#include <vtkSIVectorPropertyTemplate.h>
| typedef vtkSIVectorProperty | Superclass |
Public Types inherited from vtkSIVectorProperty | |
| virtual bool | GetArgumentIsArray () |
| If ArgumentIsArray is true, multiple elements are passed in as array arguments. More... | |
Public Member Functions inherited from vtkSIVectorProperty | |
| virtual bool | GetUseIndex () |
| static vtkSIVectorPropertyTemplate * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSIVectorProperty | |
| static vtkSIVectorProperty * | SafeDownCast (vtkObject *o) |
| vtkSIVectorPropertyTemplate () | |
| ~vtkSIVectorPropertyTemplate () override | |
| bool | Push (vtkSMMessage *, int) override |
| bool | Pull (vtkSMMessage *) override |
| bool | ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override |
| bool | Push (T *values, int number_of_elements) |
| Implements the actual push. More... | |
Protected Member Functions inherited from vtkSIVectorProperty | |
| vtkSIVectorProperty () | |
| ~vtkSIVectorProperty () override | |
| vtkSIProperty () | |
Protected Attributes | |
| bool | ArgumentIsArray |
Protected Attributes inherited from vtkSIVectorProperty | |
| char * | SetNumberCommand |
| char * | CleanCommand |
| bool | UseIndex |
| int | NumberOfElementsPerCommand |
| char * | InitialString |
| char * | XMLName |
| char * | Command |
| bool | InformationOnly |
| bool | Repeatable |
| bool | IsInternal |
Definition at line 16 of file vtkSIVectorPropertyTemplate.h.
| typedef vtkSIVectorProperty vtkSIVectorPropertyTemplate< T, force_idtype >::Superclass |
Definition at line 19 of file vtkSIVectorPropertyTemplate.h.
Reimplemented from vtkSIVectorProperty.
For example, For example, if RepeatCommand is true, NumberOfElementsPerCommand is 2, the command is SetFoo and the values are 1 2 3 4 5 6, the resulting stream will have:
* * Invoke obj SetFoo array(1, 2) * * Invoke obj SetFoo array(3, 4) * * Invoke obj SetFoo array(5, 6) *
overrideprotectedvirtual |
Parse the xml for the property.
Definition at line 62 of file vtkSIVectorPropertyTemplate.h.
1.8.13 on Sun Dec 14 2025
