| The name assigned by the xml parser. More...
virtual char * | GetCommand () |
| The command name used to set the value on the server object. More...
virtual bool | GetInformationOnly () |
| Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual bool | GetRepeatable () |
| If repeatable, a property can have 1 or more values of the same kind. More...
virtual void | SetIsInternal (bool) |
| This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More...
virtual bool | GetIsInternal () |
virtual void | Modified () |
Select names from an indexed string list.
Expected Methods on reader (assuming command="Dimension"): int GetNumberOfDimensions() std::string GetDimensionName(int) int GetCurrentDimensionIndex(std::string) int GetDimensionSize(std::string) void SetCurrentDimensionIndex(std::string, int)
Definition at line 21 of file vtkSIIndexSelectionProperty.h.
