int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| Set the default values for the property. More...
void | Update (vtkSMProperty *requestingProperty) override |
| Overridden to fire DomainModified when the required property changes. More...
Public Member Functions inherited from vtkSMBooleanDomain |
int | IsInDomain (vtkSMProperty *property) override |
| Returns true if the property is a vtkSMIntVectorProperty. More...
void | SetAnimationValue (vtkSMProperty *property, int idx, double value) override |
| Set the value of an element of a property from the animation editor. More...
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
virtual void | Modified () |
