vtkChartTextRepresentation Class Reference
representation to add text to vtkPVContextView More...
#include <vtkChartTextRepresentation.h>
Inheritance diagram for vtkChartTextRepresentation:
Collaboration diagram for vtkChartTextRepresentation:
enum  DesiredOutputPrecision
virtual doubleGetPosition ()
 Get/Set the normalized text position in the scene when AnyLocation is used. More...
virtual void GetPosition (double &, double &)
virtual void GetPosition (double [2])
virtual void SetPosition (double, double)
void SetPosition (double [2])
void SetInteractivity (bool)
 Set the interactivity. More...
void SetTextProperty (vtkTextProperty *)
 Forwarded to vtkBlockItem. More...
void SetVisibility (bool val) override
virtual void MarkModified ()
virtual bool GetVisibility ()
virtual vtkDataObjectGetRenderedDataObject (int vtkNotUsed(port))
double GetCacheKey () const
vtkAlgorithmOutputGetInternalOutputPort () override
vtkAlgorithmOutputGetInternalOutputPort (int port) override
vtkAlgorithmOutputGetInternalOutputPort (int port, int conn) override
vtkViewGetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
const std::stringGetLogName () const
vtkDataRepresentationNewInstance () const
virtual vtkSelectionConvertSelection (vtkView *view, vtkSelection *selection)
vtkAlgorithmOutputGetInputConnection (int port=0, int index=0)
vtkAnnotationLinkGetAnnotationLink ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort ()
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort (int port)
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort (int port, int conn)
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort ()
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort (int port)
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort (int port, int conn)
virtual vtkStringArrayGetSelectionArrayNames ()
vtkPassInputTypeAlgorithmNewInstance () const
vtkPolyDataGetPolyDataOutput ()
vtkStructuredPointsGetStructuredPointsOutput ()
vtkImageDataGetImageDataOutput ()
vtkStructuredGridGetStructuredGridOutput ()
vtkUnstructuredGridGetUnstructuredGridOutput ()
vtkRectilinearGridGetRectilinearGridOutput ()
vtkTableGetTableOutput ()
vtkGraphGetGraphOutput ()
vtkDataObjectGetInput ()
vtkDataObjectGetOutput ()
vtkDataObjectGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkChartTextRepresentationNew ()
static vtkChartTextRepresentationSafeDownCast (vtkObject *o)
static vtkPVDataRepresentationSafeDownCast (vtkObject *o)
static vtkDataRepresentationNew ()
static vtkDataRepresentationSafeDownCast (vtkObjectBase *o)
static vtkPassInputTypeAlgorithmNew ()
static vtkPassInputTypeAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkChartTextRepresentation ()
 ~vtkChartTextRepresentation () override=default
 vtkPVDataRepresentation ()
vtkExecutiveCreateDefaultExecutive () override
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
virtual vtkAnnotationLayersConvertAnnotations (vtkView *view, vtkAnnotationLayers *annotations)
vtkTrivialProducerGetInternalInput (int port, int conn)
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
vtkDataObjectGetInput (int port)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
enum  {
  AnyLocation = 0, LowerLeftCorner, LowerRightCorner, LowerCenter,
  UpperLeftCorner, UpperRightCorner, UpperCenter
void SetLabelLocation (int location)
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
vtkStringArraySelectionArrayNames
CommandObserver
vtkAnnotationLinkAnnotationLinkInternal
double Progress
char * ProgressText
unsigned long ErrorCode
vtkChartTextRepresentation supports adding text to vtkPVContextView. It is the vtkTextSourceRepresentation counterpart except for vtkPVContextView instead of vtkPVRenderView. It adds a vtkBlockItem to the vtkContextScene maintained by the vtkPVContextView to render the text.
In theory, we can support interacting with the label to place it interactively. For now, we only support anchoring the label at one of the predefined anchor locations or specifying normalized coordinates manually.
Definition at line 26 of file vtkChartTextRepresentation.h.
Definition at line 30 of file vtkChartTextRepresentation.h.
◆ anonymous enum
anonymous enum
Enumerator
AnyLocation
LowerLeftCorner
LowerRightCorner
LowerCenter
UpperLeftCorner
UpperRightCorner
UpperCenter
Definition at line 34 of file vtkChartTextRepresentation.h.
◆ vtkChartTextRepresentation()
vtkChartTextRepresentation::vtkChartTextRepresentation ( )
◆ ~vtkChartTextRepresentation()
vtkChartTextRepresentation::~vtkChartTextRepresentation ( )
overrideprotecteddefault
static vtkChartTextRepresentation* vtkChartTextRepresentation::New ( )
virtual const char* vtkChartTextRepresentation::GetClassName ( )
static int vtkChartTextRepresentation::IsTypeOf ( const char *  type)
virtual int vtkChartTextRepresentation::IsA ( const char *  type)
static vtkChartTextRepresentation* vtkChartTextRepresentation::SafeDownCast ( vtkObject o)
void vtkChartTextRepresentation::PrintSelf ( ostream &  os,
◆ SetLabelLocation()
void vtkChartTextRepresentation::SetLabelLocation ( int  location)
◆ GetPosition() [1/3]
virtual double* vtkChartTextRepresentation::GetPosition ( )
Default is { 0.05, 0.05 }.
◆ GetPosition() [2/3]
virtual void vtkChartTextRepresentation::GetPosition ( double ,
double
◆ GetPosition() [3/3]
virtual void vtkChartTextRepresentation::GetPosition ( double  [2])
◆ SetPosition() [1/2]
virtual void vtkChartTextRepresentation::SetPosition ( double  ,
double
◆ SetPosition() [2/2]
void vtkChartTextRepresentation::SetPosition ( double  [2])
◆ SetInteractivity()
void vtkChartTextRepresentation::SetInteractivity ( bool  )
◆ SetTextProperty()
void vtkChartTextRepresentation::SetTextProperty ( vtkTextProperty )
◆ SetVisibility()
void vtkChartTextRepresentation::SetVisibility ( bool  val)
When the visibility of representation of false, all view passes are ignored.
◆ ProcessViewRequest()
int vtkChartTextRepresentation::ProcessViewRequest ( vtkInformationRequestKey request_type,
vtkInformation inInfo,
vtkInformation outInfo
Note
Starting with ParaView 5.8, this method is no longer called for hidden representation i.e. representations for which vtkDataRepresentation::GetVisibility() returns false.
◆ FillInputPortInformation()
int vtkChartTextRepresentation::FillInputPortInformation ( int  port,
vtkInformation info
overrideprotectedvirtual
Fill input port information.
◆ RequestData()
int vtkChartTextRepresentation::RequestData ( vtkInformation ,
vtkInformationVector **  ,
Overridden to invoke vtkCommand::UpdateDataEvent.
◆ AddToView()
bool vtkChartTextRepresentation::AddToView ( vtkView view)
◆ RemoveFromView()
bool vtkChartTextRepresentation::RemoveFromView ( vtkView view)
