void | AddProxy (const char *name, vtkSMProxy *proxy) |
| Add a proxy to be included in this compound proxy. More...
void | ExposeProperty (const char *proxyName, const char *propertyName, const char *exposedName) |
| Expose a property from the sub proxy (added using AddProxy). More...
void | ExposeOutputPort (const char *proxyName, const char *portName, const char *exposedName) |
| Expose an output port from a subproxy. More...
void | ExposeOutputPort (const char *proxyName, unsigned int portIndex, const char *exposedName) |
unsigned int | GetNumberOfProxies () |
| Returns the number of sub-proxies. More...
vtkSMProxy * | GetProxy (unsigned int cc) |
| Returns the sub proxy at a given index. More...
vtkSMProxy * | GetProxy (const char *name) |
| Returns the subproxy with the given name. More...
const char * | GetProxyName (unsigned int index) |
| Returns the name used to store sub-proxy. More...
void | CreateOutputPorts () override |
| Creates the output port proxiess for this filter. More...
void | CreateSelectionProxies () override |
| Creates extract selection proxies for each output port if not already created. More...
void | UpdateVTKObjects () override |
vtkPVXMLElement * | SaveDefinition (vtkPVXMLElement *root) |
| This is the same as save state except it will remove all references to "outside" proxies. More...
void | UpdatePipelineInformation () override |
| Calls UpdateInformation() on all sources. More...
virtual void | UpdatePipeline () |
| Calls Update() on all sources. More...
virtual void | UpdatePipeline (double time) |
| Calls Update() on all sources with the given time request. More...
virtual unsigned int | GetNumberOfOutputPorts () |
| Return the number of output ports. More...
virtual vtkSMOutputPort * | GetOutputPort (unsigned int idx) |
| Return an output port. More...
virtual vtkSMOutputPort * | GetOutputPort (const char *portname) |
| Return an output port, given the name for the port. More...
virtual unsigned int | GetOutputPortIndex (const char *portname) |
| Returns the port index, given the name of an output port. More...
virtual const char * | GetOutputPortName (unsigned int index) |
| Returns the output port name given its index. More...
vtkPVDataInformation * | GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex) |
| A GetSubsetDataInformation overload that uses composite index. More...
void | SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort) |
| Set/Get the selection input. More...
void | CleanSelectionInputs (unsigned int portIndex) |
| Clean all selection inputs for the given port. More...
vtkSMSourceProxy * | GetSelectionOutput (unsigned int portIndex) |
| Returns the source proxy which provides the selected data from the given output port. More...
unsigned int | GetNumberOfAlgorithmOutputPorts () |
| Returns the number of output ports provided by the algorithm. More...
virtual unsigned int | GetNumberOfAlgorithmRequiredInputPorts () |
| Returns the number of non-optional input ports required by the algorithm. More...
vtkTypeUInt32 | GetGlobalID () override |
| Overridden to reserve additional IDs for use by "ExtractSelection" proxies. More...
void | MarkDirty (vtkSMProxy *modifiedProxy) override |
| Marks the selection proxies dirty as well as chain to superclass. More...
virtual int | GetOutputPortsCreated () |
| Returns if the output port proxies have been created. More...
vtkSMDocumentation * | GetOutputPortDocumentation (unsigned int index) |
| It is possible to provide some documentation for each output port in the configuration xml. More...
vtkSMDocumentation * | GetOutputPortDocumentation (const char *portname) |
vtkPVDataInformation * | GetDataInformation () |
| DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
vtkPVDataInformation * | GetDataInformation (unsigned int outputIdx) |
vtkPVDataInformation * | GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr) |
| For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
vtkPVDataInformation * | GetRankDataInformation (int rank) |
| Get rank-specific data information. More...
vtkPVDataInformation * | GetRankDataInformation (unsigned int outputIdx, int rank) |
vtkSMSourceProxy * | GetSelectionInput (unsigned int portIndex) |
| API to query selection input set using SetSelectionInput. More...
unsigned int | GetSelectionInputPort (unsigned int portIndex) |
virtual int | GetProcessSupport () |
| This returns information about whether the VTK algorithm supports multiple processes or not. More...
virtual bool | GetMPIRequired () |
| This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
| vtkSMCompoundSourceProxy () |
| ~vtkSMCompoundSourceProxy () override |
int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) override |
| Read attributes from an XML element. More...
void | CreateVTKObjects () override |
| Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More...
int | ShouldWriteValue (vtkPVXMLElement *valueElem) |
void | TraverseForProperties (vtkPVXMLElement *root) |
void | StripValues (vtkPVXMLElement *propertyElem) |
| vtkSMSourceProxy () |
| ~vtkSMSourceProxy () override |
virtual void | InvalidateDataInformation () |
| Mark the data information as invalid. More...
virtual void | SetExecutiveName (const char *) |
void | PostUpdateData (bool) override |
| Overwritten from superclass to invoke. More...
void | SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override |
| Overridden to pass the logname to the internal ExtractSelection proxies. More...
void | SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc) |
| Method to set an output port at the given index. More...
void | RemoveAllOutputPorts () |
void | SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy) |
void | RemoveAllExtractSelectionProxies () |
| vtkSMProxy () |
| ~vtkSMProxy () override |
void | ExecuteStream (const vtkClientServerStream &msg, bool ignore_errors=false, vtkTypeUInt32 location=0) |
| Invoke that takes a vtkClientServerStream as the argument. More...
virtual void | UpdateAndPushAnnotationState () |
virtual void | AddProperty (const char *name, vtkSMProperty *prop) |
| Add a property with the given key (name). More...
virtual void | MarkConsumersAsDirty (vtkSMProxy *modifiedProxy) |
| Calls MarkDirtyFromProducer on all consumers. More...
virtual void | MarkDirtyFromProducer (vtkSMProxy *modifiedProxy, vtkSMProxy *producer, vtkSMProperty *property) |
| MarkConsumersAsDirty calls this method on each consumer, instead of directly calling MarkDirty on the consumer. More...
void | MarkInputsAsDirty () |
| This method is called by vtkSMRepresentationProxy whenever the time request for the pipeline may have potentially changed. More...
| Cleanup code. More...
virtual void | SetPropertyModifiedFlag (const char *name, int flag) |
| Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself. More...
void | AddSubProxy (const char *name, vtkSMProxy *proxy, int overrideOK=0) |
| Add a sub-proxy. More...
void | RemoveSubProxy (const char *name) |
| Remove a sub-proxy. More...
vtkSMProxy * | GetSubProxy (const char *name) |
| Returns a sub-proxy. More...
vtkSMProxy * | GetSubProxy (unsigned int index) |
const char * | GetSubProxyName (unsigned int index) |
const char * | GetSubProxyName (vtkSMProxy *) |
unsigned int | GetNumberOfSubProxies () |
virtual void | AddConsumer (vtkSMProperty *property, vtkSMProxy *proxy) |
| Called by a proxy property, this adds the property,proxy pair to the list of consumers. More...
virtual void | RemoveConsumer (vtkSMProperty *property, vtkSMProxy *proxy) |
| Remove the property,proxy pair from the list of consumers. More...
virtual void | RemoveAllConsumers () |
| Remove all consumers. More...
void | AddProducer (vtkSMProperty *property, vtkSMProxy *proxy) |
| Called by an proxy/input property to add property, proxy pair to the list of producers. More...
void | RemoveProducer (vtkSMProperty *property, vtkSMProxy *proxy) |
| Remove the property,proxy pair from the list of producers. More...
void | PostUpdateDataSelfOnly (bool using_cache) |
| This is called by PostUpdateData to only update state for this proxy without iterative over producers. More...
bool | WarnIfDeprecated () |
| If a proxy is deprecated, prints a warning. More...
bool | LoadPluginIfEnsured () |
| If a proxy need to ensure a plugin is loaded, make sure it is. More...
void | LinkProperty (vtkSMProperty *inputProperty, vtkSMProperty *outputProperty) |
| Links properties such that when inputProperty's checked or unchecked values are changed, the outputProperty's corresponding values are also changed. More...
vtkSMPropertyGroup * | NewPropertyGroup (vtkPVXMLElement *propElement) |
| Parses the XML to create a new property group. More...
void | AppendPropertyGroup (vtkSMPropertyGroup *group) |
| Adds a property groups. More...
void | ExposeSubProxyProperty (const char *subproxy_name, const char *property_name, const char *exposed_name, int overrideOK=0) |
| Expose a subproxy property from the base proxy. More...
virtual void | ExecuteSubProxyEvent (vtkSMProxy *o, unsigned long event, void *data) |
| Handle events fired by subproxies. More...
virtual int | CreateSubProxiesAndProperties (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) |
virtual void | UpdatePropertyInformationInternal (vtkSMProperty *prop=nullptr) |
| Called to update the property information on the property. More...
void | RebuildStateForProperties () |
| vtkSMProxy tracks state of properties on this proxy in an internal State object. More...
bool | ArePropertiesModified () |
| Indicates if any properties are modified. More...
void | SetHints (vtkPVXMLElement *hints) |
void | SetDeprecated (vtkPVXMLElement *deprecated) |
void | SetEnsurePluginLoaded (vtkPVXMLElement *ensurePluginLoaded) |
| Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured. More...
void | SetXMLElement (vtkPVXMLElement *element) |
| vtkSMProxy (const vtkSMProxy &)=delete |
void | operator= (const vtkSMProxy &)=delete |
virtual const vtkClientServerStream & | GetLastResult () |
| Get the last result. More...
virtual const vtkClientServerStream & | GetLastResult (vtkTypeUInt32 location) |
virtual void | SetXMLGroup (const char *) |
virtual void | SetXMLLabel (const char *) |
virtual void | SetXMLSubProxyName (const char *) |
vtkSMProperty * | NewProperty (const char *name) |
| Creates a new property and initializes it by calling ReadXMLAttributes() with the right XML element. More...
vtkSMProperty * | NewProperty (const char *name, vtkPVXMLElement *propElement) |
void | SetupExposedProperties (const char *subproxy_name, vtkPVXMLElement *element) |
void | SetupSharedProperties (vtkSMProxy *subproxy, vtkPVXMLElement *element) |
virtual void | SetSIClassName (const char *) |
| SIClassName identifies the classname for the helper on the server side. More...
virtual char * | GetSIClassName () |
| vtkSMRemoteObject () |
| Default constructor. More...
| ~vtkSMRemoteObject () override |
| Destructor. More...
void | PushState (vtkSMMessage *msg) |
| Subclasses can call this method to send a message to its state object on the server processes specified. More...
bool | PullState (vtkSMMessage *msg) |
| Subclasses can call this method to pull the state from the state-object on the server processes specified. More...
void | SetGlobalID (vtkTypeUInt32 guid) |
| Set the GlobalUniqueId. More...
vtkTypeUInt32 | GetFilteredLocation () |
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
