vtkChartRepresentation is the base representation for charting representations. More...
#include <vtkChartRepresentation.h>
| enum | ArraySelectionModes { MERGED_BLOCKS = 0, INDIVIDUAL_BLOCKS = 1 } |
| typedef vtkPVDataRepresentation | Superclass |
Public Types inherited from vtkPVDataRepresentation | |
| enum | { SkippedUpdateDataEvent = vtkCommand::UserEvent + 91, UpdateTimeChangedEvent } |
| typedef vtkDataRepresentation | Superclass |
Public Types inherited from vtkDataRepresentation | |
| typedef vtkPassInputTypeAlgorithm | Superclass |
Public Types inherited from vtkPassInputTypeAlgorithm | |
| typedef vtkAlgorithm | Superclass |
Public Types inherited from vtkAlgorithm | |
| enum | DesiredOutputPrecision |
| void | SetSelectionRepresentation (vtkChartSelectionRepresentation *) |
| These must only be set during initialization before adding the representation to any views or calling Update(). More... | |
| void | SetVisibility (bool visible) override |
| Set visibility of the representation. More... | |
| This needs to be called on all instances of vtkGeometryRepresentation when the input is modified. More... | |
| unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override |
| Override because of internal selection representations that need to be initialized as well. More... | |
| vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More... | |
| virtual std::string | GetDefaultSeriesLabel (const std::string &tableName, const std::string &columnName) |
| Method to provide the default name given the name of a table and a column in that table. More... | |
| virtual bool | MapSelectionToInput (vtkSelection *sel) |
| This method is called on the client-side by the vtkPVContextView whenever a new selection is made on all the visible representations in that view. More... | |
| virtual bool | MapSelectionToView (vtkSelection *sel) |
| This is the inverse of MapSelectionToInput(). More... | |
| void | SetFieldAssociation (int) |
| Set the field association for arrays to use. More... | |
| virtual int | GetFieldAssociation () |
| virtual void | SetActiveAssembly (const char *) |
| Get/Set the name of the assembly to use for mapping block visibilities, colors and opacities. More... | |
| virtual char * | GetActiveAssembly () |
| void | AddBlockSelector (const char *selector) |
| Update list of selectors that determine the selected blocks. More... | |
| void | RemoveAllBlockSelectors () |
| void | SetCompositeDataSetIndex (unsigned int) |
| Methods to control block selection. More... | |
| void | AddCompositeDataSetIndex (unsigned int) |
| void | ResetCompositeDataSetIndices () |
| virtual void | SetFlattenTable (int) |
| Flatten the table, i.e. More... | |
| virtual int | GetFlattenTable () |
| virtual bool | Export (vtkAbstractChartExporter *vtkNotUsed(exporter)) |
| Called by vtkPVContextView::Export() to export the representation's data to a CSV file. More... | |
| virtual int | GetArraySelectionMode () |
| ArraySelectionMode controls how arrays are selected for charting in composite datasets. More... | |
| void | SetArraySelectionMode (int mode) |
| void | SetPlaceHolderDataType (int datatype) |
| Set/Get the placeholder data type. More... | |
| virtual int | GetPlaceHolderDataType () |
Public Member Functions inherited from vtkPVDataRepresentation | |
| Return 0 if the Initialize() method was not called otherwise a unique ID that will be shared across the processes for that same object. More... | |
| Returns the data object that is rendered from the given input port. More... | |
| Returns the cache-key the representation is currently using. More... | |
| Retrieves an output port for the input data object at the specified port and connection index. More... | |
| Provides access to the view. More... | |
Returns the timestamp when RequestData was executed on the representation. More... | |
| bool | GetNeedsUpdate () |
| Returns true if the representation needs an update. More... | |
| Specify the array names used for the selection. More... | |
| Set the update time. More... | |
| Get whether the UpdateTime is valid. More... | |
| void | ResetUpdateTime () |
| Generally, caching is within the purview of the vtkPVView (and subclasses). More... | |
| Making these methods public. More... | |
| This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged. More... | |
| This flag indicates if the representation is for a temporal pipeline. More... | |
Overridden to ensure that MarkModified is called. More... | |
Public Member Functions inherited from vtkDataRepresentation | |
Public Member Functions inherited from vtkPassInputTypeAlgorithm | |
Public Member Functions inherited from vtkAlgorithm | |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
Protected Types | |
| using | MapOfTables = std::map< std::string, std::pair< vtkSmartPointer< vtkTable >, unsigned int > > |
Public Attributes inherited from vtkAlgorithm | |
| SINGLE_PRECISION | |
| DOUBLE_PRECISION | |
| DEFAULT_PRECISION | |
| int | AbortExecute |
Static Protected Member Functions inherited from vtkAlgorithm | |
| static vtkInformationIntegerKey * | PORT_REQUIREMENTS_FILLED () |
Static Protected Attributes inherited from vtkAlgorithm | |
| static vtkExecutive * | DefaultExecutivePrototype |
Currently, ParaView's charting views are client-side only views that render only on the client side. That being the case, when running in client-server mode or in parallel, the data-delivery mode is fixed. Hence, unlike representations for 3D views, this representation delivers the data in RequestData() itself. This makes it possible for client code to call UpdatePipeline() on the representation proxy and then access the delivered vtkTable on the client.
Definition at line 36 of file vtkChartRepresentation.h.
Definition at line 40 of file vtkChartRepresentation.h.
Definition at line 288 of file vtkChartRepresentation.h.
| Enumerator | |
| MERGED_BLOCKS | |
| INDIVIDUAL_BLOCKS | |
Definition at line 179 of file vtkChartRepresentation.h.
| void vtkChartRepresentation::SetSelectionRepresentation | ( | vtkChartSelectionRepresentation * | ) |
Reimplemented in vtkXYChartRepresentation, vtkPVPlotMatrixRepresentation, vtkPVImageChartRepresentation, vtkPVParallelCoordinatesRepresentation, and vtkPVBoxChartRepresentation.
This is essential since the geometry filter does not have any real-input on the client side which messes with the Update requests.
| void vtkChartRepresentation::SetFieldAssociation | ( | int | ) |
When changed, this will call MarkModified().
The default is Hierarchy.
| void vtkChartRepresentation::AddBlockSelector | ( | const char * | selector | ) |
| void vtkChartRepresentation::RemoveAllBlockSelectors | ( | ) |
| void vtkChartRepresentation::SetCompositeDataSetIndex | ( | unsigned | int | ) |
| void vtkChartRepresentation::AddCompositeDataSetIndex | ( | unsigned | int | ) |
| void vtkChartRepresentation::ResetCompositeDataSetIndices | ( | ) |
This is typically called by the vtkView to request meta-data from the representations or ask them to perform certain tasks e.g. PrepareForRendering. Overridden to handle REQUEST_RENDER() to call PrepareForRendering.
Reimplemented in vtkXYChartRepresentation.
When overriding this method, ensure that the implementation does not depend on the instance being initialized or have valid data. This method is called on the client-side when filling up the domains for the properties.
Reimplemented in vtkQuartileChartRepresentation.
split any multicomponent columns into separate components.
The goal of this method is allow the representations to transform the selection created in the view (which is an id-based selection based on the vtkTable that is fed into the vtkChart) to an appropriate selection based on the data going into the representation. Return false if the selection is not applicable to this representation or the conversion cannot be made. Default implementation simply ensures that the FieldType on the selection nodes is set to match up with the FieldAssociation on the representation.
Reimplemented in vtkPVHistogramChartRepresentation.
In this case, we are converting the selection defined on the input for the representation to a selection that corresponds to elements being rendered in the view. The default implementation checks removes vtkSelectionNode items in sel that don't have the FieldType that matches this->FieldAssociation. Similar to MapSelectionToInput(), this method is expected to transform the sel in place and return false is the selection is not applicable to this representation or the conversion cannot be made.
inlinevirtual |
Return false on failure which will call the exporting process to abort and raise an error. Default implementation simply returns false.
Definition at line 176 of file vtkChartRepresentation.h.
MERGED_BLOCKS means arrays are selected once and applied to all blocks. INDIVIDUAL_BLOCKS means arrays are selected independently for each leaf block.
| void vtkChartRepresentation::SetArraySelectionMode | ( | int | mode | ) |
| void vtkChartRepresentation::SetPlaceHolderDataType | ( | int | datatype | ) |
This value is set by the proxy and is needed to ensure that the client knows the type of the input that lives on the server.
In the past, we were always creating a placeholder of type vtkMultiBlockDataSet when no input was available on the client. This is no longer valid.
This can be potentially removed in the future once vtkMultiBlockDataSet is deprecated.
overrideprotectedvirtual |
Fill input port information.
inlineprotectedvirtual |
This method is called before actual render if this->MTime was modified since the last time this method was called.
Subclasses should override to update "appearance" related changes that don't affect data. When this method is called, you're assured that this->ContextView is valid. Note that this method will not be called if this->GetVisibility() returns false, this subclasses should also override SetVisibility() to hide "actors" and such.
Reimplemented in vtkXYChartRepresentation, vtkPVPlotMatrixRepresentation, vtkPVHistogramChartRepresentation, vtkQuartileChartRepresentation, vtkPVParallelCoordinatesRepresentation, vtkPVBoxChartRepresentation, and vtkPVImageChartRepresentation.
Definition at line 229 of file vtkChartRepresentation.h.
Subclasses should override this to connect inputs to the internal pipeline as necessary.
Since most representations are "meta-filters" (i.e. filters containing other filters), you should create shallow copies of your input before connecting to the internal pipeline. The convenience method GetInternalOutputPort will create a cached shallow copy of a specified input for you. The related helper functions GetInternalAnnotationOutputPort, GetInternalSelectionOutputPort should be used to obtain a selection or annotation port whose selections are localized for a particular input data object.
Convenience method to get the first vtkTable from LocalOutput, if any.
If pre_delivery is true (default is false), then the data from most-recent REQUEST_UPDATE pass is used otherwise the delivered data object from most recent REQUEST_RENDER pass is used.
protectedvirtual |
Method to be overridden to transform input data.
The default implementation just returns the data object provided in parameter.
protectedvirtual |
Chart representation/views expect that the data is reduced to root node and then passed on the rendering nodes.
This method may be overridden to customize the reduction. The default implementation uses vtkBlockDeliveryPreprocessor to convert to tables and then use vtkPVMergeTablesMultiBlock as the reduction algorithm.
Reimplemented in vtkPVImageChartRepresentation.
protectedvirtual |
Method to be overridden to apply an operation of the table after it is gathered to the first rank for rendering the chart.
This allows subclasses to operate on the final table. The default implementation just returns the input.
Convenience method to get all vtkTable instances with their associated names.
Definition at line 294 of file vtkChartRepresentation.h.
Definition at line 295 of file vtkChartRepresentation.h.
Definition at line 296 of file vtkChartRepresentation.h.
Definition at line 297 of file vtkChartRepresentation.h.
Definition at line 300 of file vtkChartRepresentation.h.
Definition at line 302 of file vtkChartRepresentation.h.
Definition at line 304 of file vtkChartRepresentation.h.
Definition at line 305 of file vtkChartRepresentation.h.
Definition at line 306 of file vtkChartRepresentation.h.
Definition at line 308 of file vtkChartRepresentation.h.
1.8.13 on Sun Dec 14 2025
