void | SetAutoLoad (unsigned int cc, bool) |
| API to change auto-load status. More...
void | SetDelayedLoad (unsigned int cc, bool) |
| API to change DelayedLoad status. More...
void | SetAutoLoadAndForce (unsigned int cc, bool) |
| This is a hack. More...
void | CopyFromObject (vtkObject *) override |
| Transfer information about a single object into this object. More...
void | AddInformation (vtkPVInformation *) override |
| Merge another information object. More...
void | Update (vtkPVPluginsInformation *other) |
| Updates the local information with elements from other without overriding auto-load state. More...
unsigned int | GetNumberOfPlugins () |
| API to iterate over the information collected for each plugin. More...
const char * | GetPluginName (unsigned int) |
const char * | GetPluginFileName (unsigned int) |
const char * | GetPluginVersion (unsigned int) |
bool | GetPluginLoaded (unsigned int) |
const char * | GetRequiredPlugins (unsigned int) |
bool | GetRequiredOnServer (unsigned int) |
bool | GetRequiredOnClient (unsigned int) |
const char * | GetDescription (unsigned int) |
bool | GetAutoLoad (unsigned int) |
bool | GetDelayedLoad (unsigned int) |
std::vector< std::string > | GetXMLs (unsigned int) |
const char * | GetPluginStatusMessage (unsigned int) |
| Set/Get the plugin status message for a specific plugin. More...
void | SetPluginStatusMessage (unsigned int, const char *) |
void | CopyToStream (vtkClientServerStream *) override |
| Manage a serialized version of the information. More...
void | CopyFromStream (const vtkClientServerStream *) override |
virtual char * | GetSearchPaths () |
| Get the plugin search path. More...
virtual void | CopyParametersToStream (vtkMultiProcessStream &) |
| Serialize/Deserialize the parameters that control how/what information is gathered. More...
virtual void | CopyParametersFromStream (vtkMultiProcessStream &) |
virtual int | GetRootOnly () |
| Set/get whether to gather information only from the root. More...
virtual void | Modified () |
information about plugins tracked by vtkPVPluginTracker.
vtkPVPluginsInformation is used to collect information about plugins tracked by vtkPVPluginTracker.
Definition at line 18 of file vtkPVPluginsInformation.h.
