void | SetVisibility (bool visible) override |
| Set visibility of the representation. More...
vtkChartHistogram2D * | GetChart () |
| Provides access to the underlying VTK representation. More...
void | SetLookupTable (vtkScalarsToColors *lut) |
| Set the color map to use for the points in the plot. More...
void | SetSelectionRepresentation (vtkChartSelectionRepresentation *) |
| These must only be set during initialization before adding the representation to any views or calling Update(). More...
void | MarkModified () override |
| This needs to be called on all instances of vtkGeometryRepresentation when the input is modified. More...
void | SetCompositeDataSetIndex (unsigned int) |
void | AddCompositeDataSetIndex (unsigned int) |
void | ResetCompositeDataSetIndices () |
unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override |
| Override because of internal selection representations that need to be initialized as well. More...
int | ProcessViewRequest (vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo) override |
| vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
virtual std::string | GetDefaultSeriesLabel (const std::string &tableName, const std::string &columnName) |
| Method to provide the default name given the name of a table and a column in that table. More...
virtual bool | MapSelectionToInput (vtkSelection *sel) |
| This method is called on the client-side by the vtkPVContextView whenever a new selection is made on all the visible representations in that view. More...
virtual bool | MapSelectionToView (vtkSelection *sel) |
| This is the inverse of MapSelectionToInput(). More...
void | SetFieldAssociation (int) |
| Set the field association for arrays to use. More...
virtual int | GetFieldAssociation () |
virtual void | SetFlattenTable (int) |
| Flatten the table, i.e. More...
virtual int | GetFlattenTable () |
virtual bool | Export (vtkAbstractChartExporter *vtkNotUsed(exporter)) |
| Called by vtkPVContextView::Export() to export the representation's data to a CSV file. More...
unsigned int | GetUniqueIdentifier () |
| Return 0 if the Initialize() method was not called otherwise a unique ID that will be shared across the processes for that same object. More...
virtual bool | GetVisibility () |
virtual vtkDataObject * | GetRenderedDataObject (int vtkNotUsed(port)) |
| Returns the data object that is rendered from the given input port. More...
double | GetCacheKey () const |
| Returns the cache-key the representation is currently using. More...
vtkAlgorithmOutput * | GetInternalOutputPort () override |
| Retrieves an output port for the input data object at the specified port and connection index. More...
vtkAlgorithmOutput * | GetInternalOutputPort (int port) override |
vtkAlgorithmOutput * | GetInternalOutputPort (int port, int conn) override |
vtkView * | GetView () const |
| Provides access to the view. More...
vtkMTimeType | GetPipelineDataTime () |
| Returns the timestamp when RequestData was executed on the representation. More...
bool | GetNeedsUpdate () |
| Returns true if the representation needs an update. More...
virtual void | SetArrayIdNames (const char *vtkNotUsed(pointArray), const char *vtkNotUsed(cellArray)) |
| Specify the array names used for the selection. More...
virtual void | SetUpdateTime (double time) |
| Set the update time. More...
virtual double | GetUpdateTime () |
virtual bool | GetUpdateTimeValid () |
| Get whether the UpdateTime is valid. More...
void | ResetUpdateTime () |
virtual void | SetForcedCacheKey (double val) |
| Generally, caching is within the purview of the vtkPVView (and subclasses). More...
virtual void | SetForceUseCache (bool val) |
virtual double | GetForcedCacheKey () |
virtual bool | GetForceUseCache () |
bool | AddToView (vtkView *view) override |
| Making these methods public. More...
bool | RemoveFromView (vtkView *view) override |
virtual void | SetLogName (const std::string &name) |
| This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged. More...
const std::string & | GetLogName () const |
virtual bool | GetHasTemporalPipeline () |
| This flag indicates if the representation is for a temporal pipeline. More...
virtual void | SetHasTemporalPipeline (bool) |
void | SetInputConnection (int port, vtkAlgorithmOutput *input) override |
| Overridden to ensure that MarkModified is called. More...
void | AddInputConnection (int port, vtkAlgorithmOutput *input) override |
vtkDataRepresentation * | NewInstance () const |
virtual void | ApplyViewTheme (vtkViewTheme *vtkNotUsed(theme)) |
virtual vtkSelection * | ConvertSelection (vtkView *view, vtkSelection *selection) |
vtkAlgorithmOutput * | GetInputConnection (int port=0, int index=0) |
vtkAnnotationLink * | GetAnnotationLink () |
void | SetAnnotationLink (vtkAnnotationLink *link) |
void | Select (vtkView *view, vtkSelection *selection) |
void | Select (vtkView *view, vtkSelection *selection, bool extend) |
void | Annotate (vtkView *view, vtkAnnotationLayers *annotations) |
void | Annotate (vtkView *view, vtkAnnotationLayers *annotations, bool extend) |
virtual void | SetSelectable (bool) |
virtual bool | GetSelectable () |
virtual void | SelectableOn () |
virtual void | SelectableOff () |
void | UpdateSelection (vtkSelection *selection) |
void | UpdateSelection (vtkSelection *selection, bool extend) |
void | UpdateAnnotations (vtkAnnotationLayers *annotations) |
void | UpdateAnnotations (vtkAnnotationLayers *annotations, bool extend) |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort () |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort (int port) |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort (int port, int conn) |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort () |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort (int port) |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort (int port, int conn) |
virtual void | SetSelectionType (int) |
virtual int | GetSelectionType () |
virtual void | SetSelectionArrayNames (vtkStringArray *names) |
virtual vtkStringArray * | GetSelectionArrayNames () |
virtual void | SetSelectionArrayName (const char *name) |
virtual const char * | GetSelectionArrayName () |
vtkPassInputTypeAlgorithm * | NewInstance () const |
vtkPolyData * | GetPolyDataOutput () |
vtkStructuredPoints * | GetStructuredPointsOutput () |
vtkImageData * | GetImageDataOutput () |
vtkStructuredGrid * | GetStructuredGridOutput () |
vtkUnstructuredGrid * | GetUnstructuredGridOutput () |
vtkRectilinearGrid * | GetRectilinearGridOutput () |
vtkTable * | GetTableOutput () |
vtkGraph * | GetGraphOutput () |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
| vtkPVImageChartRepresentation ()=default |
| ~vtkPVImageChartRepresentation () override |
void | PrepareForRendering () override |
| This method is called before actual render if this->MTime was modified since the last time this method was called. More...
vtkSmartPointer< vtkDataObject > | ReduceDataToRoot (vtkDataObject *data) override |
| Override to simply pass the data instead of converting it to vtkTable. More...
| vtkChartRepresentation () |
| ~vtkChartRepresentation () override |
int | FillInputPortInformation (int port, vtkInformation *info) override |
| Fill input port information. More...
int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
| Adds the representation to the view. More...
| Removes the representation to the view. More...
vtkTable * | GetLocalOutput (bool pre_delivery=false) |
| Convenience method to get the first vtkTable from LocalOutput, if any. More...
virtual vtkSmartPointer< vtkDataObject > | TransformInputData (vtkDataObject *data) |
| Method to be overridden to transform input data. More...
virtual vtkSmartPointer< vtkDataObject > | TransformTable (vtkSmartPointer< vtkDataObject > table) |
| Method to be overridden to apply an operation of the table after it is gathered to the first rank for rendering the chart. More...
bool | GetLocalOutput (MapOfTables &tables) |
| Convenience method to get all vtkTable instances with their associated names. More...
| vtkPVDataRepresentation () |
| ~vtkPVDataRepresentation () override |
vtkExecutive * | CreateDefaultExecutive () override |
| Create a default executive. More...
| Overridden to invoke vtkCommand::UpdateDataEvent. More...
int | RequestUpdateExtent (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
int | RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
virtual vtkObjectBase * | NewInstanceInternal () const |
| vtkDataRepresentation () |
| ~vtkDataRepresentation () |
virtual void | ProcessEvents (vtkObject *caller, unsigned long eventId, void *callData) |
virtual bool | AddToView (vtkView *vtkNotUsed(view)) |
virtual bool | RemoveFromView (vtkView *vtkNotUsed(view)) |
virtual vtkAnnotationLayers * | ConvertAnnotations (vtkView *view, vtkAnnotationLayers *annotations) |
vtkTrivialProducer * | GetInternalInput (int port, int conn) |
void | SetInternalInput (int port, int conn, vtkTrivialProducer *producer) |
virtual void | SetAnnotationLinkInternal (vtkAnnotationLink *link) |
| vtkPassInputTypeAlgorithm () |
| ~vtkPassInputTypeAlgorithm () |
virtual int | RequestUpdateTimeDependentInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
virtual int | FillOutputPortInformation (int port, vtkInformation *info) |
virtual int | RequestInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
virtual int | RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
| vtkAlgorithm () |
| ~vtkAlgorithm () |
virtual void | SetNumberOfInputPorts (int n) |
virtual void | SetNumberOfOutputPorts (int n) |
int | InputPortIndexInRange (int index, const char *action) |
int | OutputPortIndexInRange (int index, const char *action) |
int | GetInputArrayAssociation (int idx, vtkInformationVector **inputVector) |
void | ReportReferences (vtkGarbageCollector *) VTK_OVERRIDE |
virtual void | SetNumberOfInputConnections (int port, int n) |
int | GetInputArrayAssociation (int idx, int connection, vtkInformationVector **inputVector) |
int | GetInputArrayAssociation (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkInformation * | GetInputArrayFieldInformation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNthInputConnection (int port, int index, vtkAlgorithmOutput *input) |
void | SetInputDataInternal (int port, vtkDataObject *input) |
void | AddInputDataInternal (int port, vtkDataObject *input) |
virtual void | SetErrorCode (unsigned long) |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
