used to build a vtkSMCompoundSourceProxy definition. More...
#include <vtkSMCompoundSourceProxyDefinitionBuilder.h>
void | Reset () |
Resets the builder. More... | |
void | AddProxy (const char *name, vtkSMProxy *proxy) |
Add a proxy to be included in this compound proxy. More... | |
void | ExposeProperty (const char *proxyName, const char *propertyName, const char *exposedName) |
Expose a property from the sub proxy (added using AddProxy). More... | |
void | ExposeOutputPort (const char *proxyName, const char *portName, const char *exposedName) |
Expose an output port from a subproxy. More... | |
void | ExposeOutputPort (const char *proxyName, unsigned int portIndex, const char *exposedName) |
unsigned int | GetNumberOfProxies () |
Returns the number of sub-proxies. More... | |
vtkSMProxy * | GetProxy (unsigned int cc) |
Returns the sub proxy at a given index. More... | |
vtkSMProxy * | GetProxy (const char *name) |
Returns the subproxy with the given name. More... | |
const char * | GetProxyName (unsigned int index) |
Returns the name used to store sub-proxy. More... | |
vtkPVXMLElement * | SaveDefinition (vtkPVXMLElement *root) |
This is the same as save state except it will remove all references to "outside" proxies. More... | |
virtual void | Modified () |
static vtkSMCompoundSourceProxyDefinitionBuilder * | New () |
static vtkSMCompoundSourceProxyDefinitionBuilder * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMCompoundSourceProxyDefinitionBuilder () | |
~vtkSMCompoundSourceProxyDefinitionBuilder () override | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMCompoundSourceProxyDefinitionBuilder is used to create a XML definition for a compound-proxy consisting of other proxies. This class can only build one compound-proxy definition at a time. Use Reset() to start a new definition.
Definition at line 25 of file vtkSMCompoundSourceProxyDefinitionBuilder.h.
Definition at line 29 of file vtkSMCompoundSourceProxyDefinitionBuilder.h.
void vtkSMCompoundSourceProxyDefinitionBuilder::Reset | ( | ) |
Resets the builder.
This can be used when using the builder to create multiple definitions.
void vtkSMCompoundSourceProxyDefinitionBuilder::AddProxy | ( | const char * | name, |
vtkSMProxy * | proxy | ||
The name must be unique to each proxy added, otherwise the previously added proxy will be replaced.
void vtkSMCompoundSourceProxyDefinitionBuilder::ExposeProperty | ( | const char * | proxyName, |
const char * | propertyName, | ||
const char * | exposedName | ||
Only exposed properties are accessible externally. Note that the sub proxy whose property is being exposed must have been already added using AddProxy().
void vtkSMCompoundSourceProxyDefinitionBuilder::ExposeOutputPort | ( | const char * | proxyName, |
const char * | portName, | ||
Exposed output ports are treated as output ports of the vtkSMCompoundSourceProxy itself. This method does not may the output port available. One must call CreateOutputPorts().
unsigned int | portIndex, | ||
unsigned int vtkSMCompoundSourceProxyDefinitionBuilder::GetNumberOfProxies | ( | ) |
vtkSMProxy* vtkSMCompoundSourceProxyDefinitionBuilder::GetProxy | ( | unsigned int | cc | ) |
vtkSMProxy* vtkSMCompoundSourceProxyDefinitionBuilder::GetProxy | ( | const char * | name | ) |
Returns 0 if sub-proxy does not exist.
vtkPVXMLElement* vtkSMCompoundSourceProxyDefinitionBuilder::SaveDefinition | ( | vtkPVXMLElement * | root | ) |
Outside proxies are proxies that are not contained in the compound proxy. As a result, the saved state will be self contained. Returns the top element created. It is the caller's responsibility to delete the returned element. If root is nullptr, the returned element will be a top level element.
