Controller that encapsulates control logic for typical ParaView applications. More...
#include <vtkSMParaViewPipelineController.h>
virtual bool | InitializeSession (vtkSMSession *session) |
Call this method to setup a branch new session with state considered essential for ParaView session. More... | |
virtual vtkSMProxy * | FindTimeKeeper (vtkSMSession *session) |
Returns the TimeKeeper proxy associated with the session. More... | |
virtual vtkSMProxy * | FindMaterialLibrary (vtkSMSession *session) |
Returns the MaterialLibrary proxy associated with the session. More... | |
virtual bool | PreInitializeProxy (vtkSMProxy *proxy) |
Pre-initializes a proxy i.e. More... | |
virtual bool | PostInitializeProxy (vtkSMProxy *proxy) |
Final step in proxy initialization. More... | |
bool | InitializeProxy (vtkSMProxy *proxy) |
Convenience method to call PreInitializeProxy and PostInitializeProxy. More... | |
virtual bool | FinalizeProxy (vtkSMProxy *proxy) |
Cleans up any helper proxies registered for the proxy in PreInitializeProxy/PostInitializeProxy. More... | |
virtual bool | RegisterPipelineProxy (vtkSMProxy *proxy, const char *proxyname) |
Use this method after PreInitializeProxy() and PostInitializeProxy() to register a pipeline proxy with the proxy manager. More... | |
virtual bool | RegisterPipelineProxy (vtkSMProxy *proxy) |
virtual bool | UnRegisterPipelineProxy (vtkSMProxy *proxy) |
Unregisters a pipeline proxy. More... | |
virtual bool | RegisterViewProxy (vtkSMProxy *proxy) |
Use this method after PreInitializeProxy() and PostInitializeProxy() to register a view proxy with the proxy manager. More... | |
virtual bool | RegisterViewProxy (vtkSMProxy *proxy, const char *proxyname) |
virtual bool | UnRegisterViewProxy (vtkSMProxy *proxy, bool unregister_representations=true) |
Inverse of RegisterViewProxy. More... | |
virtual bool | UnRegisterRepresentationProxy (vtkSMProxy *proxy) |
Unregisters a representation proxy. More... | |
virtual bool | RegisterColorTransferFunctionProxy (vtkSMProxy *proxy, const char *proxyname) |
Registration method for color transfer function proxies to be used after PreInitializeProxy() and PostInitializeProxy() calls. More... | |
virtual bool | RegisterColorTransferFunctionProxy (vtkSMProxy *proxy) |
virtual bool | RegisterOpacityTransferFunction (vtkSMProxy *proxy, const char *proxyname) |
Registration method for opacity transfer function proxies. More... | |
virtual bool | RegisterOpacityTransferFunction (vtkSMProxy *proxy) |
virtual bool | RegisterTransferFunction2D (vtkSMProxy *proxy, const char *proxyname) |
Registration method for 2D transfer function proxies. More... | |
virtual bool | RegisterTransferFunction2D (vtkSMProxy *proxy) |
virtual bool | RegisterLightProxy (vtkSMProxy *proxy, vtkSMProxy *view, const char *proxyname) |
Use this method after PreInitializeProxy() and PostInitializeProxy() to register a light proxy with the proxy manager. More... | |
virtual bool | RegisterLightProxy (vtkSMProxy *proxy, vtkSMProxy *view) |
virtual bool | RegisterTextureProxy (vtkSMProxy *proxy, const char *filename) |
Use this method after PreInitializeProxy() and PostInitializeProxy() to register a texture proxy with the proxy manager. More... | |
virtual bool | RegisterTextureProxy (vtkSMProxy *proxy, const char *trivialProducerKeyName, const char *proxyname) |
virtual bool | RegisterExtractorProxy (vtkSMProxy *proxy, const char *proxyname) |
Registers an extractor. More... | |
virtual bool | RegisterExtractorProxy (vtkSMProxy *proxy) |
virtual vtkSMProxy * | FindAnimationScene (vtkSMSession *session) |
Returns the animation scene, if any. More... | |
virtual vtkSMProxy * | GetAnimationScene (vtkSMSession *session) |
Returns the animation scene for the session. More... | |
virtual vtkSMProxy * | FindTimeAnimationTrack (vtkSMProxy *scene) |
Return the animation track for time, if any. More... | |
virtual vtkSMProxy * | GetTimeAnimationTrack (vtkSMProxy *scene) |
Return the animation track for time. More... | |
virtual bool | RegisterAnimationProxy (vtkSMProxy *proxy) |
Use this method after PreInitializeProxy() and PostInitializeProxy() to register an animation proxy with the proxy manager. More... | |
virtual bool | UnRegisterAnimationProxy (vtkSMProxy *proxy) |
Inverse of RegisterAnimationProxy. More... | |
virtual void | UpdateSettingsProxies (vtkSMSession *session) |
Initializes and registers proxies in the "settings" group that haven't been already. More... | |
virtual bool | UnRegisterProxy (vtkSMProxy *proxy) |
A catch-all method do cleanup and unregister any proxies that were registered using Register..Proxy() APIs on this class. More... | |
virtual bool | RegisterRepresentationProxy (vtkSMProxy *proxy) |
Registration method for representations to be used after PreInitializeProxy() and PostInitializeProxy(). More... | |
virtual bool | RegisterRepresentationProxy (vtkSMProxy *proxy, const char *proxyname) |
virtual void | Modified () |
static vtkSMParaViewPipelineController * | New () |
static vtkSMParaViewPipelineController * | SafeDownCast (vtkObject *o) |
static std::string | GetHelperProxyGroupName (vtkSMProxy *) |
For a given proxy returns the name of the group used for helper proxies. More... | |
static vtkObject * | New () |
vtkSMParaViewPipelineController () | |
~vtkSMParaViewPipelineController () override | |
vtkSMProxy * | FindProxy (vtkSMSessionProxyManager *pxm, const char *reggroup, const char *xmlgroup, const char *xmltype) |
Find proxy of the group type (xmlgroup, xmltype) registered under a particular group (reggroup). More... | |
virtual bool | SetupGlobalPropertiesLinks (vtkSMProxy *proxy) |
Setup global properties links based on hints for properties in the XML. More... | |
virtual bool | CreateAnimationHelpers (vtkSMProxy *proxy) |
To help animation representation properties such as visibility, opacity, we create animation helpers. More... | |
virtual bool | UnRegisterDependencies (vtkSMProxy *proxy) |
Unregisters know proxy dependencies that must be removed when the proxy is to be deleted e.g animation cues, representations, etc. More... | |
vtkMTimeType | GetInitializationTime (vtkSMProxy *) |
Returns the initialization timestamp for the proxy, if available. More... | |
void | ProcessInitializationHelperRegistration (vtkSMProxy *) |
If the proxy has initialization helpers, let those classes also handle registration tasks, if any. More... | |
virtual bool | CreateProxiesForProxyListDomains (vtkSMProxy *proxy) |
Creates new proxies for proxies referred in vtkSMProxyListDomain for any of the properties for the given proxy. More... | |
virtual void | RegisterProxiesForProxyListDomains (vtkSMProxy *proxy) |
void | ProcessInitializationHelper (vtkSMProxy *, vtkMTimeType initializationTimeStamp) |
Proxies can specify custom initialization using XML hints. More... | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
bool | Debug |
vtkTimeStamp | MTime |
ParaView's ServerManager, together with it's proxies and properties provides a mechanism to create visualization and data processing pipelines. However, for a complex application like ParaView, there is considerable control logic to manage these proxies, set them up, etc. for common operations supported by the application. vtkSMParaViewPipelineController provides us a mechanism to encapsulate just control logic with ability to customize and extend for custom applications, similar to ParaView.
vtkSMParaViewPipelineController has no state of itself. When needed, one should simply create an instance of vtkSMParaViewPipelineController and release it once done.
vtkSMParaViewPipelineController uses the vtkObjectFactory mechanism. Custom application developers can provide subclasses and override the behaviour (see vtkSMParaViewPipelineControllerWithRender).
For an example of using vtkSMParaViewPipelineController in your application, see Remoting/Views/Testing/Cxx/TestParaViewPipelineController.cxx
Definition at line 40 of file vtkSMParaViewPipelineController.h.
Definition at line 44 of file vtkSMParaViewPipelineController.h.
Reimplemented in vtkSMParaViewPipelineControllerWithRendering.
Returns true on success.
prepares the proxy for initialization. One should call this before changing any properties on the proxy. We load the property values from XML defaults as well as user-preferences here.
When this method is called, all essential properties on the proxy (such as inputs for filters, or filename on readers) are assumed to be set up so that domains can be updated. This method setups up property values for those properties that weren't modified since the PreInitializeProxy() using the domains, if possible. This enables the application to select data-specific default values. NOTE: This method does not register the proxy with the proxy manager. It may, however register any helper proxies created for this proxy.
Definition at line 86 of file vtkSMParaViewPipelineController.h.
Similar to PreInitializeProxy/PostInitializeProxy methods, this doesn't affect the proxy manager registration state for the proxy itself.
This method does additional updates required for pipeline proxies such as registering the proxy with the TimeKeeper, creating additional helper proxies for enabling representation animations, and updating the active-source. This method will register the proxy in an appropriate group so that the application becomes aware of it. One can optionally pass in the registration name to use. Otherwise, this code will come up with a unique name. Caveat: while pipeline proxies are generally registered under the "sources" group, there's one exception: sources that produce vtkSelection. ParaView treats them specially and registers them under "selection_sources".
inlinevirtual |
Definition at line 116 of file vtkSMParaViewPipelineController.h.
This is the inverse of RegisterPipelineProxy() and hence unsets the active source if the active source if this proxy, unregisters the proxy with the TimeKeeper etc. Users can use either this method or the catch-all vtkSMParaViewPipelineController::UnRegisterProxy() method which determines the type of the proxy and then calls the appropriate method.
inlinevirtual |
This will also perform any additional setups as needed e.g. registering the view with the animation scene and the timer keeper.
Definition at line 140 of file vtkSMParaViewPipelineController.h.
Users can use either this method or the catch-all vtkSMParaViewPipelineController::UnRegisterProxy() method which determines the type of the proxy and then calls the appropriate method. If the optional argument, unregister_representations
, is false (default is true), then this method will skip the unregistering of representations. Default behaviour is to unregister all representations too.
inlinevirtual |
Register the proxy under the appropriate group.
Definition at line 163 of file vtkSMParaViewPipelineController.h.
inlinevirtual |
Definition at line 186 of file vtkSMParaViewPipelineController.h.
inlinevirtual |
Definition at line 195 of file vtkSMParaViewPipelineController.h.
inlinevirtual |
Definition at line 204 of file vtkSMParaViewPipelineController.h.
This will also perform needed python tracing.
inlinevirtual |
Definition at line 215 of file vtkSMParaViewPipelineController.h.
inlinevirtual |
Definition at line 236 of file vtkSMParaViewPipelineController.h.
Returns nullptr if none exists.
If none exists, a new one will be created. This may returns nullptr if animation scene proxy is not available in the session.
If none exists, a new one will be created. Returns nullptr if the proxy is not available in the session.
Also unregisters cues if proxy is scene, keyframes if proxy is a cue, etc. Users can use either this method or the catch-all vtkSMParaViewPipelineController::UnRegisterProxy() method which determines the type of the proxy and then calls the appropriate method.
This may be called whenever a new settings proxy definition becomes available, say, after loading a plugin.
It determines what known types the "proxy" is, i.e. is it a view, or pipeline, or representation etc., and then calls the appropriate UnRegister...Proxy() method.
Returns the first proxy found, if any.
protectedvirtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
Useful for subclasses to determine which properties were modified since initialization.
This method calls those initialization helpers, if any.
This is called in RegisterProxy
