vtkChartLogoRepresentation Class Reference
representation to add logo to vtkPVContextView More...
#include <vtkChartLogoRepresentation.h>
Inheritance diagram for vtkChartLogoRepresentation:
Collaboration diagram for vtkChartLogoRepresentation:
enum  DesiredOutputPrecision
virtual doubleGetPosition ()
 Get/Set the position to use when AnyLocation is being used. More...
virtual void GetPosition (double &, double &)
virtual void GetPosition (double [2])
virtual void SetPosition (double, double)
void SetPosition (double [2])
void SetVisibility (bool val) override
virtual void MarkModified ()
virtual bool GetVisibility ()
virtual vtkDataObjectGetRenderedDataObject (int vtkNotUsed(port))
double GetCacheKey () const
vtkAlgorithmOutputGetInternalOutputPort () override
vtkAlgorithmOutputGetInternalOutputPort (int port) override
vtkAlgorithmOutputGetInternalOutputPort (int port, int conn) override
vtkViewGetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
const std::stringGetLogName () const
vtkDataRepresentationNewInstance () const
virtual vtkSelectionConvertSelection (vtkView *view, vtkSelection *selection)
vtkAlgorithmOutputGetInputConnection (int port=0, int index=0)
vtkAnnotationLinkGetAnnotationLink ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort ()
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort (int port)
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort (int port, int conn)
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort ()
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort (int port)
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort (int port, int conn)
virtual vtkStringArrayGetSelectionArrayNames ()
vtkPassInputTypeAlgorithmNewInstance () const
vtkPolyDataGetPolyDataOutput ()
vtkStructuredPointsGetStructuredPointsOutput ()
vtkImageDataGetImageDataOutput ()
vtkStructuredGridGetStructuredGridOutput ()
vtkUnstructuredGridGetUnstructuredGridOutput ()
vtkRectilinearGridGetRectilinearGridOutput ()
vtkTableGetTableOutput ()
vtkGraphGetGraphOutput ()
vtkDataObjectGetInput ()
vtkDataObjectGetOutput ()
vtkDataObjectGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkChartLogoRepresentationNew ()
static vtkChartLogoRepresentationSafeDownCast (vtkObject *o)
static vtkPVDataRepresentationSafeDownCast (vtkObject *o)
static vtkDataRepresentationNew ()
static vtkDataRepresentationSafeDownCast (vtkObjectBase *o)
static vtkPassInputTypeAlgorithmNew ()
static vtkPassInputTypeAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkChartLogoRepresentation ()
 ~vtkChartLogoRepresentation () override
 vtkPVDataRepresentation ()
vtkExecutiveCreateDefaultExecutive () override
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
virtual vtkAnnotationLayersConvertAnnotations (vtkView *view, vtkAnnotationLayers *annotations)
vtkTrivialProducerGetInternalInput (int port, int conn)
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
vtkDataObjectGetInput (int port)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
enum  {
  AnyLocation = 0, LowerLeftCorner, LowerRightCorner, LowerCenter,
  UpperLeftCorner, UpperRightCorner, UpperCenter
virtual void SetLogoLocation (int)
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
vtkStringArraySelectionArrayNames
CommandObserver
vtkAnnotationLinkAnnotationLinkInternal
double Progress
char * ProgressText
unsigned long ErrorCode
vtkChartLogoRepresentation supports adding logo to vtkPVContextView. It is the vtkLogoSourceRepresentation counterpart except for vtkPVContextView instead of vtkPVRenderView. It adds a vtkImageItem to the vtkContextScene maintained by the vtkPVContextView to render the logo.
Definition at line 21 of file vtkChartLogoRepresentation.h.
Definition at line 25 of file vtkChartLogoRepresentation.h.
◆ anonymous enum
anonymous enum
Enumerator
AnyLocation
LowerLeftCorner
LowerRightCorner
LowerCenter
UpperLeftCorner
UpperRightCorner
UpperCenter
Definition at line 29 of file vtkChartLogoRepresentation.h.
◆ vtkChartLogoRepresentation()
vtkChartLogoRepresentation::vtkChartLogoRepresentation ( )
◆ ~vtkChartLogoRepresentation()
vtkChartLogoRepresentation::~vtkChartLogoRepresentation ( )
static vtkChartLogoRepresentation* vtkChartLogoRepresentation::New ( )
virtual const char* vtkChartLogoRepresentation::GetClassName ( )
static int vtkChartLogoRepresentation::IsTypeOf ( const char *  type)
virtual int vtkChartLogoRepresentation::IsA ( const char *  type)
static vtkChartLogoRepresentation* vtkChartLogoRepresentation::SafeDownCast ( vtkObject o)
void vtkChartLogoRepresentation::PrintSelf ( ostream &  os,
◆ SetLogoLocation()
virtual void vtkChartLogoRepresentation::SetLogoLocation ( int  )
◆ GetPosition() [1/3]
virtual double* vtkChartLogoRepresentation::GetPosition ( )
◆ GetPosition() [2/3]
virtual void vtkChartLogoRepresentation::GetPosition ( double ,
double
◆ GetPosition() [3/3]
virtual void vtkChartLogoRepresentation::GetPosition ( double  [2])
◆ SetPosition() [1/2]
virtual void vtkChartLogoRepresentation::SetPosition ( double  ,
double
◆ SetPosition() [2/2]
void vtkChartLogoRepresentation::SetPosition ( double  [2])
◆ SetVisibility()
void vtkChartLogoRepresentation::SetVisibility ( bool  val)
When the visibility of representation of false, all view passes are ignored.
◆ ProcessViewRequest()
int vtkChartLogoRepresentation::ProcessViewRequest ( vtkInformationRequestKey request_type,
vtkInformation inInfo,
vtkInformation outInfo
Note
Starting with ParaView 5.8, this method is no longer called for hidden representation i.e. representations for which vtkDataRepresentation::GetVisibility() returns false.
◆ FillInputPortInformation()
int vtkChartLogoRepresentation::FillInputPortInformation ( int  port,
vtkInformation info
overrideprotectedvirtual
Fill input port information.
◆ RequestData()
int vtkChartLogoRepresentation::RequestData ( vtkInformation ,
vtkInformationVector **  ,
Overridden to invoke vtkCommand::UpdateDataEvent.
◆ AddToView()
bool vtkChartLogoRepresentation::AddToView ( vtkView view)
◆ RemoveFromView()
bool vtkChartLogoRepresentation::RemoveFromView ( vtkView view)
