int | IsInDomain (vtkSMProperty *property) override |
| Returns true if the property is a vtkSMIntVectorProperty. More...
void | Update (vtkSMProperty *) override |
| Update self checking the "unchecked" values of all required properties. More...
int | SetDefaultValues (vtkSMProperty *prop, bool use_unchecked_values) override |
| Set Default value. More...
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| Set the value of an element of a property from the animation editor. More...
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
virtual void | Modified () |
| vtkSMFrameStrideQueryDomain () |
| ~vtkSMFrameStrideQueryDomain () override |
| vtkSMDomain () |
| ~vtkSMDomain () override |
| Load the state of the domain from the XML. More...
virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| Set the appropriate ivars from the xml element. More...
| Remove the given property from the required properties list. More...
| Add a new required property to this domain. More...
void | DomainModified () |
| Invokes DomainModifiedEvent. More...
void | InvokeModified () |
| Gets the number of required properties added. More...
| Set the domain's property. More...
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
A domain for getting the input data type and setting it.
This domain is used to query the frame stride of the animation scene to the property and set it as the default value and during the update.
Example usage is as follows:
<SourceProxy ...>
<IntVectorProperty command="SetFrameStride"
default_values="1"
name="FrameStride"
number_of_elements="1">
<FrameStrideQueryDomain name="frame_stride_query">
<RequiredProperties>
<Property function="AnimationScene"
name="AnimationScene"/>
</RequiredProperties>
</FrameStrideQueryDomain>
</IntVectorProperty>
</SourceProxy>
- See also
- vtkSMDomain vtkSMIntVectorProperty
Definition at line 38 of file vtkSMFrameStrideQueryDomain.h.
