings | ( | bool | use | ) |
If true, the setting file name includes application version numbers. Should be set before the first call to settings(): later calls will not be taken into account.
Default is false.
| vtkPVXMLElement* pqApplicationCore::saveState | ( | ) |
| bool pqApplicationCore::saveState | ( | const QString & | filename, |
| vtkTypeUInt32 | location = 0x10 |
Return true if the operation succeeded otherwise return false.
| void pqApplicationCore::loadState | ( | vtkPVXMLElement * | root, |
| pqServer * | server, | ||
| vtkSMStateLoader * | loader = nullptr |
Emits the signal stateLoaded() on loading state successfully.
| void pqApplicationCore::loadState | ( | const char * | filename, |
The filename can be a Qt resource file, besides regular filesystem files (refer to QFile documentation for more information on Qt resource system).
| void pqApplicationCore::loadStateFromString | ( | const char * | xmlcontents, |
| void pqApplicationCore::clearViewsForLoadingState | ( | pqServer * | server | ) |
| void pqApplicationCore::loadStateIncremental | ( | vtkPVXMLElement * | root, |
| void pqApplicationCore::loadStateIncremental | ( | const QString & | filename, |
Definition at line 304 of file pqApplicationCore.h.
Definition at line 311 of file pqApplicationCore.h.
| pqServer* pqApplicationCore::getActiveServer | ( | ) | const |
| QString pqApplicationCore::getTranslationsPathFromInterfaceLanguage | ( | QString | prefix, |
| QString | locale | ||
The binary file returned is the first one to have a name matching the locale given in the user settings.
| prefix | The prefix the filename should contain. |
| locale | The locale the filename suffix should contain. |
| QTranslator* pqApplicationCore::getQtTranslations | ( | QString | prefix, |
The qm file can come either from the Qt's translation directory or from the ParaView's shared directory.
| QString pqApplicationCore::getInterfaceLanguage | ( | ) |
It is first read from PV_INTERFACE_LANGUAGE environment variable if defined, then recovered from user settings. If not set, return en.
| void pqApplicationCore::_paraview_client_environment_complete | ( | ) |
INTERNAL.
Do not use.
slot |
slot |
slot |
This results in firing of the loadXML() signal which different components that support configuration catch and process to update their behavior. This also update available readers and writers.
slot |
slot |
slot |
signal |
Note that writing can still fail at this point.
signal |
Note that loading can still fail at this point.
signal |
One can add slots for this signal and modify the fired xml-element as part of pre-processing before attempting to load the state xml. Note that never attempt to connect to signal in a delayed fashion i.e using Qt::QueuedConnection etc. since the root will be destroyed.
signal |
GUI components that may have state saved in the XML state file must listen to this signal and handle process the XML to update their state.
signal |
Components that need to save XML state should listen to this signal and add their XML elements to the root. DO NOT MODIFY THE ROOT besides adding new children.
signal |
signal |
signal |
signal |
true if current user is master, false otherwise.
signal |
protectedslot |
protectedslot |
protectedslot |
Definition at line 465 of file pqApplicationCore.h.
Definition at line 467 of file pqApplicationCore.h.
Definition at line 468 of file pqApplicationCore.h.
Definition at line 469 of file pqApplicationCore.h.
Definition at line 470 of file pqApplicationCore.h.
Definition at line 471 of file pqApplicationCore.h.
Definition at line 472 of file pqApplicationCore.h.
Definition at line 473 of file pqApplicationCore.h.
Definition at line 474 of file pqApplicationCore.h.
Definition at line 475 of file pqApplicationCore.h.
Definition at line 476 of file pqApplicationCore.h.
Definition at line 477 of file pqApplicationCore.h.
Definition at line 478 of file pqApplicationCore.h.
Definition at line 479 of file pqApplicationCore.h.
Definition at line 480 of file pqApplicationCore.h.
1.8.13 on Sun Dec 14 2025
