cue used for parameter animation by the comparative view. More...
#include <vtkPVComparativeAnimationCue.h>
| void | UpdateXRange (int y, double minx, double maxx) |
| Methods use to fill up the values for the parameter over the comparative grid. More... | |
| void | UpdateYRange (int x, double miny, double maxy) |
| void | UpdateWholeRange (double mint, double maxt) |
| void | UpdateValue (int x, int y, double value) |
| void | UpdateAnimatedValue (int x, int y, int dx, int dy) |
| Update the animated property's value based on those specified using the Update. More... | |
| double * | GetValues (int x, int y, int dx, int dy, unsigned int &numValues) |
| NOTE: Returned values is only valid until the next call to this method. More... | |
| vtkPVXMLElement * | AppendCommandInfo (vtkPVXMLElement *proxyElem) |
| int | LoadCommandInfo (vtkPVXMLElement *proxyElement) |
| void | SetAnimatedProxy (vtkSMProxy *) |
| Set/Get the animated proxy. More... | |
| virtual vtkSMProxy * | GetAnimatedProxy () |
| void | RemoveAnimatedProxy () |
| virtual void | SetAnimatedPropertyName (const char *) |
| Set/Get the animated property name. More... | |
| virtual char * | GetAnimatedPropertyName () |
| virtual void | SetAnimatedDomainName (const char *) |
| Set/Get the animated domain name. More... | |
| virtual char * | GetAnimatedDomainName () |
| virtual void | SetAnimatedElement (int) |
| The index of the element of the property this cue animates. More... | |
| virtual int | GetAnimatedElement () |
| virtual void | SetEnabled (bool) |
| Enable/Disable the cue. More... | |
| virtual bool | GetEnabled () |
| virtual void | EnabledOn () |
| virtual void | EnabledOff () |
| void | UpdateXRange (int y, double *minx, double *maxx, unsigned int numvalues) |
| Use these methods when the parameter can have multiple values eg. More... | |
| void | UpdateYRange (int x, double *minx, double *maxx, unsigned int numvalues) |
| void | UpdateWholeRange (double *mint, double *maxt, unsigned int numValues) |
| void | UpdateWholeRange (double *mint, double *maxt, unsigned int numValues, bool vertical_first) |
| void | UpdateValue (int x, int y, double *value, unsigned int numValues) |
| double | GetValue (int x, int y, int dx, int dy) |
| Computes the value for a particular location in the comparative grid. More... | |
| static vtkPVComparativeAnimationCue * | New () |
| static vtkPVComparativeAnimationCue * | SafeDownCast (vtkObject *o) |
| vtkPVComparativeAnimationCue () | |
| ~vtkPVComparativeAnimationCue () override | |
| vtkSMProperty * | GetAnimatedProperty () |
| Get the property being animated. More... | |
| vtkSMDomain * | GetAnimatedDomain () |
| Get the domain being animated. More... | |
Protected Attributes | |
| vtkSMProxy * | AnimatedProxy |
| int | AnimatedElement |
| char * | AnimatedPropertyName |
| char * | AnimatedDomainName |
| double * | Values |
| bool | Enabled |
vtkPVComparativeAnimationCue is a animation cue used for parameter animation by the ComparativeView. It provides a non-conventional API i.e. without using properties to allow the user to setup parameter values over the comparative grid.
Definition at line 25 of file vtkPVComparativeAnimationCue.h.
Definition at line 29 of file vtkPVComparativeAnimationCue.h.
| void vtkPVComparativeAnimationCue::SetAnimatedProxy | ( | vtkSMProxy * | ) |
| void vtkPVComparativeAnimationCue::RemoveAnimatedProxy | ( | ) |
If the index is -1, the cue will animate all the elements of the animated property.
These are order dependent methods i.e. the result of calling UpdateXRange() and then UpdateYRange() are different from calling UpdateYRange() and then UpdateXRange(). These methods are convenience methods when the value can only be a single value.
Definition at line 84 of file vtkPVComparativeAnimationCue.h.
Definition at line 85 of file vtkPVComparativeAnimationCue.h.
Definition at line 86 of file vtkPVComparativeAnimationCue.h.
Definition at line 87 of file vtkPVComparativeAnimationCue.h.
| void vtkPVComparativeAnimationCue::UpdateXRange | ( | int | y, |
| double * | minx, | ||
| double * | maxx, | ||
| unsigned int | numvalues | ||
IsoValues for the Contour filter. The "AnimatedElement" for such properties must be set to -1, otherwise UpdateAnimatedValue() will raise an error.
| void vtkPVComparativeAnimationCue::UpdateYRange | ( | int | x, |
Definition at line 97 of file vtkPVComparativeAnimationCue.h.
| void vtkPVComparativeAnimationCue::UpdateWholeRange | ( | double * | mint, |
| double * | maxt, | ||
| unsigned int | numValues, | ||
| bool | vertical_first | ||
| void vtkPVComparativeAnimationCue::UpdateValue | ( | int | x, |
| int | y, | ||
| double * | value, | ||
| unsigned int | numValues | ||
(x,y) is the location in the comparative grid, while (dx, dy) are the dimensions of the comparative grid.
Definition at line 118 of file vtkPVComparativeAnimationCue.h.
| double* vtkPVComparativeAnimationCue::GetValues | ( | int | x, |
| int | y, | ||
| int | dx, | ||
| int | dy, | ||
| unsigned int & | numValues | ||
Return value is only valid when numValues > 0.
| vtkPVXMLElement* vtkPVComparativeAnimationCue::AppendCommandInfo | ( | vtkPVXMLElement * | proxyElem | ) |
| int vtkPVComparativeAnimationCue::LoadCommandInfo | ( | vtkPVXMLElement * | proxyElement | ) |
Definition at line 153 of file vtkPVComparativeAnimationCue.h.
Definition at line 154 of file vtkPVComparativeAnimationCue.h.
Definition at line 155 of file vtkPVComparativeAnimationCue.h.
Definition at line 156 of file vtkPVComparativeAnimationCue.h.
Definition at line 157 of file vtkPVComparativeAnimationCue.h.
Definition at line 158 of file vtkPVComparativeAnimationCue.h.
1.8.13 on Sun Dec 14 2025
